X.Org X Server 1.4.2
Release Date: 11 June 2008
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10)
Current Operating System: Linux debian 2.6.26-1-openvz-amd64 #1 SMP Fri Mar 13 19:02:24 UTC 2009 x86_64
Build Date: 09 January 2009 02:16:05AM
Before reporting problems, check
http://wiki.x.org
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 3 12:56:38 2009
(EE) Unable to locate/open config file
(II) Loader magic: 0x7c28e0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 2.0
X.Org XInput driver : 2.0
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
compiled for 1.4.2, module version = 1.0.0
ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: 00:00:0: chip 1002,5958 card 1002,5958 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:02:0: chip 1002,5978 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:0a:0: chip 1002,597f card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:12:0: chip 1002,4380 card 1458,b002 rev 00 class 01,06,01 hdr 00
(II) PCI: 00:13:0: chip 1002,4387 card 1458,5004 rev 00 class 0c,03,10 hdr 80
(II) PCI: 00:13:1: chip 1002,4388 card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:2: chip 1002,4389 card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:3: chip 1002,438a card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:4: chip 1002,438b card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:5: chip 1002,4386 card 1458,5004 rev 00 class 0c,03,20 hdr 00
(II) PCI: 00:14:0: chip 1002,4385 card 1458,4385 rev 14 class 0c,05,00 hdr 80
(II) PCI: 00:14:1: chip 1002,438c card 1458,5002 rev 00 class 01,01,8a hdr 00
(II) PCI: 00:14:2: chip 1002,4383 card 1458,a002 rev 00 class 04,03,00 hdr 00
(II) PCI: 00:14:3: chip 1002,438d card 1458,5001 rev 00 class 06,01,00 hdr 80
(II) PCI: 00:14:4: chip 1002,4384 card 0000,0000 rev 00 class 06,04,01 hdr 81
(II) PCI: 00:18:0: chip 1022,1200 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1201 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1202 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1203 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:4: chip 1022,1204 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 10de,0611 card 0000,0000 rev a2 class 03,00,00 hdr 00
(II) PCI: 02:00:0: chip 10ec,8168 card 1458,e000 rev 01 class 02,00,00 hdr 00
(II) PCI: 03:0e:0: chip 104c,8024 card 1458,1000 rev 00 class 0c,00,10 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,3), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
[0] -1 0 0x00000000 - 0xffffffff (0x100000000) MX
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:2:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf8000000 - 0xfbffffff (0x4000000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX
(II) Bus 2: bridge is at (0:10:0), (0,2,2), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000e000 - 0x0000efff (0x1000) IX
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfdf00000 - 0xfdffffff (0x100000) MX
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xfde00000 - 0xfdefffff (0x100000) MX
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:20:3), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 3: bridge is at (0:20:4), (0,3,3), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 3 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX
(II) Bus 3 non-prefetchable memory range:
[0] -1 0 0xfdd00000 - 0xfddfffff (0x100000) MX[B]
(II) Bus 3 prefetchable memory range:
[0] -1 0 0xfdc00000 - 0xfdcfffff (0x100000) MX[B]
(--) PCI:*(1:0:0) nVidia Corporation unknown chipset (0x0611) rev 162, Mem @ 0xfa000000/24, 0xd0000000/28, 0xf8000000/25, I/O @ 0xdf00/7
(II) Matched nv from file name nv.ids in autoconfig
(==) Matched nv for the autoconfigured driver
New driver is "nv"
(==) Using default built-in configuration (54 lines)
(==) --- Start of built-in configuration ---
Section "Module"
Load "extmod"
Load "dbe"
Load "glx"
Load "freetype"
Load "record"
Load "dri"
EndSection
Section "Monitor"
Identifier "Builtin Default Monitor"
EndSection
Section "Device"
Identifier "Builtin Default nv Device 0"
Driver "nv"
EndSection
Section "Screen"
Identifier "Builtin Default nv Screen 0"
Device "Builtin Default nv Device 0"
Monitor "Builtin Default Monitor"
EndSection
Section "Device"
Identifier "Builtin Default fbdev Device 0"
Driver "fbdev"
EndSection
Section "Screen"
Identifier "Builtin Default fbdev Screen 0"
Device "Builtin Default fbdev Device 0"
EndSection
Section "Device"
Identifier "Builtin Default vesa Device 0"
Driver "vesa"
EndSection
Section "Screen"
Identifier "Builtin Default vesa Screen 0"
Device "Builtin Default vesa Device 0"
EndSection
Section "Device"
Identifier "Builtin Default vga Device 0"
Driver "vga"
EndSection
Section "Screen"
Identifier "Builtin Default vga Screen 0"
Device "Builtin Default vga Device 0"
EndSection
Section "ServerLayout"
Identifier "Builtin Default Layout"
Screen "Builtin Default nv Screen 0"
Screen "Builtin Default fbdev Screen 0"
Screen "Builtin Default vesa Screen 0"
Screen "Builtin Default vga Screen 0"
EndSection
(==) --- End of built-in configuration ---
(==) ServerLayout "Builtin Default Layout"
(**) |-->Screen "Builtin Default nv Screen 0" (0)
(**) | |-->Monitor "Builtin Default Monitor"
(**) | |-->Device "Builtin Default nv Device 0"
(**) |-->Screen "Builtin Default fbdev Screen 0" (1)
(**) | |-->Device "Builtin Default fbdev Device 0"
(**) |-->Screen "Builtin Default vesa Screen 0" (2)
(**) | |-->Device "Builtin Default vesa Device 0"
(**) |-->Screen "Builtin Default vga Screen 0" (3)
(**) | |-->Device "Builtin Default vga Device 0"
(==) No FontPath specified. Using compiled-in default.
Entry deleted from font path.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to "/etc/X11/rgb"
(==) |-->Input Device "<default pointer>"
(==) |-->Input Device "<default keyboard>"
(==) The core pointer device wasn't specified explicitly in the layout.
Using the default mouse configuration.
(==) The core keyboard device wasn't specified explicitly in the layout.
Using the default keyboard configuration.
[0] -1 0 0x00000000 - 0xffffffff (0x100000000) MX[B]
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xe0000000 to 0xdfffffff
(II) Active PCI resource ranges:
[0] -1 0 0xfddf8000 - 0xfddfbfff (0x4000) MX[B]
[1] -1 0 0xfddff000 - 0xfddff7ff (0x800) MX[B]
[2] -1 0 0xfdfff000 - 0xfdffffff (0x1000) MX[B]
[3] -1 0 0xfe024000 - 0xfe027fff (0x4000) MX[B]
[4] -1 0 0xfe029000 - 0xfe0290ff (0x100) MX[B]
[5] -1 0 0xfe02a000 - 0xfe02afff (0x1000) MX[B]
[6] -1 0 0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
[7] -1 0 0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
[8] -1 0 0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
[9] -1 0 0xfe02e000 - 0xfe02efff (0x1000) MX[B]
[10] -1 0 0xfe02f000 - 0xfe02f3ff (0x400) MX[B]
[11] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[12] -1 0 0xf8000000 - 0xf9ffffff (0x2000000) MX[B](B)
[13] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[14] -1 0 0xfa000000 - 0xfaffffff (0x1000000) MX[B](B)
[15] -1 0 0x0000ee00 - 0x0000eeff (0x100) IX[B]
[16] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[17] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[18] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[19] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[20] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[21] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[22] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[23] -1 0 0x0000fc00 - 0x0000fc03 (0x4) IX[B]
[24] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[25] -1 0 0x0000fe00 - 0x0000fe03 (0x4) IX[B]
[26] -1 0 0x0000ff00 - 0x0000ff07 (0x8) IX[B]
[27] -1 0 0x0000df00 - 0x0000df7f (0x80) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xfddf8000 - 0xfddfbfff (0x4000) MX[B]
[5] -1 0 0xfddff000 - 0xfddff7ff (0x800) MX[B]
[6] -1 0 0xfdfff000 - 0xfdffffff (0x1000) MX[B]
[7] -1 0 0xfe024000 - 0xfe027fff (0x4000) MX[B]
[8] -1 0 0xfe029000 - 0xfe0290ff (0x100) MX[B]
[9] -1 0 0xfe02a000 - 0xfe02afff (0x1000) MX[B]
[10] -1 0 0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
[11] -1 0 0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
[12] -1 0 0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
[13] -1 0 0xfe02e000 - 0xfe02efff (0x1000) MX[B]
[14] -1 0 0xfe02f000 - 0xfe02f3ff (0x400) MX[B]
[15] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[16] -1 0 0xf8000000 - 0xf9ffffff (0x2000000) MX[B](B)
[17] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[18] -1 0 0xfa000000 - 0xfaffffff (0x1000000) MX[B](B)
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x0000ee00 - 0x0000eeff (0x100) IX[B]
[22] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[23] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[24] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[25] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[26] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[27] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[28] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[29] -1 0 0x0000fc00 - 0x0000fc03 (0x4) IX[B]
[30] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[31] -1 0 0x0000fe00 - 0x0000fe03 (0x4) IX[B]
[32] -1 0 0x0000ff00 - 0x0000ff07 (0x8) IX[B]
[33] -1 0 0x0000df00 - 0x0000df7f (0x80) IX[B](B)
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "dbe" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "freetype" will be loaded. This was enabled by default and also specified in the config file.
(II) "record" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module 180.22 Tue Jan 6 09:40:07 PST 2009
(II) Loading extension GLX
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
compiled for 1.4.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) LoadModule: "nv"
(II) Loading /usr/lib/xorg/modules/drivers//nv_drv.so
(II) Module nv: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 2.1.10
(II) LoadModule: "fbdev"
(II) Loading /usr/lib/xorg/modules/drivers//fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 1.4.0.90, module version = 0.4.0
(II) LoadModule: "vesa"
(II) Loading /usr/lib/xorg/modules/drivers//vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 1.4.0, module version = 1.3.0
(II) LoadModule: "vga"
(II) Loading /usr/lib/xorg/modules/drivers//vga_drv.so
(II) Module vga: vendor="X.Org Foundation"
compiled for 1.4.0, module version = 4.1.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
compiled for 1.4.0.90, module version = 1.3.0
ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
compiled for 1.4.0.90, module version = 1.3.1
(II) NV: driver for NVIDIA chipsets: RIVA 128, RIVA TNT, RIVA TNT2,
Unknown TNT2, Vanta, RIVA TNT2 Ultra, RIVA TNT2 Model 64,
Aladdin TNT2, GeForce 256, GeForce DDR, Quadro, GeForce2 MX/MX 400,
GeForce2 MX 100/200, GeForce2 Go, Quadro2 MXR/EX/Go,
GeForce2 Integrated GPU, GeForce2 GTS, GeForce2 Ti, GeForce2 Ultra,
Quadro2 Pro, GeForce4 MX 460, GeForce4 MX 440, GeForce4 MX 420,
GeForce4 MX 440-SE, GeForce4 440 Go, GeForce4 420 Go,
GeForce4 420 Go 32M, GeForce4 460 Go, Quadro4 550 XGL,
GeForce4 440 Go 64M, Quadro NVS, Quadro4 500 GoGL,
GeForce4 410 Go 16M, GeForce4 MX 440 with AGP8X,
GeForce4 MX 440SE with AGP8X, GeForce4 MX 420 with AGP8X,
GeForce4 MX 4000, GeForce4 448 Go, GeForce4 488 Go, Quadro4 580 XGL,
Quadro4 NVS 280 SD, Quadro4 380 XGL, Quadro NVS 50 PCI,
GeForce4 448 Go, GeForce4 MX Integrated GPU, GeForce3,
GeForce3 Ti 200, GeForce3 Ti 500, Quadro DCC, GeForce4 Ti 4600,
GeForce4 Ti 4400, GeForce4 Ti 4200, Quadro4 900 XGL, Quadro4 750 XGL,
Quadro4 700 XGL, GeForce4 Ti 4800, GeForce4 Ti 4200 with AGP8X,
GeForce4 Ti 4800 SE, GeForce4 4200 Go, Quadro4 700 GoGL,
Quadro4 980 XGL, Quadro4 780 XGL, GeForce FX 5800 Ultra,
GeForce FX 5800, Quadro FX 2000, Quadro FX 1000,
GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT,
GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700,
GeForce FX 5200, GeForce FX 5200 Ultra, GeForce FX 5200,
GeForce FX 5200LE, GeForce FX Go5200, GeForce FX Go5250,
GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M,
Quadro NVS 55/280 PCI, Quadro FX 500/600 PCI,
GeForce FX Go53xx Series, GeForce FX Go5100, GeForce FX 5900 Ultra,
GeForce FX 5900, GeForce FX 5900XT, GeForce FX 5950 Ultra,
GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700,
GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE,
GeForce FX 5700VE, GeForce FX Go5700, GeForce FX Go5700,
Quadro FX Go1000, Quadro FX 1100, GeForce 6800 Ultra, GeForce 6800,
GeForce 6800 LE, GeForce 6800 XE, GeForce 6800 XT, GeForce 6800 GT,
GeForce 6800 GT, GeForce 6800 GS, GeForce 6800 XT, Quadro FX 4000,
GeForce 6800 GS, GeForce 6800, GeForce 6800 LE, GeForce 6800 XT,
GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400,
Quadro FX 3450/4000 SDI, Quadro FX 1400, GeForce 6600 GT,
GeForce 6600, GeForce 6600 LE, GeForce 6600 VE, GeForce Go 6600,
GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL,
GeForce Go 6600, GeForce Go 6600 GT, Quadro FX 550, Quadro FX 550,
Quadro FX 540, GeForce 6200, GeForce 6500,
GeForce 6200 TurboCache(TM), GeForce 6200SE TurboCache(TM),
GeForce 6200 LE, GeForce Go 6200, Quadro NVS 285, GeForce Go 6400,
GeForce Go 6200, GeForce Go 6400, GeForce 6250, GeForce 6800,
GeForce 6800 LE, GeForce 6800 GT, GeForce 6800 XT, GeForce 6200,
GeForce 6200 A-LE, GeForce 7800 GTX, GeForce 7800 GTX,
GeForce 7800 GT, GeForce 7800 GS, GeForce 7800 SLI, GeForce Go 7800,
GeForce Go 7800 GTX, Quadro FX 4500, GeForce 7300 LE,
GeForce 7300 SE, GeForce Go 7200, GeForce Go 7300, GeForce Go 7400,
GeForce Go 7400 GS, Quadro NVS 110M, Quadro NVS 120M, Quadro FX 350M,
GeForce 7500 LE, Quadro FX 350, GeForce 7300 GS, GeForce 7600 GT,
GeForce 7600 GS, GeForce 7300 GT, GeForce 7600 LE, GeForce 7300 GT,
GeForce Go 7700, GeForce Go 7600, GeForce Go 7600 GT,
Quadro NVS 300M, GeForce Go 7900 SE, Quadro FX 550M, Quadro FX 560,
GeForce 7900 GTX, GeForce 7900 GT, GeForce 7900 GS,
GeForce Go 7900 GS, GeForce Go 7900 GTX, Quadro FX 2500M,
Quadro FX 1500M, Quadro FX 5500, Quadro FX 3500, Quadro FX 1500,
Quadro FX 4500 X2, GeForce 6150, GeForce 6150 LE, GeForce 6100,
GeForce Go 6150, GeForce Go 6100, GeForce 8800 GTX, GeForce 8800 GTS,
GeForce 8800 Ultra, Quadro FX 5600, Quadro FX 4600, GeForce 8600 GTS,
GeForce 8600 GT, GeForce 8600 GT, GeForce 8400 GS, GeForce 9500M GS,
GeForce 8600M GT, GeForce 9650M GS, GeForce 8700M GT, Quadro FX 370,
Quadro NVS 320M, Quadro FX 570M, Quadro FX 1600M, Quadro FX 570,
Quadro FX 1700, GeForce 8400 SE, GeForce 8500 GT, GeForce 8400 GS,
GeForce 8300 GS, GeForce 8400 GS, GeForce 8600M GS, GeForce 8400M GT,
GeForce 8400M GS, GeForce 8400M G, Quadro NVS 140M, Quadro NVS 130M,
Quadro NVS 135M, Quadro FX 360M, GeForce 9300M G, Quadro NVS 290,
GeForce GTX 280, GeForce GTX 260, GeForce 8800 GTS 512,
GeForce 8800 GT, GeForce 9800 GX2, GeForce 8800 GS,
GeForce 8800M GTS, GeForce 8800M GTX, GeForce 8800 GS,
GeForce 9600 GSO, GeForce 8800 GT, GeForce 9800 GTX, Quadro FX 3700,
Quadro FX 3600M, GeForce 9600 GT, GeForce 9600M GT, GeForce 9600M GS,
GeForce 9600M GT, GeForce 9500M G, GeForce 8400 GS, GeForce 9300M GS,
GeForce 9200M GS, GeForce 9300M GS
(II) FBDEV: driver for framebuffer: fbdev
(II) VESA: driver for VESA chipsets: vesa
(II) VGA: Generic VGA driver (version 4.1) for chipsets: generic
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset GeForce 8800 GT found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) Loading sub module "fbdevhw"
(II) LoadModule: "fbdevhw"
(II) Loading /usr/lib/xorg/modules/linux//libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 0.0.2
(EE) open /dev/fb0: No such file or directory
(--) Chipset vesa found
(--) Chipset generic found
(II) resource ranges after probing:
[19] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[20] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[21] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[22] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[23] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[24] -1 0 0x0000ee00 - 0x0000eeff (0x100) IX[B]
[25] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[26] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[27] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[28] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[29] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[30] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[31] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[32] -1 0 0x0000fc00 - 0x0000fc03 (0x4) IX[B]
[33] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[34] -1 0 0x0000fe00 - 0x0000fe03 (0x4) IX[B]
[35] -1 0 0x0000ff00 - 0x0000ff07 (0x8) IX[B]
[36] -1 0 0x0000df00 - 0x0000df7f (0x80) IX[B](B)
[37] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[38] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) NV(0): Initializing int10
(II) NV(0): Primary V_BIOS segment is: 0xc000
(--) NV(0): Console is VGA mode 0x3
(II) NV(0): Creating default Display subsection in Screen section
"Builtin Default nv Screen 0" for depth/fbbpp 24/32
(==) NV(0): Depth 24, (--) framebuffer bpp 32
(==) NV(0): RGB weight 888
(==) NV(0): Default visual is TrueColor
(==) NV(0): Using hardware cursor
(==) NV(0): Using gamma correction (1.0, 1.0, 1.0)
(II) NV(0): MMIO registers mapped at 0x7f3fe242c000
(--) NV(0): Total video RAM: 1024.0 MB
(--) NV(0): BAR1 size: 256.0 MB
(--) NV(0): Mapped memory: 256.0 MB
(II) NV(0): Linear framebuffer mapped at 0x7f3fd242c000
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"(II) Module "i2c" already built-in
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module "ddc" already built-in
(--) NV(0): Connector map:
(--) NV(0): Bus 0 -> DAC1
(--) NV(0): Bus 0 -> SOR0
(--) NV(0): Bus 1 -> DAC2
(--) NV(0): Bus 1 -> SOR1
(--) NV(0): Load detection: 312
(II) NV(0): I2C bus "I2C0" initialized.
(II) NV(0): Output VGA1 using monitor section Builtin Default Monitor
(II) NV(0): Output DVI0 has no monitor section
(II) NV(0): I2C bus "I2C1" initialized.
(II) NV(0): Output VGA2 has no monitor section
(II) NV(0): Output DVI1 has no monitor section
(II) NV(0): Probing for EDID on I2C bus 0...
(II) NV(0): I2C device "I2C0:ddc2" registered at address 0xA0.
(II) NV(0): I2C device "I2C0:ddc2" removed.
(II) NV(0): ... none found
(--) NV(0): Trying load detection on VGA1 ... nothing.
(II) NV(0): Probing for EDID on I2C bus 1...
(II) NV(0): I2C device "I2C1:ddc2" registered at address 0xA0.
(--) NV(0): DDC detected a CRT:
(II) NV(0): Manufacturer: PHL Model: e013 Serial#: 567063
(II) NV(0): Year: 2003 Week: 42
(II) NV(0): EDID Version: 1.3
(II) NV(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
(II) NV(0): Sync: Separate
(II) NV(0): Max H-Image Size [cm]: horiz.: 31 vert.: 23
(II) NV(0): Gamma: 2.83
(II) NV(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) NV(0): First detailed timing not preferred mode in violation of standard!(II) NV(0): redX: 0.636 redY: 0.327 greenX: 0.278 greenY: 0.600
(II) NV(0): blueX: 0.145 blueY: 0.064 whiteX: 0.283 whiteY: 0.297
(II) NV(0): Supported VESA Video Modes:
(II) NV(0): 720x400@70Hz
(II) NV(0): 640x480@60Hz
(II) NV(0): 640x480@72Hz
(II) NV(0): 640x480@75Hz
(II) NV(0): 800x600@60Hz
(II) NV(0): 800x600@72Hz
(II) NV(0): 800x600@75Hz
(II) NV(0): 832x624@75Hz
(II) NV(0): 1024x768@60Hz
(II) NV(0): 1024x768@70Hz
(II) NV(0): 1024x768@75Hz
(II) NV(0): Manufacturer's mask: 0
(II) NV(0): Supported Future Video Modes:
(II) NV(0): #0: hsize: 640 vsize 480 refresh: 85 vid: 22833
(II) NV(0): #1: hsize: 800 vsize 600 refresh: 85 vid: 22853
(II) NV(0): #2: hsize: 1024 vsize 768 refresh: 85 vid: 22881
(II) NV(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) NV(0): #4: hsize: 640 vsize 480 refresh: 100 vid: 26673
(II) NV(0): #5: hsize: 800 vsize 600 refresh: 100 vid: 26693
(II) NV(0): #6: hsize: 1280 vsize 960 refresh: 60 vid: 16513
(II) NV(0): #7: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) NV(0): Supported additional Video Mode:
(II) NV(0): clock: 25.2 MHz Image Size: 306 x 230 mm
(II) NV(0): h_active: 640 h_sync: 656 h_sync_end 752 h_blank_end 800 h_border: 0
(II) NV(0): v_active: 350 v_sync: 387 v_sync_end 389 v_blanking: 449 v_border: 0
(II) NV(0): Serial No: CX 567063
(II) NV(0): Monitor name: PHILIPS 107T5
(II) NV(0): Ranges: V min: 50 V max: 160 Hz, H min: 30 H max: 71 kHz, PixClock max 110 MHz
(II) NV(0): EDID (in hex):
(II) NV(0): 00ffffffffffff00410c13e017a70800
(II) NV(0): 2a0d0103681f17b7e8f628a253479925
(II) NV(0): 10484cadee0031594559615981803168
(II) NV(0): 45688140714fd60980a0205e63101060
(II) NV(0): 520832e61000001a000000ff00204358
(II) NV(0): 20203536373036330a20000000fc0050
(II) NV(0): 48494c495053203130375435000000fd
(II) NV(0): 0032a01e470b000a20202020202000cd
(--) NV(0): Trying load detection on VGA2 ... found one!
(II) NV(0): EDID vendor "PHL", prod id 57363
(II) NV(0): Output VGA1 disconnected
(II) NV(0): Output DVI0 disconnected
(II) NV(0): Output VGA2 connected
(II) NV(0): Output DVI1 disconnected
(II) NV(0): Output VGA2 using initial mode 1152x864
(--) NV(0): Virtual size is 1600x1600 (pitch 1792)
(**) NV(0): Default mode "1152x864": 108.0 MHz (scaled from 0.0 MHz), 67.5 kHz, 75.0 Hz
(II) NV(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
(**) NV(0): Driver mode "1152x864": 104.0 MHz (scaled from 0.0 MHz), 67.7 kHz, 74.8 Hz
(II) NV(0): Modeline "1152x864"x74.8 104.00 1152 1224 1344 1536 864 867 871 905 -hsync +vsync (67.7 kHz)
(**) NV(0): Default mode "1280x768": 80.1 MHz (scaled from 0.0 MHz), 47.7 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x768"x60.0 80.14 1280 1344 1480 1680 768 769 772 795 (47.7 kHz)
(**) NV(0): Default mode "1152x768": 65.0 MHz (scaled from 0.0 MHz), 44.2 kHz, 54.8 Hz
(II) NV(0): Modeline "1152x768"x54.8 65.00 1152 1178 1314 1472 768 771 777 806 +hsync +vsync (44.2 kHz)
(**) NV(0): Driver mode "1024x768": 94.5 MHz (scaled from 0.0 MHz), 68.7 kHz, 84.9 Hz
(II) NV(0): Modeline "1024x768"x84.9 94.50 1024 1096 1200 1376 768 771 775 809 -hsync +vsync (68.7 kHz)
(**) NV(0): Default mode "1024x768": 94.5 MHz (scaled from 0.0 MHz), 68.7 kHz, 85.0 Hz
(II) NV(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz)
(**) NV(0): Driver mode "1024x768": 78.8 MHz (scaled from 0.0 MHz), 60.1 kHz, 75.1 Hz
(II) NV(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz)
(**) NV(0): Default mode "1024x768": 78.8 MHz (scaled from 0.0 MHz), 60.0 kHz, 75.0 Hz
(II) NV(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
(**) NV(0): Driver mode "1024x768": 75.0 MHz (scaled from 0.0 MHz), 56.5 kHz, 70.1 Hz
(II) NV(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
(**) NV(0): Driver mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
(II) NV(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
(**) NV(0): Default mode "1024x768": 44.9 MHz (scaled from 0.0 MHz), 35.5 kHz, 87.0 Hz (I)
(II) NV(0): Modeline "1024x768"x87.0 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz)
(**) NV(0): Driver mode "832x624": 57.3 MHz (scaled from 0.0 MHz), 49.7 kHz, 74.6 Hz
(II) NV(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
(**) NV(0): Driver mode "800x600": 67.2 MHz (scaled from 0.0 MHz), 63.7 kHz, 99.7 Hz
(II) NV(0): Modeline "800x600"x99.7 67.25 800 848 928 1056 600 603 607 639 -hsync +vsync (63.7 kHz)
(**) NV(0): Driver mode "800x600": 56.8 MHz (scaled from 0.0 MHz), 53.7 kHz, 84.9 Hz
(II) NV(0): Modeline "800x600"x84.9 56.75 800 848 928 1056 600 603 607 633 -hsync +vsync (53.7 kHz)
(**) NV(0): Default mode "800x600": 56.3 MHz (scaled from 0.0 MHz), 53.7 kHz, 85.1 Hz
(II) NV(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz)
(**) NV(0): Driver mode "800x600": 50.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.2 Hz
(II) NV(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
(**) NV(0): Driver mode "800x600": 49.5 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz
(II) NV(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
(**) NV(0): Driver mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.3 Hz
(II) NV(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
(**) NV(0): Default mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.2 Hz
(II) NV(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
(**) NV(0): Default mode "840x525": 73.6 MHz (scaled from 0.0 MHz), 65.2 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "840x525"x60.1 73.57 840 892 984 1128 525 525 527 543 doublescan (65.2 kHz)
(**) NV(0): Default mode "800x512": 53.5 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "800x512"x60.1 53.45 800 810 820 835 512 513 515 533 doublescan -hsync -vsync (64.0 kHz)
(**) NV(0): Default mode "700x525": 61.0 MHz (scaled from 0.0 MHz), 64.9 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz)
(**) NV(0): Default mode "640x512": 54.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz)
(**) NV(0): Default mode "720x450": 54.4 MHz (scaled from 0.0 MHz), 56.9 kHz, 60.2 Hz (D)
(II) NV(0): Modeline "720x450"x60.2 54.42 720 736 940 956 450 459 463 473 doublescan +hsync +vsync (56.9 kHz)
(**) NV(0): Default mode "640x480": 54.0 MHz (scaled from 0.0 MHz), 60.0 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz)
(**) NV(0): Driver mode "640x480": 42.5 MHz (scaled from 0.0 MHz), 51.1 kHz, 99.8 Hz
(II) NV(0): Modeline "640x480"x99.8 42.50 640 672 736 832 480 483 487 512 -hsync +vsync (51.1 kHz)
(**) NV(0): Default mode "640x480": 36.0 MHz (scaled from 0.0 MHz), 43.3 kHz, 85.0 Hz
(II) NV(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz)
(**) NV(0): Driver mode "640x480": 35.0 MHz (scaled from 0.0 MHz), 42.9 kHz, 84.6 Hz
(II) NV(0): Modeline "640x480"x84.6 35.00 640 664 728 816 480 483 487 507 -hsync +vsync (42.9 kHz)
(**) NV(0): Driver mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
(II) NV(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
(**) NV(0): Driver mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 72.8 Hz
(II) NV(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz)
(**) NV(0): Default mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 72.8 Hz
(II) NV(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
(**) NV(0): Default mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
(**) NV(0): Driver mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) NV(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(**) NV(0): Default mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 59.9 Hz
(II) NV(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
(**) NV(0): Default mode "720x400": 35.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 85.0 Hz
(II) NV(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz)
(**) NV(0): Driver mode "720x400": 28.3 MHz (scaled from 0.0 MHz), 31.5 kHz, 70.1 Hz
(II) NV(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
(**) NV(0): Default mode "640x400": 41.7 MHz (scaled from 0.0 MHz), 49.7 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "640x400"x60.0 41.73 640 672 740 840 400 400 402 414 doublescan (49.7 kHz)
(**) NV(0): Default mode "640x400": 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 85.1 Hz
(II) NV(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz)
(**) NV(0): Default mode "576x432": 54.0 MHz (scaled from 0.0 MHz), 67.5 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz)
(**) NV(0): Default mode "640x384": 40.1 MHz (scaled from 0.0 MHz), 47.7 kHz, 60.1 Hz (D)
(II) NV(0): Modeline "640x384"x60.1 40.07 640 672 740 840 384 384 386 397 doublescan (47.7 kHz)
(**) NV(0): Default mode "640x350": 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 85.1 Hz
(II) NV(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz)
(**) NV(0): Driver mode "640x350": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 70.1 Hz
(II) NV(0): Modeline "640x350"x70.1 25.18 640 656 752 800 350 387 389 449 +hsync -vsync (31.5 kHz)
(**) NV(0): Default mode "576x384": 32.5 MHz (scaled from 0.0 MHz), 44.2 kHz, 54.8 Hz (D)
(II) NV(0): Modeline "576x384"x54.8 32.50 576 589 657 736 384 385 388 403 doublescan +hsync +vsync (44.2 kHz)
(**) NV(0): Default mode "512x384": 47.2 MHz (scaled from 0.0 MHz), 68.7 kHz, 85.0 Hz (D)
(II) NV(0): Modeline "512x384"x85.0 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync (68.7 kHz)
(**) NV(0): Default mode "512x384": 39.4 MHz (scaled from 0.0 MHz), 60.0 kHz, 75.0 Hz (D)
(II) NV(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz)
(**) NV(0): Default mode "512x384": 37.5 MHz (scaled from 0.0 MHz), 56.5 kHz, 70.1 Hz (D)
(II) NV(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz)
(**) NV(0): Default mode "512x384": 32.5 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz (D)
(II) NV(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz)
(**) NV(0): Default mode "416x312": 28.6 MHz (scaled from 0.0 MHz), 49.7 kHz, 74.7 Hz (D)
(II) NV(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz)
(**) NV(0): Default mode "400x300": 28.1 MHz (scaled from 0.0 MHz), 53.7 kHz, 85.3 Hz (D)
(II) NV(0): Modeline "400x300"x85.3 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync (53.7 kHz)
(**) NV(0): Default mode "400x300": 25.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.2 Hz (D)
(II) NV(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz)
(**) NV(0): Default mode "1600x1024": 106.9 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1600x1024"x60.0 106.91 1600 1620 1640 1670 1024 1027 1030 1067 -hsync -vsync (64.0 kHz)
(**) NV(0): Driver mode "1280x1024": 109.0 MHz (scaled from 0.0 MHz), 63.7 kHz, 59.9 Hz
(II) NV(0): Modeline "1280x1024"x59.9 109.00 1280 1368 1496 1712 1024 1027 1034 1063 -hsync +vsync (63.7 kHz)
(**) NV(0): Default mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
(**) NV(0): Default mode "1440x900": 108.8 MHz (scaled from 0.0 MHz), 56.9 kHz, 60.2 Hz
(II) NV(0): Modeline "1440x900"x60.2 108.84 1440 1472 1880 1912 900 918 927 946 +hsync +vsync (56.9 kHz)
(**) NV(0): Default mode "1280x960": 108.0 MHz (scaled from 0.0 MHz), 60.0 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz)
(**) NV(0): Driver mode "1280x960": 101.2 MHz (scaled from 0.0 MHz), 59.7 kHz, 59.9 Hz
(II) NV(0): Modeline "1280x960"x59.9 101.25 1280 1360 1488 1696 960 963 967 996 -hsync +vsync (59.7 kHz)
(**) NV(0): Default mode "1280x800": 83.5 MHz (scaled from 0.0 MHz), 49.7 kHz, 60.0 Hz
(II) NV(0): Modeline "1280x800"x60.0 83.46 1280 1344 1480 1680 800 801 804 828 (49.7 kHz)
(==) NV(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules//libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.2.0
(II) LoadModule: "ramdac"(II) Module "ramdac" already built-in
(II) UnloadModule: "fbdev"
(II) Unloading /usr/lib/xorg/modules/drivers//fbdev_drv.so
(II) UnloadModule: "fbdevhw"
(II) Unloading /usr/lib/xorg/modules/linux//libfbdevhw.so
(II) UnloadModule: "vesa"
(II) Unloading /usr/lib/xorg/modules/drivers//vesa_drv.so
(II) UnloadModule: "vga"
(II) Unloading /usr/lib/xorg/modules/drivers//vga_drv.so
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xf8000000 - 0xf9ffffff (0x2000000) MX[B]
[1] 0 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B]
[2] 0 0 0xfa000000 - 0xfaffffff (0x1000000) MX[B]
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0xfddf8000 - 0xfddfbfff (0x4000) MX[B]
[8] -1 0 0xfddff000 - 0xfddff7ff (0x800) MX[B]
[9] -1 0 0xfdfff000 - 0xfdffffff (0x1000) MX[B]
[10] -1 0 0xfe024000 - 0xfe027fff (0x4000) MX[B]
[11] -1 0 0xfe029000 - 0xfe0290ff (0x100) MX[B]
[12] -1 0 0xfe02a000 - 0xfe02afff (0x1000) MX[B]
[13] -1 0 0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
[14] -1 0 0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
[15] -1 0 0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
[16] -1 0 0xfe02e000 - 0xfe02efff (0x1000) MX[B]
[17] -1 0 0xfe02f000 - 0xfe02f3ff (0x400) MX[B]
[18] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O
[19] -1 0 0xf8000000 - 0xf9ffffff (0x2000000) MX[B](B)
[20] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[21] -1 0 0xfa000000 - 0xfaffffff (0x1000000) MX[B](B)
[22] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[23] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[24] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[25] 0 0 0x0000df00 - 0x0000df7f (0x80) IX[B]
[26] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[27] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[28] -1 0 0x0000ee00 - 0x0000eeff (0x100) IX[B]
[29] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[30] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[31] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[32] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[33] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[34] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[35] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[36] -1 0 0x0000fc00 - 0x0000fc03 (0x4) IX[B]
[37] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[38] -1 0 0x0000fe00 - 0x0000fe03 (0x4) IX[B]
[39] -1 0 0x0000ff00 - 0x0000ff07 (0x8) IX[B]
[40] -1 0 0x0000df00 - 0x0000df7f (0x80) IX[B](B)
[41] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[42] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(--) NV(0): 213.06 MB available for offscreen pixmaps
(II) NV(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
8x8 mono pattern filled rectangles
Indirect CPU to Screen color expansion
Solid Lines
Scanline Image Writes
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(==) NV(0): Backing store disabled
(==) NV(0): Silken mouse enabled
(II) NV(0): DPMS enabled
(II) NV(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(--) RandR disabled
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension XEVIE
(EE) Failed to initialize GLX extension (Compatible NVIDIA X driver not found)
(II) NV(0): Setting screen physical size to 306 x 230
(WW) <default pointer>: No Device specified, looking for
