apt-get install amavisd-new
Reading package lists... Done
Building dependency tree
Suggested packages:
lha unrar cabextract dspam libmail-dkim-perl
The following NEW packages will be installed:
amavisd-new
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0B/830kB of archives.
After this operation, 2257kB of additional disk space will be used.
Preconfiguring packages ...
Selecting previously deselected package amavisd-new.
(Reading database ... 44498 files and directories currently installed.)
Unpacking amavisd-new (from .../amavisd-new_1%3a2.6.1.dfsg-1_all.deb) ...
Processing triggers for man-db ...
Setting up amavisd-new (1:2.6.1.dfsg-1) ...
Creating/updating amavis user account...
Broken amavis system user found. To insure data-safety,
it is up to you the local administrator to remove the broken
amavis user, or repair it so that it is sane
dpkg: error processing amavisd-new (--configure):
subprocess post-installation script returned error exit status 1
Errors were encountered while processing:
amavisd-new
passwdKod: Zaznacz cały
passwd: pam_start() failed, error 2
