Nie można wysłać wiadomości, ponieważ jeden z odbiorców został odrzucony przez serwer. Odrzucony adres e-mail to: ,,lordzio000@o2.pl''. Temat 'asd', Konto: 'servnet-ts.pl', Serwer: 'servnet-ts.pl', Protokół: SMTP, Odpowiedź serwera: '550 5.1.1 <lordzio000@o2.pl>: Recipient address rejected: User unknown in local recipient table', Port: 25, Zabezpieczenie (SSL): Nie, Błąd serwera: 550, Numer błędu: 0x800CCC79Kod: Zaznacz cały
command_directory = /usr/sbin
mail_owner = postfix
mydomain = servnet-ts.pl
myhostname = d122.prociv.com
myorigin = /etc/mailname
mydestination = $myhostname, $mydomain, lemon.webcitron.pl, localhost.webcitron.pl, localhost, logi.pl, wp.pl, prokonto.pl, tlen.pl, o2.pl, gmail.com, go2.pl
mynetworks_style = subnet
message_size_limit = 102400000
mynetworks = 127.0.0.0/8, 192.168.0.0/24, 172.16.0.0/12
inet_interfaces = all
inet_protocols = ipv4
home_mailbox = Maildir/
mail_spool_directory = /home/
smtpd_banner = ESMTP on $myhostname !
mailbox_size_limit = 0
recipient_delimiter = +
biff = no
append_dot_mydomain = no
relayhost =
#AUTH SMTP
smtpd_sasl_type = dovecot
smtpd_sasl_auth_enable = yes
smtpd_sasl2_auth_enable = yes
smtpd_sasl_security_options = noanonymous
smtpd_sasl_local_domain = $myhostname
#TLS
smtpd_tls_auth_only = yes
smtp_use_tls = yes
smtpd_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_key_file = /etc/postfix/ssl/mail.pem
smtpd_tls_cert_file = /etc/postfix/ssl/mail.pem
smtpd_tls_CAfile = /etc/postfix/ssl/mail.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
tls_random_source = dev:/dev/urandom
dovecot: 2009-06-30 00:07:52 Info: auth(default): new auth connection: pid=4514
Jun 30 00:07:52 d122 postfix/smtpd[4514]: connect from adkc41.neoplus.adsl.tpnet.pl[*.*.*.*]
Jun 30 00:07:52 d122 postfix/smtpd[4514]: NOQUEUE: reject: RCPT from adkc41.neoplus.adsl.tpnet.pl[79.*.*.*]: 550 5.1.1 <lordzio000@o2.pl>: Recipient address rejected: User unknown in local recipient table; from=<lord@servnet-ts.pl> to=<lordzio000@o2.pl> proto=SMTP helo=<lordc1hp0p7wlm>
Jun 30 00:07:52 d122 postfix/smtpd[4514]: disconnect from adkc41.neoplus.adsl.tpnet.pl[79.*.*.*]
dovecot: 2009-06-30 00:07:52 Info: auth(default): client in: AUTH 1 PLAIN service=POP3 lip=94.*.*.* rip=79.*.*.* resp=<hidden>
dovecot: 2009-06-30 00:07:52 Info: auth(default): pam(lord,79.184.236.41): lookup service=dovecot
dovecot: 2009-06-30 00:07:52 Info: auth(default): client out: OK 1 user=lord
dovecot: 2009-06-30 00:07:52 Info: auth(default): master in: REQUEST 14 4494 1
dovecot: 2009-06-30 00:07:52 Info: auth(default): passwd(lord,79.*.*.*): lookup
dovecot: 2009-06-30 00:07:52 Info: auth(default): master out: USER 14 lord system_user=lord uid=1001 gid=1001 home=/home/lord
dovecot: 2009-06-30 00:07:52 Info: pop3-login: Login: user=<lord>, method=PLAIN, rip=79.184.236.41, lip=94.40.59.16
dovecot: 2009-06-30 00:07:53 Info: POP3(lord): Disconnected: Logged out top=0/0, retr=1/1539, del=1/1, size=1522
dovecot: 2009-06-30 00:07:53 Info: auth(default): new auth connection: pid=4520Proszę o pomoc, walczę z tym już jakieś 4dni i bez skutku. „lordzio000@o2.pl”
