mobility radeon hd3470 na amd64 - jak zainstalowa
mobility radeon hd3470 na amd64 - jak zainstalować?
Czy ktoś może mi powiedzieć jak zainstalować mam sterowniki do karty mobility radeon hd3470 mając procesor amd64bit? Nie mogę znaleźć sterowników, a nie ukrywam nie mam pojęcia jak to zrobić?
ogur, wklej wyniki poleceń:
uname -r
lspci
cat /etc/apt/sources.listKod: Zaznacz cały
bartek@bartek:~$ uname -r
2.6.26-1-amd64Kod: Zaznacz cały
bartek@bartek:~$ lspci
00:00.0 Host bridge: ATI Technologies Inc RS690 Host Bridge
00:02.0 PCI bridge: ATI Technologies Inc RS690 PCI to PCI Bridge (PCI Express Graphics Port 0)
00:04.0 PCI bridge: ATI Technologies Inc Device 7914
00:05.0 PCI bridge: ATI Technologies Inc RS690 PCI to PCI Bridge (PCI Express Port 1)
00:06.0 PCI bridge: ATI Technologies Inc RS690 PCI to PCI Bridge (PCI Express Port 2)
00:07.0 PCI bridge: ATI Technologies Inc RS690 PCI to PCI Bridge (PCI Express Port 3)
00:12.0 SATA controller: ATI Technologies Inc SB600 Non-Raid-5 SATA
00:13.0 USB Controller: ATI Technologies Inc SB600 USB (OHCI0)
00:13.1 USB Controller: ATI Technologies Inc SB600 USB (OHCI1)
00:13.2 USB Controller: ATI Technologies Inc SB600 USB (OHCI2)
00:13.3 USB Controller: ATI Technologies Inc SB600 USB (OHCI3)
00:13.4 USB Controller: ATI Technologies Inc SB600 USB (OHCI4)
00:13.5 USB Controller: ATI Technologies Inc SB600 USB Controller (EHCI)
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 14)
00:14.1 IDE interface: ATI Technologies Inc SB600 IDE
00:14.2 Audio device: ATI Technologies Inc SBx00 Azalia (Intel HDA)
00:14.3 ISA bridge: ATI Technologies Inc SB600 PCI to LPC Bridge
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:00.0 VGA compatible controller: ATI Technologies Inc Mobility Radeon HD 3400 Series
06:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 01)
07:00.0 Network controller: Atheros Communications Inc. AR5008 Wireless Network Adapter (rev 01)
08:01.0 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller (rev 05)
08:01.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 22)
08:01.2 System peripheral: Ricoh Co Ltd R5C843 MMC Host Controller (rev 12)
08:01.3 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 12)
08:01.4 System peripheral: Ricoh Co Ltd xD-Picture Card Controller (rev ff)Kod: Zaznacz cały
bartek@bartek:~$ cat /etc/apt/sources.list
#~~~~~~Squeeze~~~~~~#
deb [url]http://ftp.pl.debian.org/debian/[/url] squeeze main non-free contrib
deb-src [url]http://ftp.pl.debian.org/debian/[/url] squeeze main non-free contrib
deb [url]http://security.debian.org/[/url] squeeze/updates main contrib non-free
deb-src [url]http://security.debian.org/[/url] squeeze/updates main contrib non-free
#~~~~~~Debian-multimedia~~~~~~#
deb [url]http://www.debian-multimedia.org[/url] squeeze main
deb-src [url]http://www.debian-multimedia.org[/url] squeeze mainZapoznaj się z tym tematem:
http://debian.linux.pl/viewtopic.php?p=73083#73083
Mam Della Studio 1735 z radeonem HD 3650 i driver z strony wsparcia technicznego AMD-Ati (link) i nie miałem problemów z instalacją.
Podam ci mój xorg.conf wklej raczej powinno się uruchomić o ile masz prawidłowo zainstalowany sterownik.
Jedynie co sprawdź to sekcje device i BUS ID.
Podobną konfiguracje mam na stacjonarnym komputerze z zintegrowaną kartą grafiki ATI (płyta Gigabyte pod AMD 64).
# xorg.conf (X.Org X Window System server configuration file)
# package.
Section "ServerLayout"
Identifier "aticonfig Layout"
Screen 0 "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Files"
EndSection
Section "Module"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-0"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection
