Nic. Natomiast sam dmesg wyświetla tyle
name_len=206
EXT3-fs error (device sdc1): htree_dirblock_to_tree: bad entry in directory #2: rec_len % 4 != 0 - offset=28672, inode=1845440245, rec_len=15321, name_len=8
attempt to access beyond end of device
sdc1: rw=32, want=25220298192, limit=1250258624
EXT3-fs error (device sdc1): htree_dirblock_to_tree: bad entry in directory #249 52833: rec_len % 4 != 0 - offset=0, inode=2581325133, rec_len=49878, name_len=22 8
EXT3-fs error (device sdc1): htree_dirblock_to_tree: bad entry in directory #266 73153: directory entry across blocks - offset=0, inode=1871159428, rec_len=14048 , name_len=72
EXT3-fs error (device sdc1): htree_dirblock_to_tree: bad entry in directory #120 42256: inode out of bounds - offset=0, inode=3464505254, rec_len=160, name_len=0
EXT3-fs error (device sdc1): htree_dirblock_to_tree: bad entry in directory #266 73321: rec_len % 4 != 0 - offset=0, inode=125070398, rec_len=33341, name_len=48
EXT3-fs error (device sdc1): htree_dirblock_to_tree: bad entry in directory #266 73193: directory entry across blocks - offset=0, inode=3518006053, rec_len=7200, name_len=22
EXT3-fs error (device sdc1): htree_dirblock_to_tree: bad entry in directory #266 81466: rec_len % 4 != 0 - offset=0, inode=2150810660, rec_len=162, name_len=66
EXT3-fs error (device sdc1): htree_dirblock_to_tree: bad entry in directory #266 73430: directory entry across blocks - offset=0, inode=209990245, rec_len=62052, name_len=206
kjournald starting. Commit interval 5 seconds
EXT3 FS on sdd1, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
EXT3-fs error (device sdc1): ext3_dx_find_entry: bad entry in directory #2: rec_ len % 4 != 0 - offset=28672, inode=1845440245, rec_len=15321, name_len=8
sdc1: rw=32, want=8173430568, limit=1250258624
EXT3-fs error (device sdc1): ext3_find_entry: reading directory #2 offset 12
EXT3-fs error (device sdc1): ext3_find_entry: reading directory #2 offset 13
