Co jaki
prot
Co jakiś czas przestaje działać poprawnie routing?
Post autor: prot »
Mam problem tego typu iż pada mi routing co jakiś czas.
Log błędu wygląda tak.:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@host-xxx-xxx-xxx-xxx :~#
Message from syslogd@host-xxx-xxx-xxx-xxx  at Sun Jun 21 17:43:25 2009 ...
host-xxx-xxx-xxx-xxx  kernel: Oops: 0000 [#1]
host-xxx-xxx-xxx-xxx  kernel: CPU:    0
host-xxx-xxx-xxx-xxx  kernel: EIP:    0060:[<c065147d>]    Not tainted VLI
host-xxx-xxx-xxx-xxx  kernel: EFLAGS: 00010286   (2.6.22.12-net_system #1)
host-xxx-xxx-xxx-xxx  kernel: EIP is at __ip_route_output_key+0x20d/0x890
host-xxx-xxx-xxx-xxx  kernel: eax: 80000000   ebx: 00000000   ecx: 00000000   edx:                                              000000e0
host-xxx-xxx-xxx-xxx  kernel: esi: f7049e5c   edi: a0b317ec   ebp: f7049d64   esp:                                              f7049d44
host-xxx-xxx-xxx-xxx  kernel: ds: 007b   es: 007b   fs: 0000  gs: 0033  ss: 0068
host-xxx-xxx-xxx-xxx  kernel: Process squid (pid: 4741, ti=f7048000 task=f7d32a70 t                                             ask.ti=f7048000)
host-xxx-xxx-xxx-xxx  kernel: Stack: fffef6ad f7049e98 00000000 00650dee 00000001 0                                             000a728 f7926000 00000000
host-xxx-xxx-xxx-xxx  kernel:        00000000 00000001 00000000 a0b317ec 2a9fc35b 0                                             0000000 00000000 00000000
host-xxx-xxx-xxx-xxx  kernel:        00000000 00000000 00000000 00000000 00000000 0                                             0000000 00000000 2a05c35b
host-xxx-xxx-xxx-xxx  kernel: Call Trace:
host-xxx-xxx-xxx-xxx  kernel:  [<c0651b1e>] ip_route_output_flow+0x1e/0x250
host-xxx-xxx-xxx-xxx  kernel:  [<c0670230>] tcp_v4_connect+0x150/0x640
host-xxx-xxx-xxx-xxx  kernel:  [<c0125200>] autoremove_wake_function+0x0/0x50
host-xxx-xxx-xxx-xxx  kernel:  [<c067d608>] inet_stream_connect+0x1e8/0x270
host-xxx-xxx-xxx-xxx  kernel:  [<c062d735>] sys_recvfrom+0x125/0x180
Message from syslogd@host-v at Sun Jun 21 17:43:25 2009 ...
host-xxx-xxx-xxx-xxx  kernel:  [<c062c1e5>] sys_connect+0xd5/0xf0
Message from syslogd@host-xxx-xxx-xxx-xxx 2 at Sun Jun 21 17:43:25 2009 ...
host-xxx-xxx-xxx-xxx  kernel:  [<c062dc28>] sys_socketcall+0x98/0x280
host-xxx-xxx-xxx-xxx  kernel:  [<c01027c2>] sysenter_past_esp+0x5f/0x85
host-xxx-xxx-xxx-xxx  kernel:  =======================
host-xxx-xxx-xxx-xxx  kernel: Code: 00 00 81 fa e0 00 00 00 0f 84 03 04 00 00 81 fa                                              f0 00 00 00 0f 84 57 02 00 00 84 c0 0f 84 4f 02 00 00 8b 44 24 08 0d 00 00 00 8                                             0 <f6> 83 b8 00 00 00 08 0f 44 44 24 08 89 44 24 08 8b ab 08 01 00
host-xxx-xxx-xxx-xxx  kernel: EIP: [<c065147d>] __ip_route_output_key+0x20d/0x890 S                                             S:ESP 0068:f7049d44
Ktoś wie jaka możne być przyczyna takiego stanu rzeczy?
Dodam jeszcze iż wszystkie aplikacje działają prócz www wydaje mi się ze błąd jest spowodowany błędem powodowanym przez squida.
killanonimx
Post autor: killanonimx »
To chyba są błędy z kernela, a dokładniej modułu odpowiedzialnego za tcp/ip.
Jakiś pakiet się trafia, no i siada.
[ Dodano: 2009-06-21, 22:21 ]
A może to jednak squid
