lspci | grep Audio
00:07.0 Audio device: nVidia Corporation MCP67 High Definition Audio (rev a1)
lspci -n i oznaczenie karty dźwiękowej
00:07.0 0403: 10de:055c (rev a1)
cat /proc/asound/pcm
00-00: CONEXANT Analog : CONEXANT Analog : playback 1 : capture 1
00-01: Conexant Digital : Conexant Digital : playback 1Kod: Zaznacz cały
cat /proc/asound/cards
0 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xf2580000 irq 21Kod: Zaznacz cały
cat /proc/asound/modules
0 snd_hda_intelKod: Zaznacz cały
dpkg -l | grep alsa
ii alsa-base 1.0.20+dfsg-1 ALSA driver configuration files
ii alsa-firmware-loaders 1.0.19-1 ALSA software loaders for specific hardware
ii alsa-modules-2.6.26-1-686 1.0.19.dfsg-3+2.6.26-13lenny2 ALSA modules for kernel 2.6.26-1-686
ii alsa-oss 1.0.17-1 ALSA wrapper for OSS applications
ii alsa-source 1.0.20+dfsg-1 ALSA driver sources
ii alsa-tools 1.0.19-1 Console based ALSA utilities for specific ha
ii alsa-tools-gui 1.0.19-1 GUI based ALSA utilities for specific hardwa
ii alsa-utils 1.0.19-2 ALSA utilities
ii alsaplayer-alsa 0.99.80-3 PCM player designed for ALSA (ALSA output mo
ii alsaplayer-common 0.99.80-3 PCM player designed for ALSA (common files)
ii alsaplayer-gtk 0.99.80-3 PCM player designed for ALSA (GTK version)
ii libsdl1.2debian-alsa 1.2.13-4+b1 Simple DirectMedia Layer (with X11 and ALSA
ii libwine-alsa 1.0.1-1 Windows API implementation - ALSA sound moduKod: Zaznacz cały
dpkg -l | grep pulse
ii libpulse0 0.9.15-2 PulseAudio client librariesKod: Zaznacz cały
speaker-test
speaker-test 1.0.19
Playback device is default
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
ALSA lib pcm_dmix.c:1008 :( snd_pcm_dmix_open) unable to open slave
Playback open error: -16,Urządzenie lub zasoby zajęteUżywam:
cat /etc/debian_version
squeeze/sid
