Robiłem wiele rzeczy, nadawałem prawa, dopisywałem key.conf i dalej nie wiem o co chodzi.
rndc: connect failed: 127.0.0.1#953: connection refusedKod: Zaznacz cały
// This is the primary configuration file for the BIND DNS server named.
// Please read /usr/share/doc/bind9/README.Debian.gz for information on the
// structure of BIND configuration files in Debian, *BEFORE* you customize
// this configuration file.
// If you are just adding zones, please do that in /etc/bind/named.conf.local
include "/etc/bind/named.conf.options";
// prime the server with knowledge of the root servers
zone "." {
type hint;
file "/etc/bind/db.root";
// be authoritative for the localhost forward and reverse zones, and for
// broadcast zones as per RFC 1912
zone "cypdomena.no-ip.pl" IN {
type master;
file "/var/cache/bind/cypdomena.no-ip.pl";
allow-update { none; };
allow-transfer { none; };
notify yes;
zone "localhost" {
type master;
file "/etc/bind/db.local";
zone "127.in-addr.arpa" {
type master;
file "/etc/bind/db.127";
zone "0.in-addr.arpa" {
type master;
file "/etc/bind/db.0";
zone "255.in-addr.arpa" {
type master;
file "/etc/bind/db.255";
options {
pid-file "/var/run/named/named.pid";
key "rndc-key" {
algorithm hmac-md5
secret "YJ0ugrZPC9Gbm36PneKcSw==";
controls {
inet 127.0.0.1 port 953
allow { 127.0.0.1; } keys { "rndc-key"; };
include "/etc/bind/named.conf.local";
