Mam problem z apt-getem na serwerze produkcyjnym. Mianowicie: Nie daje się zainstalować nic za pomocą apt-get, przykład:
apt-get install libapache-mod-python
Reading package lists... Done
Building dependency tree... Done
Package libapache-mod-python is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package libapache-mod-python has no installation candidate
Zapytałem Google i wyszukałem, żeby pokombinować z flagą ,,-f'' i przykładowo:
apt-get -f install
Correcting dependencies... Done
The following packages will be REMOVED:
amavisd-new apache apache-common build-essential courier-base courier-imap courier-imap-ssl courier-maildrop
courier-pop courier-pop-ssl courier-ssl debhelper defoma dpkg-dev fontconfig-config intltool-debian java-package
libapache-mod-jk libapache-mod-perl libapache-mod-php5 libarchive-tar-perl libarchive-zip-perl libberkeleydb-perl
libcompress-zlib-perl libconvert-binhex-perl libconvert-tnef-perl libconvert-uulib-perl libdbd-mysql-perl libdbi-perl
libdevel-symdump-perl libdigest-hmac-perl libdigest-sha1-perl libfontconfig1 libgd-xpm-dev libgd2-xpm
libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl libio-multiplex-perl libio-stringy-perl libio-zlib-perl
libmailtools-perl libmime-perl libnet-cidr-perl libnet-daemon-perl libnet-dns-perl libnet-ip-perl libnet-server-perl
libplrpc-perl libsocket6-perl libtimedate-perl libunix-syslog-perl liburi-perl libwww-perl libx11-dev libxpm-dev
mysql-client-5.0 mysql-server-5.0 ntp perl perl-modules php-pear php5 php5-cgi php5-cli php5-gd php5-imap php5-mcrypt
php5-mysql po-debconf proftpd razor spamassassin squirrelmail squirrelmail-locales ttf-dejavu
0 upgraded, 0 newly installed, 76 to remove and 0 not upgraded.
3 not fully installed or removed.
Need to get 0B of archives.
After unpacking 209MB disk space will be freed.
Do you want to continue [Y/n]?
Czy można jakoś naprawić apt-get nie kasując potrzebnych pakietów?
