Proszę o pomoc bo już zupełnie nie wiem gdzie jest błąd. Korzystam z Debiana 5 (Lenny) i Binda9. Chcę zainstalować serwer DNS dla sieci lokalnej. Skonfigurowałem wszystko zgodnie z opisami jakie znalazłem przez Google. Problem jest taki, że nie mogę pingować z klienta sieci z Windows XP komputera, na którym znajduje się Debian i Bind. Oto konfiguracja Binda:
Bind9 konfig
NAMED.CONF
// This is the primary configuration file for the BIND DNS server named.
// Please read /usr/share/doc/bind9/README.Debian.gz for information on the
// structure of BIND configuration files in Debian, *BEFORE* you customize
// this configuration file.
// If you are just adding zones, please do that in /etc/bind/named.conf.local
include "/etc/bind/named.conf.options";
// prime the server with knowledge of the root servers
zone "." {
type hint;
file "/etc/bind/db.root";
// be authoritative for the localhost forward and reverse zones, and for
// broadcast zones as per RFC 1912
zone "localhost" {
type master;
file "/etc/bind/db.local";
zone "127.in-addr.arpa" {
type master;
file "/etc/bind/db.127";
zone "0.in-addr.arpa" {
type master;
file "/etc/bind/db.0";
zone "255.in-addr.arpa" {
type master;
file "/etc/bind/db.255";
zone "word25.skierniewice.local" {
type master;
file "/etc/bind/word25.local";
//allow-transfer { xxx.xxx.xxx.xxx; yyy.yyy.yyy.yyy; };
allow-query {"any";};
notify no;
include "/etc/bind/named.conf.local";
NAMED.CONF.OPTIONS
options {
directory "/var/cache/bind";
listen-on { any; };
auth-nxdomain yes;
query-source address * port 53;
transfer-source * port 53;
notify-source * port 53;
forwarders { 194.204.159.1; 194.204.152.34; };
allow-query { any; }
WORD25.LOCAL
$TTL 1D
$ORIGIN word25.local.
@ IN SOA word0002.word25.local. root.word25.local. (
2008040706 ; Serial
10800 ; Refresh
3600 ; Retry
2419200 ; Expire
10800 ) ; NXDOMAIN TTL
@ IN NS word0002.word25.local.
@ IN A 172.16.0.3
word0002 IN A 172.16.0.3
Dig na Debianie
word0002:/etc/bind# dig any word25.local
; <<>> DiG 9.5.1-P1 <<>> any word25.local
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 61112
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 0, ADDITIONAL: 1
;; QUESTION SECTION:
;word25.local. IN ANY
;; ANSWER SECTION:
word25.local. 86400 IN SOA word0002.word25.local. root.word25.local. 2008040706 10800 3600 2419200 10800
word25.local. 86400 IN NS word0002.word25.local.
word25.local. 86400 IN A 172.16.0.3
;; ADDITIONAL SECTION:
word0002.word25.local. 86400 IN A 172.16.0.3
;; Query time: 8 msec
;; SERVER: 172.16.0.3#53(172.16.0.3)
;; WHEN: Fri Apr 17 10:17:40 2009
;; MSG SIZE rcvd: 139
word0002:/home/word# dig @localhost word25.local
; <<>> DiG 9.5.1-P1 <<>> @localhost word25.local
; (2 servers found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 57509
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;word25.local. IN A
;; AUTHORITY SECTION:
. 9642 IN SOA A.ROOT-SERVERS.NET. NSTLD.VERISIGN-GRS.COM. 2009041700 1800 900 604800 86400
;; Query time: 1 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Fri Apr 17 10:19:25 2009
;; MSG SIZE rcvd: 119
Nslookup
KOMPUTER Z BIND9
word0002:/etc/bind# nslookup word0002
Server: 172.16.0.3
Address: 172.16.0.3#53
Address: 172.16.0.3
word0002:/etc/bind# nslookup 172.16.0.3
Server: 172.16.0.3
** server can't find 3.0.16.172.in-addr.arpa.: NXDOMAIN
Wynik jest zrozumiay ze wzgldu na brak zdefiniowanej strefy zwronej
KOMPUTER Z XP
c:\nslookup word0002
*** Nie mozna znalesc nazwy serwera dla adresu 172.16.0.3. Non-existent domian.
*** Domyslne serwery nie sa dostepne.
Serwer: UnKnow
Adres: 172.16.0.3
*** UnKnow nie moze znalesc word0002: Non-existent domian.
Dziękuję za pomoc i pozdrawiam.[/code]
