Mam pewien drobny problem z xcompmgr. W pliku startup mam taki wiersz:
exec xcompmgr -cCfF -r7 -o.65 -l-10 -t-8 -D7 &Jak pozbyć się tych cieni w conky?
exec xcompmgr -cCfF -r7 -o.65 -l-10 -t-8 -D7 &Kod: Zaznacz cały
arek@debian:~$ cat .conkyrc
# avoid flicker
double_buffer yes
no_buffers yes
#own window to run simultanious 2 or more conkys
own_window yes
own_window_transparent yes
own_window_type override
own_window_hints undecorated,below,,skip_taskbar,
#borders
#draw_borders no
#border_margin 1
#shades
draw_shades no
#draw_graph_borders yes
#draw_borders yes
#position
gap_x 815
gap_y 38
maximum_width 200
# X font when Xft is disabled, you can pick one with program xfontsel
#font -*-*-*-r-normal--14-*-*-*-c-*-iso8859-2
font -xos4-terminus-*-r-normal-*-12-100-*-*-c-*-iso10646-1
# Use Xft?
use_xft yes
#xftfont snap:size=8
xftfont Terminus:encoding=utf-8:size=9
xftalpha 0.9
update_interval 1
total_run_times 0
default_color white
default_shade_color black
default_outline_color white
alignment top_left
uppercase no
cpu_avg_samples 2
net_avg_samples 2
override_utf8_locale yes
use_spacer yes
background yes
use_xft yes
# default font
#font -*-*-*-*-*-*-11-*-*-*-*-*-*-*
# xft font when Xft is enabled
xftfont Terminus:size=11
#xftfont aqui
# Text alpha when using Xft
xftalpha 0.8
update_interval 1
#own_window yes
own_window_type normal
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
maximum_width 250
minimum_size 250
draw_shades no
draw_outline no
draw_borders no
#stippled_borders 8
#border_margin 4
#border_width 1
default_color green
default_outline_color green
#alignment top_left
alignment top_right
#alignment bottom_left
#alignment bottom_right
gap_x 10
gap_y 10
#no_buffers yes
uppercase no
double_buffer yes
