# package.
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "aticonfig-Screen[0]" 0 0
EndSection
Section "Files"
# path to defoma fonts
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Protocol" "ImPS/2"
EndSection
Section "Monitor"
Identifier "SyncMaster"
Option "DPMS"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "Generic Video Card"
Driver "vesa"
BusID "PCI:1:0:0"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]"
Driver "fglrx"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Generic Video Card"
Monitor "SyncMaster"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]"
Device "aticonfig-Device[0]"
Monitor "aticonfig-Monitor[0]"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
Ati i xorg.conf
Ati i xorg.conf
Zainstalowałem sterowniki ze strony ATI według TEGO.Przy uruchamianiu komputer się zatrzymuje. Czarny ekran. Mam Ati x1950xtx. Wie może ktoś co może być tego przyczyną. Mój xorg wyglada tak:
zamiastSemerchet pisze:Niestety nie pomogło. Czy jak wywalę
Section "Device"
Driver "vesa"
BusID "PCI:1:0:0"
EndSection
to tu też muszą zajść jakieś zmiany
Section "Screen"
Device "Generic Video Card"Kod: Zaznacz cały
Device "aticonfig-Device[0]"i wszedzie gdzie masz Device "Generic Video Card" zmień na Device "aticonfig-Device[0]"
Semerchet, albo po prostu przekonfiguruj xorga, tak jak masz tutaj opisane:
http://www.debian.linux.pl/viewtopic.php?t=492
a sterowniki spróbuj zainstalować według tego:
http://www.debian.linux.pl/viewtopic.php?t=952
aloha
aloha
Korzystałem z tego podczas instalacji. Zainstalowałęm stery. Niestety nie chce się uruchomić. Xorg też konfigurowałem. Też lipa. Uruchamia się system czarny ekran i stop. Nie chcę rąk rozkładać w bezradności. Poszukam rozwiazania. Jak znajdę dam znać. W repo stery ati do jakiej serii są??
[ Dodano: 2007-04-14, 23:59 ]
Problem rozwiązany. Brakowało libstdc++5. Po zainstalowaniu i małej korekcie Xorg.conf akceleracja działa:
glxgears -printfps
55406 frames in 5.0 seconds = 11081.147 FPS
55638 frames in 5.0 seconds = 11127.456 FPS
55486 frames in 5.0 seconds = 11097.153 FPS
55389 frames in 5.0 seconds = 11077.733 FPS
55655 frames in 5.0 seconds = 11130.868 FPS
Oto mój xorg.conf:
# package.
EndSection
Section "Files"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "ServerFlags"
Option "AIGLX" "off"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Section "Monitor"
Option "DPMS"
EndSection
Section "Monitor"
EndSection
Section "Device"
Driver "fglrx"
EndSection
Section "Screen"
DefaultDepth 24
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Screen"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "0"
EndSection
Dziękuję za pomoc.
glxgears -printfps
Oto mój xorg.conf:
# package.
EndSection
Section "Files"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Section "Monitor"
Option "DPMS"
EndSection
Section "Monitor"
EndSection
Section "Device"
Driver "fglrx"
EndSection
Section "Screen"
DefaultDepth 24
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Screen"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
EndSection
Dziękuję za pomoc.
