Mam błędy przy instalacji:
apt-get instlal libACEKod: Zaznacz cały
In file included from /root/trinitycore2/src/shared/Common.h:103,
from /root/trinitycore2/src/bindings/scripts/include/../ScriptM gr.h:11,
from /root/trinitycore2/src/bindings/scripts/include/precompile d.h:8,
from /root/trinitycore2/src/bindings/scripts/ScriptMgr.cpp:5:
/root/trinitycore2/src/shared/LockedQueue.h: In member function 'void ACE_Based: :LockedQueue<T, LockType, StorageType>::add(const T&)':
/root/trinitycore2/src/shared/LockedQueue.h:57: error: 'ACE_Stack_Trace' was not declared in this scope
/root/trinitycore2/src/shared/LockedQueue.h:57: error: expected `;' before 'st'
/root/trinitycore2/src/shared/LockedQueue.h:57: error: 'st' was not declared in this scope
/root/trinitycore2/src/shared/LockedQueue.h: In member function 'T ACE_Based::Lo ckedQueue<T, LockType, StorageType>::next()':
/root/trinitycore2/src/shared/LockedQueue.h:70: error: 'ACE_Stack_Trace' was not declared in this scope
/root/trinitycore2/src/shared/LockedQueue.h:70: error: expected `;' before 'st'
/root/trinitycore2/src/shared/LockedQueue.h:70: error: 'st' was not declared in this scope
/root/trinitycore2/src/shared/LockedQueue.h: In member function 'T ACE_Based::Lo ckedQueue<T, LockType, StorageType>::front()':
/root/trinitycore2/src/shared/LockedQueue.h:83: error: 'ACE_Stack_Trace' was not declared in this scope
/root/trinitycore2/src/shared/LockedQueue.h:83: error: expected `;' before 'st'
/root/trinitycore2/src/shared/LockedQueue.h:83: error: 'st' was not declared in this scope
In file included from /root/trinitycore2/src/shared/Database/DatabaseEnv.h:29,
from /root/trinitycore2/src/shared/Log.h:26,
from /root/trinitycore2/src/shared/ByteBuffer.h:26,
from /root/trinitycore2/src/game/GridNotifiers.h:25,
from /root/trinitycore2/src/bindings/scripts/include/precompile d.h:11,
/root/trinitycore2/src/shared/Database/QueryResult.h: In member function 'uint32 QueryNamedResult::GetField_idx(const std::string&) const':
/root/trinitycore2/src/shared/Database/QueryResult.h:73: error: 'ACE_Stack_Trace ' was not declared in this scope
/root/trinitycore2/src/shared/Database/QueryResult.h:73: error: expected `;' bef ore 'st'
/root/trinitycore2/src/shared/Database/QueryResult.h:73: error: 'st' was not dec lared in this scope
In file included from /root/trinitycore2/src/game/GridNotifiers.h:25,
/root/trinitycore2/src/shared/ByteBuffer.h: In member function 'T ByteBuffer::re ad(size_t) const':
/root/trinitycore2/src/shared/ByteBuffer.h:253: error: 'ACE_Stack_Trace' was not declared in this scope
/root/trinitycore2/src/shared/ByteBuffer.h:253: error: expected `;' before 'st'
/root/trinitycore2/src/shared/ByteBuffer.h:253: error: 'st' was not declared in this scope
/root/trinitycore2/src/shared/ByteBuffer.h: In member function 'void ByteBuffer: :read(uint8*, size_t)':
/root/trinitycore2/src/shared/ByteBuffer.h:261: error: 'ACE_Stack_Trace' was not declared in this scope
/root/trinitycore2/src/shared/ByteBuffer.h:261: error: expected `;' before 'st'
/root/trinitycore2/src/shared/ByteBuffer.h:261: error: 'st' was not declared in this scope
/root/trinitycore2/src/shared/ByteBuffer.h: In member function 'void ByteBuffer: :append(const uint8*, size_t)':
/root/trinitycore2/src/shared/ByteBuffer.h:330: error: 'ACE_Stack_Trace' was not declared in this scope
/root/trinitycore2/src/shared/ByteBuffer.h:330: error: expected `;' before 'st'
/root/trinitycore2/src/shared/ByteBuffer.h:330: error: 'st' was not declared in this scope
/root/trinitycore2/src/shared/ByteBuffer.h: In member function 'void ByteBuffer: :p ut(size_t, const uint8*, size_t)':
/root/trinitycore2/src/shared/ByteBuffer.h:375: error: 'ACE_Stack_Trace' was not declared in this scope
/root/trinitycore2/src/shared/ByteBuffer.h:375: error: expected `;' before 'st'
/root/trinitycore2/src/shared/ByteBuffer.h:375: error: 'st' was not declared in this scope
In file included from /root/trinitycore2/src/game/Corpse.h:24,
from /root/trinitycore2/src/game/GridNotifiers.h:29,
/root/trinitycore2/src/game/Object.h: In member function 'const int32& Object::G etInt32Value(uint16) const':
/root/trinitycore2/src/game/Object.h:178: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:178: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:178: error: 'st' was not declared in this s cope
/root/trinitycore2/src/game/Object.h: In member function 'const uint32& Object:: GetUInt32Value(uint16) const':
/root/trinitycore2/src/game/Object.h:184: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:184: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:184: error: 'st' was not declared in this s cope
/root/trinitycore2/src/game/Object.h: In member function 'const uint64& Object:: GetUInt64Value(uint16) const':
/root/trinitycore2/src/game/Object.h:190: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:190: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:190: error: 'st' was not declared in this s cope
/root/trinitycore2/src/game/Object.h: In member function 'const float& Object::G etFloatValue(uint16) const':
/root/trinitycore2/src/game/Object.h:196: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:196: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:196: error: 'st' was not declared in this s cope
/root/trinitycore2/src/game/Object.h: In member function 'uint8 Object::GetByteV alue(uint16, uint8) const':
/root/trinitycore2/src/game/Object.h:202: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:202: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:202: error: 'st' was not declared in this s cope
/root/trinitycore2/src/game/Object.h:203: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:203: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:203: error: 'st' was not declared in this s cope
/root/trinitycore2/src/game/Object.h: In member function 'uint16 Object::GetUInt 16Value(uint16, uint8) const':
/root/trinitycore2/src/game/Object.h:209: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:209: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:209: error: 'st' was not declared in this s cope
/root/trinitycore2/src/game/Object.h:210: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:210: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:210: error: 'st' was not declared in this s cope
/root/trinitycore2/src/game/Object.h: In member function 'bool Object::HasFlag(u int16, uint32) const':
/root/trinitycore2/src/game/Object.h:252: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:252: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:252: error: 'st' was not declared in this s cope
/root/trinitycore2/src/game/Object.h: In member function 'bool Object::HasByteFl ag(uint16, uint8, uint8) const':
/root/trinitycore2/src/game/Object.h:269: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:269: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:269: error: 'st' was not declared in this s cope
/root/trinitycore2/src/game/Object.h:270: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:270: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:270: error: 'st' was not declared in this s cope
/root/trinitycore2/src/game/Object.h: In member function 'bool Object::HasFlag64 (uint16, uint64) const':
/root/trinitycore2/src/game/Object.h:303: error: 'ACE_Stack_Trace' was not decla red in this scope
/root/trinitycore2/src/game/Object.h:303: error: expected `;' before 'st'
/root/trinitycore2/src/game/Object.h:303: error: 'st' was not declared in this s cope
In file included from /root/trinitycore2/src/game/Creature.h:26,
from /root/trinitycore2/src/game/TemporarySummon.h:24,
from /root/trinitycore2/src/game/Pet.h:26,
from /root/trinitycore2/src/game/Player.h:35,
from /root/trinitycore2/src/game/GridNotifiers.h:33,
/root/trinitycore2/src/game/UpdateMask.h: In member function 'void UpdateMask: :o perator&=(const UpdateMask&)':
/root/trinitycore2/src/game/UpdateMask.h:87: error: 'ACE_Stack_Trace' was not de clared in this scope
/root/trinitycore2/src/game/UpdateMask.h:87: error: expected `;' before 'st'
/root/trinitycore2/src/game/UpdateMask.h:87: error: 'st' was not declared in thi s scope
/root/trinitycore2/src/game/UpdateMask.h: In member function 'void UpdateMask: :o perator|=(const UpdateMask&)':
/root/trinitycore2/src/game/UpdateMask.h:94: error: 'ACE_Stack_Trace' was not de clared in this scope
/root/trinitycore2/src/game/UpdateMask.h:94: error: expected `;' before 'st'
/root/trinitycore2/src/game/UpdateMask.h:94: error: 'st' was not declared in thi s scope
/root/trinitycore2/src/game/UpdateMask.h: In member function 'UpdateMask UpdateM ask: :o perator&(const UpdateMask&) const':
/root/trinitycore2/src/game/UpdateMask.h:101: error: 'ACE_Stack_Trace' was not d eclared in this scope
/root/trinitycore2/src/game/UpdateMask.h:101: error: expected `;' before 'st'
/root/trinitycore2/src/game/UpdateMask.h:101: error: 'st' was not declared in th is scope
/root/trinitycore2/src/game/UpdateMask.h: In member function 'UpdateMask UpdateM ask: :o perator|(const UpdateMask&) const':
/root/trinitycore2/src/game/UpdateMask.h:112: error: 'ACE_Stack_Trace' was not d eclared in this scope
/root/trinitycore2/src/game/UpdateMask.h:112: error: expected `;' before 'st'
/root/trinitycore2/src/game/UpdateMask.h:112: error: 'st' was not declared in th is scope
In file included from /root/trinitycore2/src/game/GridNotifiers.h:33,
/root/trinitycore2/src/game/Player.h: In member function 'void Player::AddMItem( Item*)':
/root/trinitycore2/src/game/Player.h:1373: error: 'ACE_Stack_Trace' was not decl ared in this scope
/root/trinitycore2/src/game/Player.h:1373: error: expected `;' before 'st'
/root/trinitycore2/src/game/Player.h:1373: error: 'st' was not declared in this scope
make[2]: *** [src/bindings/scripts/CMakeFiles/trinityscript.dir/ScriptMgr.cpp.o] Błąd 1
make[1]: *** [src/bindings/scripts/CMakeFiles/trinityscript.dir/all] Błąd 2
