Otwieranie nowych okien programów w lewym górnym rogu
shevchenko1987
Post autor: shevchenko1987 »
Witam, mam pytanie, czy da się zmienić domyślne otwieranie okien/programów w Gnome by nie otwierały się w lewym górnym rogu tylko na środku pulpitu?
sigo
Post autor: sigo »
Nie wiem czy będzie to możliwe.
Przeszukałeś
gconf-editor
Lepiej było by chyba poszukać (jeżeli używasz) jakiegoś pluginu do compiza, beryla lub compiz fusiona.
shevchenko1987
Przeszukałem. Nic niestety nie udało mi się znaleźć. :-/ Wiem właśnie że w Compizie jest ustawianie tego typu rzeczy, ale nie chce tych bajerów, więc chyba będę musiał obyć się bez tego. :-/
lis6502
Post autor: lis6502 »
[quote="http://chad.glendenin.com/metacity/patch.html]This patch for Metacity adds a few window-placement options that can be configured in the graphical gconf-editor or with the gconftool-2 command-line program.
The following options are available:
"first_fit" ("smart" is also accepted)
This is the default Metacity window-placement behavior. In this mode, Metacity will attempt to tile new windows on the screen so that they do not overlap.
"cascade"
This skips Metacity's center/tile behavior and cascades new windows the upper-left corner of the current desktop. It uses Metacity's built-in cascading algorithm (which I find to be incredibly irritating). In my copious free time, I plan to fix the cascade mode so that the windows don't overlap as much and so that they start cascading from a position away from the upper-left corner (so desktop icons are not immediately covered by windows). If I can find a multi-screen system for testing, I may also fix it so that each screen keeps tracks of its own cascading.
"center"
This option will cause Metacity to place each new window at the center of its workspace.
"origin"
In this mode, Metacity will simply place each new window at the origin (the upper-left corner) of its workspace.
"random"
In this mode, Metacity will choose a random position on the screen for a new window. [/quote] Mowa tam jak mniemam o jakimś starszym Metacity, ale nawet jeśli i te sposoby zawiodą, zawsze możesz skorzystać z jakiegoś innego menedżera okien. Przykładowo ja pod kde mam Openboksa.
