Doszedłem tylko do tego że pokazuje się X na tle i wraca do konsoli oraz pokazuje taki komunikat:
X: warning; process set to priority -1 instead of requested priority 0
X.Org X Server 1.4.2
Release Date: 11 June 2008
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10.lenny1)
Current Operating System: Linux debian 2.6.26-2-686 #1 SMP Thu Mar 26 01:08:11 UTC 2009 i686
Build Date: 15 March 2009 03:18:10PM
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Apr 19 14:47:34 2009
(II) Module "i2c" already built-in
(II) Module "ddc" already built-in
(II) Module "ramdac" already built-in
waiting for X server to shut down FreeFontPath: FPE "/usr/share/fonts/X11/misc" refcount is 2, should be 1; fixing.
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkdRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
Option "XkbOptions" "201"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
Option "UseFBDev"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
RgbPath "/etc/X11/rgb"
ModulePath "/usr/lib/xorg/modules"
EndSection
Section "Module"
Load "glx"
Load "GLcore"
Load "record"
Load "extmod"
Load "dri"
Load "dbe"
Load "xtrap"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
### Available Driver options are:-
### Values: [i]: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
### [arg]: arg optional
#Option "SWcursor" # [<bool>]
#Option "HWcursor" # [<bool>]
#Option "NoAccel" # [<bool>]
#Option "ShadowFB" # [<bool>]
#Option "UseFBDev" # [<bool>]
#Option "Rotate" # [<str>]
#Option "VideoKey" # [i]
#Option "FlatPanel" # [<bool>]
#Option "FPDither" # [<bool>]
#Option "CrtcNumber" # [i]
#Option "FPScale" # [<bool>]
#Option "FPTweak" # [i]
#Option "DualHead" # [<bool>]
Identifier "Card0"
Driver "nv"
VendorName "nVidia Corporation"
BoardName "C51PV [GeForce 6150]"
BusID "PCI:0:5:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
