Wynik polecenia
plsd@plsd:~$ uname -r[/code]Dodam,że skompilowałem kernel w wersji 2.6.29-1-686 i sterowniki na nim zachowywały się tak samo.
Mój system to:
Debian 5.0 squeeze/sidKod: Zaznacz cały
plsd@plsd:~$ cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder63)  Mon Mar 23 15:33:27 PST 2009
Section "ServerLayout"
    Identifier     "X.org Configured"
    Screen      0  "Screen0" 0 0
    InputDevice    "Mouse0" "CorePointer"
    InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
    RgbPath         "/etc/X11/rgb"
    ModulePath      "/usr/lib/xorg/modules"
    FontPath        "/usr/share/fonts/X11/misc"
    FontPath        "/usr/share/fonts/X11/cyrillic"
    FontPath        "/usr/share/fonts/X11/100dpi/:unscaled"
    FontPath        "/usr/share/fonts/X11/75dpi/:unscaled"
    FontPath        "/usr/share/fonts/X11/Type1"
    FontPath        "/usr/share/fonts/X11/100dpi"
    FontPath        "/usr/share/fonts/X11/75dpi"
    FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
    Load           "extmod"
    Load           "glx"
    Load           "xtrap"
    Load           "dbe"
    Load           "record"
EndSection
Section "InputDevice"
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/input/mice"
    Option         "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
	#DisplaySize	  310   230	# mm
 ### Comment all HorizSync and VertRefresh values to use DDC:
    Identifier     "Monitor0"
    VendorName     "PHL"
    ModelName      "PHILIPS 107B4"
    HorizSync       30.0 - 86.0
    VertRefresh     50.0 - 160.0
    Option         "DPMS"
EndSection
Section "Device"
        ### Available Driver options are:-
        ### Values: [i]: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
        ### [arg]: arg optional
        #Option     "SWcursor"           	# [<bool>]
        #Option     "HWcursor"           	# [<bool>]
        #Option     "NoAccel"            	# [<bool>]
        #Option     "ShadowFB"           	# [<bool>]
        #Option     "UseFBDev"           	# [<bool>]
        #Option     "Rotate"             	# [<str>]
        #Option     "VideoKey"           	# [i]
        #Option     "FlatPanel"          	# [<bool>]
        #Option     "FPDither"           	# [<bool>]
        #Option     "CrtcNumber"         	# [i]
        #Option     "FPScale"            	# [<bool>]
        #Option     "FPTweak"            	# [i]
        #Option     "DualHead"           	# [<bool>]
    Identifier     "Card0"
    Driver         "nv"
    VendorName     "nVidia Corporation"
    BoardName      "G72 [GeForce 7300 LE]"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Card0"
    Monitor        "Monitor0"
    SubSection     "Display"
        Viewport    0 0
    EndSubSection
        Viewport    0 0
        Depth       4
    EndSubSection
        Viewport    0 0
        Depth       8
    EndSubSection
        Viewport    0 0
        Depth       15
    EndSubSection
        Viewport    0 0
        Depth       16
    EndSubSection
        Viewport    0 0
        Depth       24
    EndSubSection
EndSection
Palit - GeForce 7300 LE- na pci expressKod: Zaznacz cały
X.Org X Server 1.4.2
Release Date: 11 June 2008
Build Operating System: Linux Debian (xorg-server 2:1.4.2-11)
Current Operating System: Linux ceder 2.6.26-1-686 #1 SMP Sat Jan 10 18:29:31 UTC 2009 i686
Build Date: 20 February 2009  03:06:29AM
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Apr  9 10:29:52 2009
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
	Entry deleted from font path.
(==) Including the default font path /usr/share/fonts/X11/misc,/usr/share/fonts/X11/cyrillic,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType.
(**) FontPath set to:
	/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
(**) RgbPath set to "/etc/X11/rgb"
(**) ModulePath set to "/usr/lib/xorg/modules"
(II) Loader magic: 0x81e3800
(II) Module ABI versions:
	X.Org ANSI C Emulation: 0.3
	X.Org Video Driver: 2.0
	X.Org XInput driver : 2.0
	X.Org Server Extension : 0.3
	X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
	compiled for 1.4.2, module version = 1.0.0
	ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: 00:00:0: chip 10de,005e card 147b,1c28 rev a3 class 05,80,00 hdr 00
(II) PCI: 00:01:0: chip 10de,0050 card 147b,1c28 rev a3 class 06,01,00 hdr 80
(II) PCI: 00:01:1: chip 10de,0052 card 147b,1c28 rev a2 class 0c,05,00 hdr 80
(II) PCI: 00:02:0: chip 10de,005a card 147b,1c28 rev a2 class 0c,03,10 hdr 80
(II) PCI: 00:02:1: chip 10de,005b card 147b,1c28 rev a3 class 0c,03,20 hdr 80
(II) PCI: 00:04:0: chip 10de,0059 card 147b,1c28 rev a2 class 04,01,00 hdr 00
(II) PCI: 00:06:0: chip 10de,0053 card 147b,1c28 rev f2 class 01,01,8a hdr 00
(II) PCI: 00:07:0: chip 10de,0054 card 147b,1c28 rev f3 class 01,01,85 hdr 00
(II) PCI: 00:08:0: chip 10de,0055 card 147b,1c28 rev f3 class 01,01,85 hdr 00
(II) PCI: 00:09:0: chip 10de,005c card 0000,0000 rev a2 class 06,04,01 hdr 01
(II) PCI: 00:0b:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:0c:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:0d:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:0e:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:08:0: chip 1814,0101 card 1814,2460 rev 00 class 02,80,00 hdr 00
(II) PCI: 05:00:0: chip 10de,01d1 card 0000,0000 rev a1 class 03,00,00 hdr 00
(II) PCI: End of PCI scan
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:9:0), (0,1,1), BCTRL: 0x0204 (VGA_EN is cleared)
(II) Bus 1 I/O range:
	[0] -1	0	0x0000b000 - 0x0000b0ff (0x100) IX[B]
	[1] -1	0	0x0000b400 - 0x0000b4ff (0x100) IX[B]
	[2] -1	0	0x0000b800 - 0x0000b8ff (0x100) IX[B]
	[3] -1	0	0x0000bc00 - 0x0000bcff (0x100) IX[B]
(II) Bus 1 non-prefetchable memory range:
	[0] -1	0	0xfdf00000 - 0xfdffffff (0x100000) MX[B]
(II) Bus 1 prefetchable memory range:
	[0] -1	0	0xfde00000 - 0xfdefffff (0x100000) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:11:0), (0,2,2), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 2 I/O range:
	[0] -1	0	0x0000a000 - 0x0000a0ff (0x100) IX[B]
	[1] -1	0	0x0000a400 - 0x0000a4ff (0x100) IX[B]
	[2] -1	0	0x0000a800 - 0x0000a8ff (0x100) IX[B]
	[3] -1	0	0x0000ac00 - 0x0000acff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
	[0] -1	0	0xfdd00000 - 0xfddfffff (0x100000) MX[B]
(II) Bus 2 prefetchable memory range:
	[0] -1	0	0xfdc00000 - 0xfdcfffff (0x100000) MX[B]
(II) Bus 3: bridge is at (0:12:0), (0,3,3), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 3 I/O range:
	[0] -1	0	0x00009000 - 0x000090ff (0x100) IX[B]
	[1] -1	0	0x00009400 - 0x000094ff (0x100) IX[B]
	[2] -1	0	0x00009800 - 0x000098ff (0x100) IX[B]
	[3] -1	0	0x00009c00 - 0x00009cff (0x100) IX[B]
(II) Bus 3 non-prefetchable memory range:
	[0] -1	0	0xfdb00000 - 0xfdbfffff (0x100000) MX[B]
(II) Bus 3 prefetchable memory range:
	[0] -1	0	0xfda00000 - 0xfdafffff (0x100000) MX[B]
(II) Bus 4: bridge is at (0:13:0), (0,4,4), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 4 I/O range:
	[0] -1	0	0x00008000 - 0x000080ff (0x100) IX[B]
	[1] -1	0	0x00008400 - 0x000084ff (0x100) IX[B]
	[2] -1	0	0x00008800 - 0x000088ff (0x100) IX[B]
	[3] -1	0	0x00008c00 - 0x00008cff (0x100) IX[B]
(II) Bus 4 non-prefetchable memory range:
	[0] -1	0	0xfd900000 - 0xfd9fffff (0x100000) MX[B]
(II) Bus 4 prefetchable memory range:
	[0] -1	0	0xfd800000 - 0xfd8fffff (0x100000) MX[B]
(II) Bus 5: bridge is at (0:14:0), (0,5,5), BCTRL: 0x001c (VGA_EN is set)
(II) Bus 5 I/O range:
	[0] -1	0	0x00007000 - 0x000070ff (0x100) IX[B]
	[1] -1	0	0x00007400 - 0x000074ff (0x100) IX[B]
	[2] -1	0	0x00007800 - 0x000078ff (0x100) IX[B]
	[3] -1	0	0x00007c00 - 0x00007cff (0x100) IX[B]
(II) Bus 5 non-prefetchable memory range:
	[0] -1	0	0xfa000000 - 0xfcffffff (0x3000000) MX[B]
(II) Bus 5 prefetchable memory range:
	[0] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B]
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:24:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
	[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
	[0] -1	0	0x00000000 - 0xffffffff (0x0) MX[B]
(--) PCI:*(5:0:0) nVidia Corporation G72 [GeForce 7300 LE] rev 161, Mem @ 0xfa000000/24, 0xd0000000/28, 0xfb000000/24
	[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
	[0] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
	[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
	[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
	[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
	[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[5] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
	[0] -1	0	0xfdffe000 - 0xfdffffff (0x2000) MX[B]
	[1] -1	0	0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
	[2] -1	0	0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
	[3] -1	0	0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
	[4] -1	0	0xfeb00000 - 0xfeb000ff (0x100) MX[B]
	[5] -1	0	0xfe02f000 - 0xfe02ffff (0x1000) MX[B]
	[6] -1	0	0xfb000000 - 0xfbffffff (0x1000000) MX[B](B)
	[7] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
	[8] -1	0	0xfa000000 - 0xfaffffff (0x1000000) MX[B](B)
	[9] -1	0	0x0000c000 - 0x0000c00f (0x10) IX[B]
	[10] -1	0	0x00000b60 - 0x00000b63 (0x4) IX[B]
	[11] -1	0	0x00000960 - 0x00000967 (0x8) IX[B]
	[12] -1	0	0x00000be0 - 0x00000be3 (0x4) IX[B]
	[13] -1	0	0x000009e0 - 0x000009e7 (0x8) IX[B]
	[14] -1	0	0x0000d400 - 0x0000d40f (0x10) IX[B]
	[15] -1	0	0x00000b70 - 0x00000b73 (0x4) IX[B]
	[16] -1	0	0x00000970 - 0x00000977 (0x8) IX[B]
	[17] -1	0	0x00000bf0 - 0x00000bf3 (0x4) IX[B]
	[18] -1	0	0x000009f0 - 0x000009f7 (0x8) IX[B]
	[19] -1	0	0x0000e800 - 0x0000e80f (0x10) IX[B]
	[20] -1	0	0x0000ec00 - 0x0000ecff (0x100) IX[B]
	[21] -1	0	0x0000f000 - 0x0000f0ff (0x100) IX[B]
	[22] -1	0	0x00001c40 - 0x00001c7f (0x40) IX[B]
	[23] -1	0	0x00001c00 - 0x00001c3f (0x40) IX[B]
	[24] -1	0	0x0000fc00 - 0x0000fc1f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
	[4] -1	0	0xfdffe000 - 0xfdffffff (0x2000) MX[B]
	[5] -1	0	0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
	[6] -1	0	0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
	[7] -1	0	0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
	[8] -1	0	0xfeb00000 - 0xfeb000ff (0x100) MX[B]
	[9] -1	0	0xfe02f000 - 0xfe02ffff (0x1000) MX[B]
	[10] -1	0	0xfb000000 - 0xfbffffff (0x1000000) MX[B](B)
	[11] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
	[12] -1	0	0xfa000000 - 0xfaffffff (0x1000000) MX[B](B)
	[13] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[14] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[15] -1	0	0x0000c000 - 0x0000c00f (0x10) IX[B]
	[16] -1	0	0x00000b60 - 0x00000b63 (0x4) IX[B]
	[17] -1	0	0x00000960 - 0x00000967 (0x8) IX[B]
	[18] -1	0	0x00000be0 - 0x00000be3 (0x4) IX[B]
	[19] -1	0	0x000009e0 - 0x000009e7 (0x8) IX[B]
	[20] -1	0	0x0000d400 - 0x0000d40f (0x10) IX[B]
	[21] -1	0	0x00000b70 - 0x00000b73 (0x4) IX[B]
	[22] -1	0	0x00000970 - 0x00000977 (0x8) IX[B]
	[23] -1	0	0x00000bf0 - 0x00000bf3 (0x4) IX[B]
	[24] -1	0	0x000009f0 - 0x000009f7 (0x8) IX[B]
	[25] -1	0	0x0000e800 - 0x0000e80f (0x10) IX[B]
	[26] -1	0	0x0000ec00 - 0x0000ecff (0x100) IX[B]
	[27] -1	0	0x0000f000 - 0x0000f0ff (0x100) IX[B]
	[28] -1	0	0x00001c40 - 0x00001c7f (0x40) IX[B]
	[29] -1	0	0x00001c00 - 0x00001c3f (0x40) IX[B]
	[30] -1	0	0x0000fc00 - 0x0000fc1f (0x20) IX[B]
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "freetype" will be loaded by default.
(II) "record" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded by default.
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
	compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module  180.44  Mon Mar 23 15:29:02 PST 2009
(II) Loading extension GLX
(II) LoadModule: "xtrap"
(II) Loading /usr/lib/xorg/modules/extensions//libxtrap.so
(II) Module xtrap: vendor="X.Org Foundation"
(II) Loading extension DEC-XTRAP
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
	compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
	compiled for 1.4.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "nv"
(II) Loading /usr/lib/xorg/modules/drivers//nv_drv.so
(II) Module nv: vendor="X.Org Foundation"
	compiled for 1.4.2, module version = 2.1.10
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
	compiled for 1.4.0.90, module version = 1.3.0
	ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
	compiled for 1.4.0.90, module version = 1.3.1
<ciach>
(II) Primary Device is: PCI 05:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset GeForce 7300 LE found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
	[13] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B]
	[14] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B]
	[15] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B]
	[16] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[17] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[18] -1	0	0x0000c000 - 0x0000c00f (0x10) IX[B]
	[19] -1	0	0x00000b60 - 0x00000b63 (0x4) IX[B]
	[20] -1	0	0x00000960 - 0x00000967 (0x8) IX[B]
	[21] -1	0	0x00000be0 - 0x00000be3 (0x4) IX[B]
	[22] -1	0	0x000009e0 - 0x000009e7 (0x8) IX[B]
	[23] -1	0	0x0000d400 - 0x0000d40f (0x10) IX[B]
	[24] -1	0	0x00000b70 - 0x00000b73 (0x4) IX[B]
	[25] -1	0	0x00000970 - 0x00000977 (0x8) IX[B]
	[26] -1	0	0x00000bf0 - 0x00000bf3 (0x4) IX[B]
	[27] -1	0	0x000009f0 - 0x000009f7 (0x8) IX[B]
	[28] -1	0	0x0000e800 - 0x0000e80f (0x10) IX[B]
	[29] -1	0	0x0000ec00 - 0x0000ecff (0x100) IX[B]
	[30] -1	0	0x0000f000 - 0x0000f0ff (0x100) IX[B]
	[31] -1	0	0x00001c40 - 0x00001c7f (0x40) IX[B]
	[32] -1	0	0x00001c00 - 0x00001c3f (0x40) IX[B]
	[33] -1	0	0x0000fc00 - 0x0000fc1f (0x20) IX[B]
	[34] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B]
	[35] 0	0	0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) NV(0): Initializing int10
(II) NV(0): Primary V_BIOS segment is: 0xc000
(--) NV(0): Chipset: "GeForce 7300 LE"
(==) NV(0): Depth 24, (--) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
	compiled for 1.4.2, module version = 0.1.0
(==) NV(0): Using HW cursor
(--) NV(0): Linear framebuffer at 0xD0000000
(--) NV(0): MMIO registers at 0xFA000000
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"(II) Module "i2c" already built-in
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module "ddc" already built-in
(II) NV(0): I2C bus "DDC" initialized.
(II) NV(0): Probing for analog device on output A...
(--) NV(0):   ...found one
(II) NV(0): Probing for analog device on output B...
(II) NV(0): Probing for EDID on I2C bus A...
(II) NV(0): I2C device "DDC:ddc2" registered at address 0xA0.
(II) NV(0): I2C device "DDC:ddc2" removed.
(II) NV(0):   ... none found
(II) NV(0): Probing for EDID on I2C bus B...
(--) NV(0): DDC detected a CRT:
(II) NV(0): Manufacturer: PHL  Model: e011  Serial#: 542458
(II) NV(0): Year: 2002  Week: 39
(II) NV(0): EDID Version: 1.3
(II) NV(0): Analog Display Input,  Input Voltage Level: 0.700/0.700 V
(II) NV(0): Sync:  Separate
(II) NV(0): Max H-Image Size [cm]: horiz.: 31  vert.: 23
(II) NV(0): Gamma: 2.87
(II) NV(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) NV(0): First detailed timing not preferred mode in violation of standard!(II) NV(0): redX: 0.645 redY: 0.316   greenX: 0.265 greenY: 0.606
(II) NV(0): blueX: 0.143 blueY: 0.058   whiteX: 0.283 whiteY: 0.297
(II) NV(0): Supported VESA Video Modes:
(II) NV(0): 720x400@70Hz
(II) NV(0): 640x480@60Hz
(II) NV(0): 640x480@72Hz
(II) NV(0): 640x480@75Hz
(II) NV(0): 800x600@60Hz
(II) NV(0): 800x600@72Hz
(II) NV(0): 800x600@75Hz
(II) NV(0): 832x624@75Hz
(II) NV(0): 1024x768@60Hz
(II) NV(0): 1024x768@70Hz
(II) NV(0): 1024x768@75Hz
(II) NV(0): 1280x1024@75Hz
(II) NV(0): 1152x870@75Hz
(II) NV(0): Manufacturer's mask: 0
(II) NV(0): Supported Future Video Modes:
(II) NV(0): #0: hsize: 640  vsize 480  refresh: 85  vid: 22833
(II) NV(0): #1: hsize: 800  vsize 600  refresh: 85  vid: 22853
(II) NV(0): #2: hsize: 1024  vsize 768  refresh: 85  vid: 22881
(II) NV(0): #3: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
(II) NV(0): #4: hsize: 1600  vsize 1200  refresh: 60  vid: 16553
(II) NV(0): #5: hsize: 1280  vsize 960  refresh: 85  vid: 22913
(II) NV(0): #6: hsize: 1280  vsize 960  refresh: 60  vid: 16513
(II) NV(0): #7: hsize: 1152  vsize 864  refresh: 85  vid: 22897
(II) NV(0): Supported additional Video Mode:
(II) NV(0): clock: 25.2 MHz   Image Size:  306 x 230 mm
(II) NV(0): h_active: 640  h_sync: 656  h_sync_end 752 h_blank_end 800 h_border: 0
(II) NV(0): v_active: 350  v_sync: 387  v_sync_end 389 v_blanking: 449 v_border: 0
(II) NV(0): Serial No:  BZ  542458
(II) NV(0): Monitor name: PHILIPS 107B4
(II) NV(0): Ranges: V min: 50  V max: 160 Hz, H min: 30  H max: 86 kHz, PixClock max 180 MHz
(II) NV(0): EDID (in hex):
(II) NV(0): 	00ffffffffffff00410c11e0fa460800
(II) NV(0): 	270c0103681f17bbe80db8a551439b24
(II) NV(0): 	0e484cadef803159455961598180a940
(II) NV(0): 	815981407159d60980a0205e63101060
(II) NV(0): 	520832e61000001a000000ff0020425a
(II) NV(0): 	20203534323435380a20000000fc0050
(II) NV(0): 	48494c495053203130374234000000fd
(II) NV(0): 	0032a01e5612000a202020202020009d
(--) NV(0): CRTC 0 appears to have a CRT attached
(II) NV(0): Using CRT on CRTC 0
(II) NV(0): EDID vendor "PHL", prod id 57361
(II) NV(0): Using hsync ranges from config file
(II) NV(0): Using vrefresh ranges from config file
(II) NV(0): Printing DDC gathered Modelines:
(II) NV(0): Modeline "640x350"x0.0   25.18  640 656 752 800  350 387 389 449 +hsync -vsync (31.5 kHz)
(II) NV(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz)
(II) NV(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz)
(II) NV(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 491 520 -hsync -vsync (37.9 kHz)
(II) NV(0): Modeline "640x480"x0.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz)
(II) NV(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz)
(II) NV(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(II) NV(0): Modeline "1024x768"x0.0   78.80  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.1 kHz)
(II) NV(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz)
(II) NV(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz)
(II) NV(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz)
(II) NV(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz)
(II) NV(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz)
(II) NV(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz)
(II) NV(0): Modeline "640x480"x84.6   35.00  640 664 728 816  480 483 487 507 -hsync +vsync (42.9 kHz)
(II) NV(0): Modeline "800x600"x84.9   56.75  800 848 928 1056  600 603 607 633 -hsync +vsync (53.7 kHz)
(II) NV(0): Modeline "1024x768"x84.9   94.50  1024 1096 1200 1376  768 771 775 809 -hsync +vsync (68.7 kHz)
(II) NV(0): Modeline "1280x1024"x59.9  109.00  1280 1368 1496 1712  1024 1027 1034 1063 -hsync +vsync (63.7 kHz)
(II) NV(0): Modeline "1600x1200"x59.9  161.00  1600 1712 1880 2160  1200 1203 1207 1245 -hsync +vsync (74.5 kHz)
(II) NV(0): Modeline "1280x960"x84.9  148.25  1280 1368 1504 1728  960 963 967 1011 -hsync +vsync (85.8 kHz)
(II) NV(0): Modeline "1280x960"x59.9  101.25  1280 1360 1488 1696  960 963 967 996 -hsync +vsync (59.7 kHz)
(II) NV(0): Modeline "1152x864"x84.8  119.75  1152 1232 1352 1552  864 867 871 910 -hsync +vsync (77.2 kHz)
(--) NV(0): VideoRAM: 131072 kBytes
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(II) NV(0): Monitor0: Using hsync range of 30.00-86.00 kHz
(II) NV(0): Monitor0: Using vrefresh range of 50.00-160.00 Hz
(II) NV(0): Monitor0: Using maximum pixel clock of 180.00 MHz
(II) NV(0): Estimated virtual size for aspect ratio 1.3478 is 1600x1200
(II) NV(0): Clock range:  12.00 to 400.00 MHz
(II) NV(0): Not using default mode "1280x1024" (hsync out of range)
(II) NV(0): Not using default mode "640x512" (hsync out of range)
(II) NV(0): Not using default mode "1600x1200" (hsync out of range)
(II) NV(0): Not using default mode "800x600" (hsync out of range)
(II) NV(0): Not using default mode "1792x1344" (width too large for virtual size)
(II) NV(0): Not using default mode "896x672" (hsync out of range)
(II) NV(0): Not using default mode "1856x1392" (width too large for virtual size)
(II) NV(0): Not using default mode "928x696" (hsync out of range)
(II) NV(0): Not using default mode "1920x1440" (width too large for virtual size)
(II) NV(0): Not using default mode "960x720" (hsync out of range)
(II) NV(0): Not using default mode "1400x1050" (hsync out of range)
(II) NV(0): Not using default mode "700x525" (hsync out of range)
(II) NV(0): Not using default mode "1680x1050" (width too large for virtual size)
(II) NV(0): Not using default mode "1920x1200" (width too large for virtual size)
(II) NV(0): Not using default mode "960x600" (hsync out of range)
(II) NV(0): Not using default mode "2048x1536" (width too large for virtual size)
(II) NV(0): Not using default mode "1024x768" (hsync out of range)
(--) NV(0): Virtual size is 1600x1200 (pitch 1600)
(**) NV(0): *Driver mode "1600x1200": 161.0 MHz, 74.5 kHz, 59.9 Hz
(**) NV(0): *Default mode "1600x1200": 175.5 MHz, 81.2 kHz, 65.0 Hz
(II) NV(0): Modeline "1600x1200"x65.0  175.50  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (81.2 kHz)
(**) NV(0): *Default mode "1600x1200": 162.0 MHz, 75.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz)
(**) NV(0): *Default mode "1400x1050": 155.8 MHz, 81.5 kHz, 74.8 Hz
(II) NV(0): Modeline "1400x1050"x74.8  155.80  1400 1464 1784 1912  1050 1052 1064 1090 +hsync +vsync (81.5 kHz)
(**) NV(0): *Default mode "1400x1050": 151.0 MHz, 77.0 kHz, 70.0 Hz
(II) NV(0): Modeline "1400x1050"x70.0  151.00  1400 1464 1656 1960  1050 1051 1054 1100 +hsync +vsync (77.0 kHz)
(**) NV(0): *Default mode "1400x1050": 122.0 MHz, 64.9 kHz, 60.0 Hz
(II) NV(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz)
(**) NV(0): *Driver mode "1280x1024": 135.0 MHz, 80.0 kHz, 75.0 Hz
(II) NV(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
(**) NV(0): *Driver mode "1280x1024": 109.0 MHz, 63.7 kHz, 59.9 Hz
(**) NV(0): *Default mode "1280x1024": 135.0 MHz, 80.0 kHz, 75.0 Hz
(**) NV(0): *Default mode "1280x1024": 108.0 MHz, 64.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(**) NV(0): *Default mode "1440x900": 108.8 MHz, 56.9 kHz, 60.2 Hz
(II) NV(0): Modeline "1440x900"x60.2  108.84  1440 1472 1880 1912  900 918 927 946 +hsync +vsync (56.9 kHz)
(**) NV(0): *Driver mode "1280x960": 148.2 MHz, 85.8 kHz, 84.9 Hz
(**) NV(0): *Driver mode "1280x960": 101.2 MHz, 59.7 kHz, 59.9 Hz
(**) NV(0): *Default mode "1280x960": 148.5 MHz, 85.9 kHz, 85.0 Hz
(II) NV(0): Modeline "1280x960"x85.0  148.50  1280 1344 1504 1728  960 961 964 1011 +hsync +vsync (85.9 kHz)
(**) NV(0): *Default mode "1280x960": 108.0 MHz, 60.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz)
(**) NV(0): *Default mode "1280x800": 83.5 MHz, 49.7 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x800"x60.0   83.46  1280 1344 1480 1680  800 801 804 828 (49.7 kHz)
(**) NV(0): *Driver mode "1152x864": 119.8 MHz, 77.2 kHz, 84.8 Hz
(**) NV(0): *Driver mode "1152x864": 108.0 MHz, 67.5 kHz, 75.0 Hz
(II) NV(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz)
(**) NV(0): *Default mode "1152x864": 121.5 MHz, 77.5 kHz, 85.1 Hz
(II) NV(0): Modeline "1152x864"x85.1  121.50  1152 1216 1344 1568  864 865 868 911 +hsync -vsync (77.5 kHz)
(**) NV(0): *Default mode "1152x864": 108.0 MHz, 67.5 kHz, 75.0 Hz
(**) NV(0): *Default mode "1280x768": 80.1 MHz, 47.7 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x768"x60.0   80.14  1280 1344 1480 1680  768 769 772 795 (47.7 kHz)
(**) NV(0): *Default mode "1152x768": 65.0 MHz, 44.2 kHz, 54.8 Hz
(II) NV(0): Modeline "1152x768"x54.8   65.00  1152 1178 1314 1472  768 771 777 806 +hsync +vsync (44.2 kHz)
(**) NV(0): *Driver mode "1024x768": 94.5 MHz, 68.7 kHz, 84.9 Hz
(**) NV(0): *Driver mode "1024x768": 78.8 MHz, 60.1 kHz, 75.1 Hz
(II) NV(0): Modeline "1024x768"x75.1   78.80  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.1 kHz)
(**) NV(0): *Driver mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(II) NV(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz)
(**) NV(0): *Driver mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(II) NV(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz)
(**) NV(0): *Default mode "1024x768": 94.5 MHz, 68.7 kHz, 85.0 Hz
(II) NV(0): Modeline "1024x768"x85.0   94.50  1024 1072 1168 1376  768 769 772 808 +hsync +vsync (68.7 kHz)
(**) NV(0): *Default mode "1024x768": 78.8 MHz, 60.0 kHz, 75.0 Hz
(II) NV(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz)
(**) NV(0): *Default mode "1024x768": 75.0 MHz, 56.5 kHz, 70.1 Hz
(**) NV(0): *Default mode "1024x768": 65.0 MHz, 48.4 kHz, 60.0 Hz
(**) NV(0): *Default mode "1024x768": 44.9 MHz, 35.5 kHz, 86.9 Hz (I)
(II) NV(0): Modeline "1024x768"x86.9   44.90  1024 1032 1208 1264  768 768 776 817 interlace +hsync +vsync (35.5 kHz)
(**) NV(0): *Default mode "928x696": 109.2 MHz, 86.4 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "928x696"x60.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz)
(**) NV(0): *Default mode "896x672": 102.4 MHz, 83.7 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "896x672"x60.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz)
(**) NV(0): *Default mode "960x600": 96.6 MHz, 74.5 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "960x600"x60.0   96.58  960 1024 1128 1296  600 600 602 621 doublescan (74.5 kHz)
(**) NV(0): *Driver mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(II) NV(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz)
(**) NV(0): *Default mode "832x624": 57.3 MHz, 49.7 kHz, 74.6 Hz
(**) NV(0): *Driver mode "800x600": 56.8 MHz, 53.7 kHz, 84.9 Hz
(**) NV(0): *Driver mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(II) NV(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz)
(**) NV(0): *Driver mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(II) NV(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz)
(**) NV(0): *Driver mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(II) NV(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz)
(**) NV(0): *Default mode "800x600": 56.3 MHz, 53.7 kHz, 85.1 Hz
(II) NV(0): Modeline "800x600"x85.1   56.30  800 832 896 1048  600 601 604 631 +hsync +vsync (53.7 kHz)
(**) NV(0): *Default mode "800x600": 49.5 MHz, 46.9 kHz, 75.0 Hz
(**) NV(0): *Default mode "800x600": 50.0 MHz, 48.1 kHz, 72.2 Hz
(**) NV(0): *Default mode "800x600": 87.8 MHz, 81.2 kHz, 65.0 Hz (D)
(II) NV(0): Modeline "800x600"x65.0   87.75  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (81.2 kHz)
(**) NV(0): *Default mode "800x600": 40.0 MHz, 37.9 kHz, 60.3 Hz
(**) NV(0): *Default mode "800x600": 81.0 MHz, 75.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "800x600"x60.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz)
(**) NV(0): *Default mode "800x600": 36.0 MHz, 35.2 kHz, 56.2 Hz
(II) NV(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz)
(**) NV(0): *Default mode "840x525": 73.6 MHz, 65.2 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "840x525"x60.1   73.57  840 892 984 1128  525 525 527 543 doublescan (65.2 kHz)
(**) NV(0): *Default mode "700x525": 77.9 MHz, 81.5 kHz, 74.8 Hz (D)
(II) NV(0): Modeline "700x525"x74.8   77.90  700 732 892 956  525 526 532 545 doublescan +hsync +vsync (81.5 kHz)
(**) NV(0): *Default mode "700x525": 75.5 MHz, 77.0 kHz, 70.0 Hz (D)
(II) NV(0): Modeline "700x525"x70.0   75.50  700 732 828 980  525 525 527 550 doublescan +hsync +vsync (77.0 kHz)
(**) NV(0): *Default mode "700x525": 61.0 MHz, 64.9 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "700x525"x60.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz)
(**) NV(0): *Default mode "640x512": 67.5 MHz, 80.0 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "640x512"x75.0   67.50  640 648 720 844  512 512 514 533 doublescan +hsync +vsync (80.0 kHz)
(**) NV(0): *Default mode "640x512": 54.0 MHz, 64.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x512"x60.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz)
(**) NV(0): *Default mode "720x450": 54.4 MHz, 56.9 kHz, 60.2 Hz (D)
(II) NV(0): Modeline "720x450"x60.2   54.42  720 736 940 956  450 459 463 473 doublescan +hsync +vsync (56.9 kHz)
(**) NV(0): *Driver mode "640x480": 35.0 MHz, 42.9 kHz, 84.6 Hz
(**) NV(0): *Driver mode "640x480": 31.5 MHz, 37.5 kHz, 75.0 Hz
(II) NV(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz)
(**) NV(0):
