Zamarzyło mi się zainstalować sterowniki ati - szczęśliwie się to udało (ale prawdopodobnie nie do końca):
glxinfowyrzuca następujacy komunikat:
X Error of failed request: BadRequest (invalid request code or no such operation)
Major opcode of failed request: 163 (GLX)
Minor opcode of failed request: 19 (X_GLXQueryServerString)
Serial number of failed request: 15
Current serial number in output stream: 15Kod: Zaznacz cały
X.Org X Server 1.4.2
Release Date: 11 June 2008
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10.lenny1)
Current Operating System: Linux debian 2.6.26-2-amd64 #1 SMP Fri Mar 27 04:02:59 UTC 2009 x86_64
Build Date: 09 March 2009 09:53:09AM
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Apr 20 10:48:53 2009
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "VT788"
(**) | |-->Device "ATI Technologies Inc ATI Default Card"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist.
(==) Including the default font path /usr/share/fonts/X11/misc,/usr/share/fonts/X11/cyrillic,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType.
(**) FontPath set to:
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
(==) RgbPath set to "/etc/X11/rgb"
(**) Extension "Composite" is disabled
(II) Loader magic: 0x7c28e0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 2.0
X.Org XInput driver : 2.0
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
compiled for 1.4.2, module version = 1.0.0
ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: 00:00:0: chip 1002,5958 card 1002,5958 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:02:0: chip 1002,5978 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:0a:0: chip 1002,597f card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:12:0: chip 1002,4380 card 1458,b002 rev 00 class 01,06,01 hdr 00
(II) PCI: 00:13:0: chip 1002,4387 card 1458,5004 rev 00 class 0c,03,10 hdr 80
(II) PCI: 00:13:1: chip 1002,4388 card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:2: chip 1002,4389 card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:3: chip 1002,438a card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:4: chip 1002,438b card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:5: chip 1002,4386 card 1458,5004 rev 00 class 0c,03,20 hdr 00
(II) PCI: 00:14:0: chip 1002,4385 card 1458,4385 rev 14 class 0c,05,00 hdr 80
(II) PCI: 00:14:1: chip 1002,438c card 1458,5002 rev 00 class 01,01,8a hdr 00
(II) PCI: 00:14:2: chip 1002,4383 card 1458,a002 rev 00 class 04,03,00 hdr 00
(II) PCI: 00:14:3: chip 1002,438d card 1458,5001 rev 00 class 06,01,00 hdr 80
(II) PCI: 00:14:4: chip 1002,4384 card 0000,0000 rev 00 class 06,04,01 hdr 81
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 1002,9442 card 0000,0000 rev 00 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,aa30 card 0000,aa30 rev 00 class 04,03,00 hdr 80
(II) PCI: 02:00:0: chip 10ec,8168 card 1458,e000 rev 01 class 02,00,00 hdr 00
(II) PCI: 03:0e:0: chip 104c,8024 card 1458,1000 rev 00 class 0c,00,10 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,3), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00000000 - 0xffffffff (0x100000000) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:2:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xfde00000 - 0xfdefffff (0x100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
(II) Bus 2: bridge is at (0:10:0), (0,2,2), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000e000 - 0x0000efff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfdd00000 - 0xfddfffff (0x100000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xfdf00000 - 0xfdffffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:20:3), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 3: bridge is at (0:20:4), (0,3,3), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 3 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 3 non-prefetchable memory range:
[0] -1 0 0xfdc00000 - 0xfdcfffff (0x100000) MX[B]
(II) Bus 3 prefetchable memory range:
[0] -1 0 0xfdb00000 - 0xfdbfffff (0x100000) MX[B]
(--) PCI:*(1:0:0) ATI Technologies Inc unknown chipset (0x9442) rev 0, Mem @ 0xd0000000/28, 0xfdee0000/16, I/O @ 0xde00/8
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xe0000000 to 0xdfffffff
(II) Active PCI resource ranges:
[0] -1 0 0xfdcf8000 - 0xfdcfbfff (0x4000) MX[B]
[1] -1 0 0xfdcff000 - 0xfdcff7ff (0x800) MX[B]
[2] -1 0 0xfddff000 - 0xfddfffff (0x1000) MX[B]
[3] -1 0 0xfdefc000 - 0xfdefffff (0x4000) MX[B]
[4] -1 0 0xfe024000 - 0xfe027fff (0x4000) MX[B]
[5] -1 0 0xfe029000 - 0xfe0290ff (0x100) MX[B]
[6] -1 0 0xfe02a000 - 0xfe02afff (0x1000) MX[B]
[7] -1 0 0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
[8] -1 0 0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
[9] -1 0 0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
[10] -1 0 0xfe02e000 - 0xfe02efff (0x1000) MX[B]
[11] -1 0 0xfe02f000 - 0xfe02f3ff (0x400) MX[B]
[12] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[13] -1 0 0xfdee0000 - 0xfdeeffff (0x10000) MX[B](B)
[14] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[15] -1 0 0x0000ee00 - 0x0000eeff (0x100) IX[B]
[16] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[17] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[18] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[19] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[20] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[21] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[22] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[23] -1 0 0x0000fc00 - 0x0000fc03 (0x4) IX[B]
[24] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[25] -1 0 0x0000fe00 - 0x0000fe03 (0x4) IX[B]
[26] -1 0 0x0000ff00 - 0x0000ff07 (0x8) IX[B]
[27] -1 0 0x0000de00 - 0x0000deff (0x100) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xfdcf8000 - 0xfdcfbfff (0x4000) MX[B]
[5] -1 0 0xfdcff000 - 0xfdcff7ff (0x800) MX[B]
[6] -1 0 0xfddff000 - 0xfddfffff (0x1000) MX[B]
[7] -1 0 0xfdefc000 - 0xfdefffff (0x4000) MX[B]
[8] -1 0 0xfe024000 - 0xfe027fff (0x4000) MX[B]
[9] -1 0 0xfe029000 - 0xfe0290ff (0x100) MX[B]
[10] -1 0 0xfe02a000 - 0xfe02afff (0x1000) MX[B]
[11] -1 0 0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
[12] -1 0 0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
[13] -1 0 0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
[14] -1 0 0xfe02e000 - 0xfe02efff (0x1000) MX[B]
[15] -1 0 0xfe02f000 - 0xfe02f3ff (0x400) MX[B]
[16] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[17] -1 0 0xfdee0000 - 0xfdeeffff (0x10000) MX[B](B)
[18] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x0000ee00 - 0x0000eeff (0x100) IX[B]
[22] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[23] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[24] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[25] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[26] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[27] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[28] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[29] -1 0 0x0000fc00 - 0x0000fc03 (0x4) IX[B]
[30] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[31] -1 0 0x0000fe00 - 0x0000fe03 (0x4) IX[B]
[32] -1 0 0x0000ff00 - 0x0000ff07 (0x8) IX[B]
[33] -1 0 0x0000de00 - 0x0000deff (0x100) IX[B](B)
(II) "extmod" will be loaded by default.
(II) "dbe" will be loaded by default.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "freetype" will be loaded by default.
(II) "record" will be loaded by default.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
compiled for 7.1.0, module version = 1.0.0
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Loading extension GLX
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
compiled for 1.4.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "fglrx"
(II) Loading /usr/lib/xorg/modules/drivers//fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.1.0, module version = 8.56.4
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
compiled for 1.4.0.90, module version = 1.3.1
ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
compiled for 1.4.0.90, module version = 1.3.0
(II) Primary Device is: PCI 01:00:0
(II) ATI Proprietary Linux Driver Version Identifier:8.56.4
(II) ATI Proprietary Linux Driver Release Identifier: 8.561
(II) ATI Proprietary Linux Driver Build Date: Dec 1 2008 14:56:32
(--) Chipset Supported AMD Graphics Processor (0x9442) found
(II) AMD Video driver is running on the exact device targeted for this release
(II) AMD Video driver is signed
(II) resource ranges after xf86ClaimFixedResources() call:
(II) fglrx(0): pEnt->device->identifier=0x13b4830
(II) resource ranges after probing:
[19] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[20] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[21] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[22] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[23] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[24] -1 0 0x0000ee00 - 0x0000eeff (0x100) IX[B]
[25] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[26] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[27] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[28] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[29] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[30] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[31] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[32] -1 0 0x0000fc00 - 0x0000fc03 (0x4) IX[B]
[33] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[34] -1 0 0x0000fe00 - 0x0000fe03 (0x4) IX[B]
[35] -1 0 0x0000ff00 - 0x0000ff07 (0x8) IX[B]
[36] -1 0 0x0000de00 - 0x0000deff (0x100) IX[B](B)
[37] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[38] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) fglrx(0): === [atiddxPreInit] === begin
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 0.1.0
(II) fglrx(0): PCI bus 1 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "DPMS"
(II) fglrx(0): Loading PCS database from /etc/ati/amdpcsdb
(II) fglrx(0): 10BitPixelFormat disabled by default
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(==) fglrx(0): Gamma Correction for I is 0x06419064
(==) fglrx(0): Gamma Correction for II is 0x06419064
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/lib/xorg/modules/linux//libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(--) fglrx(0): Chipset: "ATI Radeon HD 4800 Series" (Chipset = 0x9442)
(--) fglrx(0): (PciSubVendor = 0x0000, PciSubDevice = 0x0000)
(--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xd0000000
(--) fglrx(0): MMIO registers at 0xfdee0000
(--) fglrx(0): I/O port at 0x0000de00
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.1.0
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 3.0
(II) fglrx(0): VESA VBE Total Mem: 16384 kB
(II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
(II) fglrx(0): VESA VBE OEM Software Rev: 11.8
(II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: 2P
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
(II) fglrx(0): ATI Video BIOS revision 9 or later detected
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 8, (OK)
drmOpenByBusid: Searching for BusID PCI:1:0:0
drmOpenByBusid: drmOpenMinor returns 8
drmOpenByBusid: drmGetBusid reports PCI:1:0:0
(II) fglrx(0): Using adapter: 1:0.0.
(II) fglrx(0): [FB] MC range(MCFBBase = 0xf00000000, MCFBSize = 0x20000000)
(--) fglrx(0): Video RAM: 524288 kByte, Type: GDDR3
(II) fglrx(0): PCIE card detected
(--) fglrx(0): Using per-process page tables (PPPT) as GART.
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module "ddc" already built-in
(II) fglrx(0): ***Display: ConnectedDisplayTypes=0x00000001, disabled=0x00000000
(II) fglrx(0): Connected Display1: CRT on primary DAC [crt1]
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: VIT Model: 314 Serial#: 1
(II) fglrx(0): Year: 2004 Week: 10
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
(II) fglrx(0): Sync:
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 34 vert.: 27
(II) fglrx(0): Gamma: 1.00
(II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.625 redY: 0.340 greenX: 0.284 greenY: 0.604
(II) fglrx(0): blueX: 0.149 blueY: 0.064 whiteX: 0.280 whiteY: 0.311
(II) fglrx(0): Supported VESA Video Modes:
(II) fglrx(0): 720x400@70Hz
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 640x480@75Hz
(II) fglrx(0): 800x600@60Hz
(II) fglrx(0): 800x600@75Hz
(II) fglrx(0): 1024x768@60Hz
(II) fglrx(0): 1024x768@70Hz
(II) fglrx(0): 1024x768@75Hz
(II) fglrx(0): 1280x1024@75Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported Future Video Modes:
(II) fglrx(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 108.1 MHz Image Size: 338 x 270 mm
(II) fglrx(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
(II) fglrx(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
(II) fglrx(0): Monitor name: VT788
(II) fglrx(0): EDID (in hex):
(II) fglrx(0): 00ffffffffffff005934140301000000
(II) fglrx(0): 0a0e010300221bffea0f6ea057489a26
(II) fglrx(0): 10474fa54f0081800000000000000000
(II) fglrx(0): 0000000000003a2a009851002a403070
(II) fglrx(0): 1300520e1100001e000000fc00565437
(II) fglrx(0): 38380a20202020202020000000000000
(II) fglrx(0): 656e657369730a2020202020000000f9
(II) fglrx(0): 000000000000000000000000000000ae
(II) fglrx(0): End of Display1 EDID data --------------------
(WW) fglrx(0): Only one display is connnected,so single mode is enabled
(II) fglrx(0): Primary Controller - CRT on primary DAC
(II) fglrx(0): Internal Desktop Setting: 0x00000001
(==) fglrx(0): QBS disabled
(==) fglrx(0): FAST_SWAP disabled
(==) fglrx(0): PseudoColor visuals disabled
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(==) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Total of 23 modes found for primary display.
(--) fglrx(0): Virtual size is 1280x1024 (pitch 0)
(**) fglrx(0): *Mode "1280x1024": 108.1 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x1024"x60.0 108.10 1280 1328 1440 1688 1024 1025 1028 1066 (64.0 kHz)
(**) fglrx(0): Default mode "1280x1024": 85.5 MHz (scaled from 0.0 MHz), 50.9 kHz, 47.0 Hz (I)
(II) fglrx(0): Modeline "1280x1024"x47.0 85.51 1280 1344 1480 1680 1024 1025 1028 1083 interlace +hsync (50.9 kHz)
(**) fglrx(0): Default mode "1280x1024": 77.8 MHz (scaled from 0.0 MHz), 46.3 kHz, 43.0 Hz (I)
(II) fglrx(0): Modeline "1280x1024"x43.0 77.80 1280 1344 1480 1680 1024 1025 1028 1077 interlace +hsync (46.3 kHz)
(**) fglrx(0): *Mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 +hsync +vsync (48.4 kHz)
(**) fglrx(0): Default mode "1024x768": 44.9 MHz (scaled from 0.0 MHz), 35.5 kHz, 43.0 Hz (I)
(II) fglrx(0): Modeline "1024x768"x43.0 44.90 1024 1032 1208 1264 768 768 772 817 interlace (35.5 kHz)
(**) fglrx(0): *Mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "800x600"x60.0 40.00 800 840 968 1056 600 601 605 628 (37.9 kHz)
(**) fglrx(0): Default mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.0 Hz
(II) fglrx(0): Modeline "800x600"x56.0 36.00 800 824 896 1024 600 601 603 625 (35.2 kHz)
(**) fglrx(0): Default mode "800x600": 29.6 MHz (scaled from 0.0 MHz), 29.8 kHz, 47.0 Hz (I)
(II) fglrx(0): Modeline "800x600"x47.0 29.60 800 816 896 992 600 601 604 635 interlace +hsync (29.8 kHz)
(**) fglrx(0): *Mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x480"x60.0 25.18 640 656 752 800 480 490 492 525 +hsync +vsync (31.5 kHz)
(**) fglrx(0): Default mode "1280x960": 108.0 MHz (scaled from 0.0 MHz), 60.0 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 (60.0 kHz)
(**) fglrx(0): Default mode "1280x768": 79.5 MHz (scaled from 0.0 MHz), 47.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x768"x60.0 79.50 1280 1344 1472 1664 768 771 778 798 +hsync (47.8 kHz)
(**) fglrx(0): Default mode "1280x720": 74.5 MHz (scaled from 0.0 MHz), 44.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 +hsync (44.8 kHz)
(**) fglrx(0): Default mode "1280x720": 60.5 MHz (scaled from 0.0 MHz), 37.0 kHz, 50.0 Hz
(II) fglrx(0): Modeline "1280x720"x50.0 60.46 1280 1328 1456 1632 720 721 724 741 +hsync (37.0 kHz)
(**) fglrx(0): Default mode "1152x864": 81.6 MHz (scaled from 0.0 MHz), 53.7 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 +hsync (53.7 kHz)
(**) fglrx(0): Default mode "1152x864": 64.7 MHz (scaled from 0.0 MHz), 43.0 kHz, 47.0 Hz (I)
(II) fglrx(0): Modeline "1152x864"x47.0 64.67 1152 1208 1328 1504 864 865 868 915 interlace +hsync (43.0 kHz)
(**) fglrx(0): Default mode "1152x864": 58.3 MHz (scaled from 0.0 MHz), 39.2 kHz, 43.0 Hz (I)
(II) fglrx(0): Modeline "1152x864"x43.0 58.28 1152 1200 1320 1488 864 865 868 911 interlace +hsync (39.2 kHz)
(**) fglrx(0): Default mode "720x576": 26.6 MHz (scaled from 0.0 MHz), 29.6 kHz, 50.0 Hz
(II) fglrx(0): Modeline "720x576"x50.0 26.56 720 736 808 896 576 577 580 593 +hsync (29.6 kHz)
(**) fglrx(0): Default mode "720x480": 26.7 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "720x480"x60.0 26.71 720 736 808 896 480 481 484 497 +hsync (29.8 kHz)
(**) fglrx(0): Default mode "640x400": 24.9 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x400"x60.0 24.92 640 664 760 792 400 460 462 525 (31.5 kHz)
(**) fglrx(0): Default mode "512x384": 19.8 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "512x384"x60.0 19.81 512 544 624 664 384 451 453 497 (29.8 kHz)
(**) fglrx(0): Default mode "400x300": 22.3 MHz (scaled from 0.0 MHz), 45.0 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "400x300"x60.0 22.33 400 416 480 496 300 601 605 742 doublescan (45.0 kHz)
(**) fglrx(0): Default mode "320x240": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "320x240"x60.0 12.59 320 328 376 400 240 491 493 525 doublescan (31.5 kHz)
(**) fglrx(0): Default mode "320x200": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "320x200"x60.0 12.59 320 336 384 400 200 457 459 524 doublescan (31.5 kHz)
(--) fglrx(0): Display dimensions: (340, 270) mm
(--) fglrx(0): DPI set to (95, 96)
(--) fglrx(0): Virtual size is 1280x1024 (pitch 1280)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
ABI class: X.Org ANSI C Emulation, version 0.3
(II) LoadModule: "ramdac"(II) Module "ramdac" already built-in
(==) fglrx(0): NoAccel = NO
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.2.0
(==) fglrx(0): NoDRI = NO
(II) Reloading /usr/lib/xorg/modules/linux//libfglrxdrm.so
(==) fglrx(0): Capabilities: 0x00000000
(==) fglrx(0): CapabilitiesEx: 0x00000000
(==) fglrx(0): cpuFlags: 0x4000001f
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(II) fglrx(0): [pcie] 262144 kB allocated
(II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 65536
(==) fglrx(0): UseFastTLS=0
(==) fglrx(0): BlockSignalsOnLock=1
(II) fglrx(0): Direct rendering enabled
(II) fglrx(0): AC Adapter is used
(II) fglrx(0): Interrupt handler installed at IRQ 18.
(II) fglrx(0): Exposed events to the /proc interface
(II) fglrx(0): Finished Initialize PPLIB!
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xfdee0000 - 0xfdeeffff (0x10000) MX[B]
[1] 0 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
[2] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[3] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[4] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[5] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[6] -1 0 0xfdcf8000 - 0xfdcfbfff (0x4000) MX[B]
[7] -1 0 0xfdcff000 - 0xfdcff7ff (0x800) MX[B]
[8] -1 0 0xfddff000 - 0xfddfffff (0x1000) MX[B]
[9] -1 0 0xfdefc000 - 0xfdefffff (0x4000) MX[B]
[10] -1 0 0xfe024000 - 0xfe027fff (0x4000) MX[B]
[11] -1 0 0xfe029000 - 0xfe0290ff (0x100) MX[B]
[12] -1 0 0xfe02a000 - 0xfe02afff (0x1000) MX[B]
[13] -1 0 0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
[14] -1 0 0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
[15] -1 0 0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
[16] -1 0 0xfe02e000 - 0xfe02efff (0x1000) MX[B]
[17] -1 0 0xfe02f000 - 0xfe02f3ff (0x400) MX[B]
[18] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[19] -1 0 0xfdee0000 - 0xfdeeffff (0x10000) MX[B](B)
[20] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[21] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprU)
[22] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprU)
[23] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprU)
[24] 0 0 0x0000de00 - 0x0000deff (0x100) IX[B]
[25] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[26] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[27] -1 0 0x0000ee00 - 0x0000eeff (0x100) IX[B]
[28] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[29] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[30] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[31] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[32] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[33] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[34] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[35] -1 0 0x0000fc00 - 0x0000fc03 (0x4) IX[B]
[36] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[37] -1 0 0x0000fe00 - 0x0000fe03 (0x4) IX[B]
[38] -1 0 0x0000ff00 - 0x0000ff07 (0x8) IX[B]
[39] -1 0 0x0000de00 - 0x0000deff (0x100) IX[B](B)
[40] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[41] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) fglrx(0): driver needs X.org 7.1.x.y with x.y >= 0.0
(WW) fglrx(0): could not detect X server version (query_status=-1)
(II) Loading extension ATIFGLRXDRI
(II) fglrx(0): doing DRIScreenInit
(II) fglrx(0): DRIScreenInit for fglrx driver
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: drmOpenMinor returns 9
(II) fglrx(0): [drm] DRM interface version 1.0
(II) fglrx(0): [drm] created "fglrx" driver at busid "PCI:1:0:0"
(II) fglrx(0): [drm] added 8192 byte SAREA at 0x2000
(II) fglrx(0): [drm] mapped SAREA 0x2000 to 0x7fa14aaf5000
(II) fglrx(0): [drm] framebuffer handle = 0x3000
(II) fglrx(0): [drm] added 1 reserved context for kernel
(II) fglrx(0): DRIScreenInit done
(II) fglrx(0): Kernel Module Version Information:
(II) fglrx(0): Name: fglrx
(II) fglrx(0): Version: 8.56.4
(II) fglrx(0): Date: Dec 1 2008
(II) fglrx(0): Desc: ATI FireGL DRM kernel module
(II) fglrx(0): Kernel Module version matches driver.
(II) fglrx(0): Kernel Module Build Time Information:
(II) fglrx(0): Build-Kernel UTS_RELEASE: 2.6.26-2-amd64
(II) fglrx(0): Build-Kernel MODVERSIONS: no
(II) fglrx(0): Build-Kernel __SMP__: no
(II) fglrx(0): Build-Kernel PAGE_SIZE: 0x1000
(II) fglrx(0): [drm] register handle = 0x00004000
(II) fglrx(0): DRI initialization successfull!
(II) fglrx(0): FBADPhys: 0xf00000000 FBMappedSize: 0x01040000
(II) fglrx(0): FBMM initialized for area (0,0)-(1280,3328)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1280,1024) (front color buffer - assumption)
(II) fglrx(0): Largest offscreen area available: 1280 x 2304
(==) fglrx(0): Backing store disabled
(II) Loading extension FGLRXEXTENSION
(II) Loading extension ATITVOUT
(**) fglrx(0): DPMS enabled
(**) fglrx(0): Textured Video is enabled.
(II) LoadModule: "glesx"
(II) Loading /usr/lib/xorg/modules//glesx.so
(II) Module glesx: vendor="X.Org Foundation"
(II) Loading extension GLESX
(II) fglrx(0): GLESX enableFlags = 90
(II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
Solid Horizontal and Vertical Lines
Driver provided ScreenToScreenBitBlt replacement
Driver provided FillSolidRects replacement
(II) fglrx(0): GLESX is enabled
(II) LoadModule: "amdxmm"
(II) Loading /usr/lib/xorg/modules//amdxmm.so
(II) Module amdxmm: vendor="X.Org Foundation"
(II) fglrx(0): UVD2 feature is available
(II) fglrx(0): X context handle = 0x1
(II) fglrx(0): [DRI] installation complete
(==) fglrx(0): Silken mouse enabled
(==) fglrx(0): Using hardware cursor
(==) RandR enabled
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension XEVIE
drmOpenDevice: open result is 10, (OK)
drmOpenByBusid: drmOpenMinor returns 10
(EE) AIGLX error: dlopen of fglrx_dri.so failed
(EE) AIGLX: reverting to software rendering
(II) fglrx(0): Enable the clock gating!
(II) fglrx(0): Restoring recent mode: 1280x1024@60Hz
(**) Option "CoreKeyboard"
(**) Generic Keyboard: always reports core events
(**) Option "Protocol" "standard"
(**) Generic Keyboard: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Generic Keyboard: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Generic Keyboard: XkbModel: "pc105"
(**) Option "XkbLayout" "pl"
(**) Generic Keyboard: XkbLayout: "pl"
(**) Option "CustomKeycodes" "off"
(**) Generic Keyboard: CustomKeycodes disabled
(**) Option "Protocol" "ImPS/2"
(**) Configured Mouse: Device: "/dev/input/mice"
(**) Configured Mouse: Protocol: "ImPS/2"
(**) Option "CorePointer"
(**) Configured Mouse: always reports core events
(**) Option "Device" "/dev/input/mice"
(**) Option "Emulate3Buttons" "true"
(**) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
(**) Configured Mouse: ZAxisMapping: buttons 4 and 5
(**) Configured Mouse: Buttons: 9
(**) Configured Mouse: Sensitivity: 1
(II) evaluating device (Generic Keyboard)
(II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
(II) evaluating device (Configured Mouse)
(II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
(II) Configured Mouse: ps2EnableDataReporting: succeeded
Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
