Debugi.
klekSu
Debugi.
Post autor: klekSu »
To tylko niektóre logi, jest ich więcej =/. W czym rzecz? Prowider internetowy zmieniał sprzęt i od tamtej pory zaczęło siętak dziać.
Mar 27 12:05:28 debian kernel: [ 2635.085759] theforgottenser[7161]: segfault at 60 ip 576983 sp 422b1b10 error 4 in theforgottenserver[400000+1f4000]
Mar 27 14:40:03 debian kernel: imklog 3.18.6, log source = /proc/kmsg started.
Mar 27 14:40:03 debian rsyslogd: [origin software="rsyslogd" swVersion="3.18.6" x-pid="2497" x-info="http://www.rsyslog.com"] restart
Mar 27 14:40:03 debian kernel: [    0.000000] Initializing cgroup subsys cpuset
Mar 27 14:40:03 debian kernel: [    0.000000] Linux version 2.6.26-1-amd64 (Debian 2.6.26-13) (waldi@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-24)) #1 SMP Sat Jan 10 17:57:00 UTC 2009
Mar 27 14:40:03 debian kernel: [    0.000000] Command line: root=/dev/sda1 ro quiet
Mar 27 14:40:03 debian kernel: [    0.000000] BIOS-provided physical RAM map:
Mar 27 14:40:03 debian kernel: [    0.000000]  BIOS-e820: 0000000000000000 - 0000000000096c00 (usable)
Mar 27 14:40:03 debian kernel: [    0.000000]  BIOS-e820: 0000000000096c00 - 00000000000a0000 (reserved)
Mar 27 14:40:03 debian kernel: [    0.000000]  BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
Mar 27 14:40:03 debian kernel: [    0.000000]  BIOS-e820: 0000000000100000 - 00000000cff70000 (usable)
Mar 27 14:40:03 debian kernel: [    0.000000]  BIOS-e820: 00000000cff70000 - 00000000cff7e000 (ACPI data)
Mar 27 14:40:03 debian kernel: [    0.000000]  BIOS-e820: 00000000cff7e000 - 00000000cffd0000 (ACPI NVS)
Mar 27 14:40:03 debian kernel: [    0.000000]  BIOS-e820: 00000000cffd0000 - 00000000d0000000 (reserved)
Mar 27 14:40:03 debian kernel: [    0.000000]  BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Mar 27 14:40:03 debian kernel: [    0.000000]  BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
Mar 27 14:40:03 debian kernel: [    0.000000]  BIOS-e820: 0000000100000000 - 0000000230000000 (usable)
Mar 27 14:40:03 debian kernel: [    0.000000] max_pfn_mapped = 2293760
Mar 27 14:40:03 debian kernel: [    0.000000] init_memory_mapping
Mar 27 14:40:03 debian kernel: [    0.000000] DMI present.
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: RSDP 000FB410, 0014 (r0 ACPIAM)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: RSDT CFF70000, 003C (r1 A_M_I_ OEMRSDT  12000803 MSFT       97)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: FACP CFF70200, 0084 (r2 A_M_I_ OEMFACP  12000803 MSFT       97)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: DSDT CFF70440, 96E2 (r1  A1012 A1012001        1 INTL 20060113)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: FACS CFF7E000, 0040
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: APIC CFF70390, 006C (r1 A_M_I_ OEMAPIC  12000803 MSFT       97)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: MCFG CFF70400, 003C (r1 A_M_I_ OEMMCFG  12000803 MSFT       97)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: OEMB CFF7E040, 0089 (r1 A_M_I_ AMI_OEM  12000803 MSFT       97)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: HPET CFF79B30, 0038 (r1 A_M_I_ OEMHPET  12000803 MSFT       97)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: OSFR CFF79B70, 00B0 (r1 A_M_I_ OEMOSFR  12000803 MSFT       97)
Mar 27 14:40:03 debian kernel: [    0.000000] No NUMA configuration found
Mar 27 14:40:03 debian kernel: [    0.000000] Faking a node at 0000000000000000-0000000230000000
Mar 27 14:40:03 debian kernel: [    0.000000] Bootmem setup node 0 0000000000000000-0000000230000000
Mar 27 14:40:03 debian kernel: [    0.000000]   NODE_DATA [0000000000012000 - 0000000000016fff]
Mar 27 14:40:03 debian kernel: [    0.000000]   bootmap [0000000000017000 -  000000000005cfff] pages 46
Mar 27 14:40:03 debian kernel: [    0.000000]   early res: 0 [0-fff] BIOS data page
Mar 27 14:40:03 debian kernel: [    0.000000]   early res: 1 [6000-7fff] TRAMPOLINE
Mar 27 14:40:03 debian kernel: [    0.000000]   early res: 2 [200000-675397] TEXT DATA BSS
Mar 27 14:40:03 debian kernel: [    0.000000]   early res: 3 [3784f000-37fefa79] RAMDISK
Mar 27 14:40:03 debian kernel: [    0.000000]   early res: 4 [96c00-fffff] BIOS reserved
Mar 27 14:40:03 debian kernel: [    0.000000]   early res: 5 [8000-11fff] PGTABLE
Mar 27 14:40:03 debian kernel: [    0.000000] Zone PFN ranges:
Mar 27 14:40:03 debian kernel: [    0.000000]   DMA             0 ->     4096
Mar 27 14:40:03 debian kernel: [    0.000000]   DMA32        4096 ->  1048576
Mar 27 14:40:03 debian kernel: [    0.000000]   Normal    1048576 ->  2293760
Mar 27 14:40:03 debian kernel: [    0.000000] Movable zone start PFN for each node
Mar 27 14:40:03 debian kernel: [    0.000000] early_node_map[3] active PFN ranges
Mar 27 14:40:03 debian kernel: [    0.000000]     0:        0 ->      150
Mar 27 14:40:03 debian kernel: [    0.000000]     0:      256 ->   851824
Mar 27 14:40:03 debian kernel: [    0.000000]     0:  1048576 ->  2293760
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: PM-Timer IO Port: 0x808
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
Mar 27 14:40:03 debian kernel: [    0.000000] IOAPIC[0]: apic_id 4, version 0, address 0xfec00000, GSI 0-23
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Mar 27 14:40:03 debian kernel: [    0.000000] Setting APIC routing to flat
Mar 27 14:40:03 debian kernel: [    0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000
Mar 27 14:40:03 debian kernel: [    0.000000] Using ACPI (MADT) for SMP configuration information
Mar 27 14:40:03 debian kernel: [    0.000000] PM: Registered nosave memory: 0000000000096000 - 0000000000097000
Mar 27 14:40:03 debian kernel: [    0.000000] PM: Registered nosave memory: 0000000000097000 - 00000000000a0000
Mar 27 14:40:03 debian kernel: [    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
Mar 27 14:40:03 debian kernel: [    0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
Mar 27 14:40:03 debian kernel: [    0.000000] PM: Registered nosave memory: 00000000cff70000 - 00000000cff7e000
Mar 27 14:40:03 debian kernel: [    0.000000] PM: Registered nosave memory: 00000000cff7e000 - 00000000cffd0000
Mar 27 14:40:03 debian kernel: [    0.000000] PM: Registered nosave memory: 00000000cffd0000 - 00000000d0000000
Mar 27 14:40:03 debian kernel: [    0.000000] PM: Registered nosave memory: 00000000d0000000 - 00000000fee00000
Mar 27 14:40:03 debian kernel: [    0.000000] PM: Registered nosave memory: 00000000fee00000 - 00000000fee01000
Mar 27 14:40:03 debian kernel: [    0.000000] PM: Registered nosave memory: 00000000fee01000 - 00000000fff00000
Mar 27 14:40:03 debian kernel: [    0.000000] PM: Registered nosave memory: 00000000fff00000 - 0000000100000000
Mar 27 14:40:03 debian kernel: [    0.000000] Allocating PCI resources starting at d4000000 (gap: d0000000:2ee00000)
Mar 27 14:40:03 debian kernel: [    0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
Mar 27 14:40:03 debian kernel: [    0.000000] PERCPU: Allocating 37168 bytes of per cpu data
Mar 27 14:40:03 debian kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 2064281
Mar 27 14:40:03 debian kernel: [    0.000000] Policy zone: Normal
Mar 27 14:40:03 debian kernel: [    0.000000] Kernel command line: root=/dev/sda1 ro quiet
Mar 27 14:40:03 debian kernel: [    0.000000] Initializing CPU#0
Mar 27 14:40:03 debian kernel: [    0.000000] PID hash table entries: 4096 (order: 12, 32768 bytes)
Mar 27 14:40:03 debian kernel: [    0.000000] TSC calibrated against PM_TIMER
Mar 27 14:40:03 debian kernel: [    0.000000] time.c: Detected 2838.574 MHz processor.
Mar 27 14:40:03 debian kernel: [    0.004000] Console: colour VGA+ 80x25
Mar 27 14:40:03 debian kernel: [    0.004000] console [tty0] enabled
Mar 27 14:40:03 debian kernel: [    0.004000] Checking aperture...
Mar 27 14:40:03 debian kernel: [    0.004000] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Mar 27 14:40:03 debian kernel: [    0.004000] Placing software IO TLB between 0x4000000 - 0x8000000
Mar 27 14:40:03 debian kernel: [    0.004000] Memory: 8192008k/9175040k available (2226k kernel code, 195600k reserved, 1082k data, 392k init)
Mar 27 14:40:03 debian kernel: [    0.083834] Calibrating delay using timer specific routine.. 5681.01 BogoMIPS (lpj=11362029)
Mar 27 14:40:03 debian kernel: [    0.083862] Security Framework initialized
Mar 27 14:40:03 debian kernel: [    0.083866] SELinux:  Disabled at boot.
Mar 27 14:40:03 debian kernel: [    0.083868] Capability LSM initialized
Mar 27 14:40:03 debian kernel: [    0.084005] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
Mar 27 14:40:03 debian kernel: [    0.084005] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
Mar 27 14:40:03 debian kernel: [    0.085324] Mount-cache hash table entries: 256
Mar 27 14:40:03 debian kernel: [    0.085433] Initializing cgroup subsys ns
Mar 27 14:40:03 debian kernel: [    0.085436] Initializing cgroup subsys cpuacct
Mar 27 14:40:03 debian kernel: [    0.085438] Initializing cgroup subsys devices
Mar 27 14:40:03 debian kernel: [    0.085452] CPU: L1 I cache: 32K, L1 D cache: 32K
Mar 27 14:40:03 debian kernel: [    0.085453] CPU: L2 cache: 6144K
Mar 27 14:40:03 debian kernel: [    0.085455] CPU 0/0 -> Node 0
Mar 27 14:40:03 debian kernel: [    0.085456] CPU: Physical Processor ID: 0
Mar 27 14:40:03 debian kernel: [    0.085457] CPU: Processor Core ID: 0
Mar 27 14:40:03 debian kernel: [    0.085462] CPU0: Thermal monitoring enabled (TM2)
Mar 27 14:40:03 debian kernel: [    0.085463] using mwait in idle threads.
Mar 27 14:40:03 debian kernel: [    0.086189] ACPI: Core revision 20080321
Mar 27 14:40:03 debian kernel: [    0.135324] CPU0: Intel(R) Core(TM)2 Quad CPU    Q9550  @ 2.83GHz stepping 0a
Mar 27 14:40:03 debian kernel: [    0.135327] Using local APIC timer interrupts.
Mar 27 14:40:03 debian kernel: [    0.140008] Detected 20.871 MHz APIC timer.
Mar 27 14:40:03 debian kernel: [    0.140008] Booting processor 1/1 ip 6000
Mar 27 14:40:03 debian kernel: [    0.148009] Initializing CPU#1
Mar 27 14:40:03 debian kernel: [    0.148009] Calibrating delay using timer specific routine.. 5677.16 BogoMIPS (lpj=11354338)
Mar 27 14:40:03 debian kernel: [    0.148009] CPU: L1 I cache: 32K, L1 D cache: 32K
Mar 27 14:40:03 debian kernel: [    0.148009] CPU: L2 cache: 6144K
Mar 27 14:40:03 debian kernel: [    0.148009] CPU 1/1 -> Node 0
Mar 27 14:40:03 debian kernel: [    0.148009] CPU: Physical Processor ID: 0
Mar 27 14:40:03 debian kernel: [    0.148009] CPU: Processor Core ID: 1
Mar 27 14:40:03 debian kernel: [    0.148009] CPU1: Thermal monitoring enabled (TM2)
Mar 27 14:40:03 debian kernel: [    0.228014] CPU1: Intel(R) Core(TM)2 Quad CPU    Q9550  @ 2.83GHz stepping 0a
Mar 27 14:40:03 debian kernel: [    0.228014] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
Mar 27 14:40:03 debian kernel: [    0.232014] Booting processor 2/2 ip 6000
Mar 27 14:40:03 debian kernel: [    0.240015] Initializing CPU#2
Mar 27 14:40:03 debian kernel: [    0.240015] Calibrating delay using timer specific routine.. 5677.18 BogoMIPS (lpj=11354372)
Mar 27 14:40:03 debian kernel: [    0.240015] CPU: L1 I cache: 32K, L1 D cache: 32K
Mar 27 14:40:03 debian kernel: [    0.240015] CPU: L2 cache: 6144K
Mar 27 14:40:03 debian kernel: [    0.240015] CPU 2/2 -> Node 0
Mar 27 14:40:03 debian kernel: [    0.240015] CPU: Physical Processor ID: 0
Mar 27 14:40:03 debian kernel: [    0.240015] CPU: Processor Core ID: 2
Mar 27 14:40:03 debian kernel: [    0.240015] CPU2: Thermal monitoring enabled (TM2)
Mar 27 14:40:03 debian kernel: [    0.319736] CPU2: Intel(R) Core(TM)2 Quad CPU    Q9550  @ 2.83GHz stepping 0a
Mar 27 14:40:03 debian kernel: [    0.319751] checking TSC synchronization [CPU#0 -> CPU#2]: passed.
Mar 27 14:40:03 debian kernel: [    0.324020] Booting processor 3/3 ip 6000
Mar 27 14:40:03 debian kernel: [    0.332020] Initializing CPU#3
Mar 27 14:40:03 debian kernel: [    0.332020] Calibrating delay using timer specific routine.. 5677.18 BogoMIPS (lpj=11354371)
Mar 27 14:40:03 debian kernel: [    0.332020] CPU: L1 I cache: 32K, L1 D cache: 32K
Mar 27 14:40:03 debian kernel: [    0.332020] CPU: L2 cache: 6144K
Mar 27 14:40:03 debian kernel: [    0.332020] CPU 3/3 -> Node 0
Mar 27 14:40:03 debian kernel: [    0.332020] CPU: Physical Processor ID: 0
Mar 27 14:40:03 debian kernel: [    0.332020] CPU: Processor Core ID: 3
Mar 27 14:40:03 debian kernel: [    0.332020] CPU3: Thermal monitoring enabled (TM2)
Mar 27 14:40:03 debian kernel: [    0.411739] CPU3: Intel(R) Core(TM)2 Quad CPU    Q9550  @ 2.83GHz stepping 0a
Mar 27 14:40:03 debian kernel: [    0.411754] checking TSC synchronization [CPU#0 -> CPU#3]: passed.
Mar 27 14:40:03 debian kernel: [    0.416026] Brought up 4 CPUs
Mar 27 14:40:03 debian kernel: [    0.416026] Total of 4 processors activated (22712.55 BogoMIPS).
Mar 27 14:40:03 debian kernel: [    0.416026] net_namespace: 1224 bytes
Mar 27 14:40:03 debian kernel: [    0.416026] Booting paravirtualized kernel on bare hardware
Mar 27 14:40:03 debian kernel: [    0.416026] NET: Registered protocol family 16
Mar 27 14:40:03 debian kernel: [    0.416026] ACPI: bus type pci registered
Mar 27 14:40:03 debian kernel: [    0.416026] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
Mar 27 14:40:03 debian kernel: [    0.416026] PCI: Using configuration type 1 for base access
Mar 27 14:40:03 debian kernel: [    0.431296] ACPI: Interpreter enabled
Mar 27 14:40:03 debian kernel: [    0.431296] ACPI: (supports S0 S1 S3 S4 S5)
Mar 27 14:40:03 debian kernel: [    0.431296] ACPI: Using IOAPIC for interrupt routing
Mar 27 14:40:03 debian kernel: [    0.431340] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
Mar 27 14:40:03 debian kernel: [    0.433550] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources
Mar 27 14:40:03 debian kernel: [    0.443035] PCI: Using MMCONFIG at e0000000 - efffffff
Mar 27 14:40:03 debian kernel: [    0.451297] ACPI: PCI Root Bridge [PCI0] (0000:00)
Mar 27 14:40:03 debian kernel: [    0.454385] PCI: Transparent bridge - 0000:00:1e.0
Mar 27 14:40:03 debian kernel: [    0.469309] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Mar 27 14:40:03 debian kernel: [    0.469309] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Mar 27 14:40:03 debian kernel: [    0.469309] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Mar 27 14:40:03 debian kernel: [    0.469309] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *7 10 11 12 14 15)
Mar 27 14:40:03 debian kernel: [    0.469309] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Mar 27 14:40:03 debian kernel: [    0.469309] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 *15)
Mar 27 14:40:03 debian kernel: [    0.469309] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 *14 15)
Mar 27 14:40:03 debian kernel: [    0.469405] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 7 10 11 12 14 15)
Mar 27 14:40:03 debian kernel: [    0.473309] ACPI Warning (tbutils-0217): Incorrect checksum in table [OEMB] - C9, should be C8 [20080321]
Mar 27 14:40:03 debian kernel: [    0.473309] Linux Plug and Play Support v0.97 (c) Adam Belay
Mar 27 14:40:03 debian kernel: [    0.473309] pnp: PnP ACPI init
Mar 27 14:40:03 debian kernel: [    0.473309] ACPI: bus type pnp registered
Mar 27 14:40:03 debian kernel: [    0.473309] pnp: PnP ACPI: found 17 devices
Mar 27 14:40:03 debian kernel: [    0.473309] ACPI: ACPI bus type pnp unregistered
Mar 27 14:40:03 debian kernel: [    0.473896] usbcore: registered new interface driver usbfs
Mar 27 14:40:03 debian kernel: [    0.477309] usbcore: registered new interface driver hub
Mar 27 14:40:03 debian kernel: [    0.477309] usbcore: registered new device driver usb
Mar 27 14:40:03 debian kernel: [    0.477309] PCI: Using ACPI for IRQ routing
Mar 27 14:40:03 debian kernel: [    0.493266] PCI-GART: No AMD northbridge found.
Mar 27 14:40:03 debian kernel: [    0.493270] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
Mar 27 14:40:03 debian kernel: [    0.493274] hpet0: 4 64-bit timers, 14318180 Hz
Mar 27 14:40:03 debian kernel: [    0.497247] ACPI: RTC can wake from S4
Mar 27 14:40:03 debian kernel: [    0.512137] system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved
Mar 27 14:40:03 debian kernel: [    0.512148] system 00:06: ioport range 0x290-0x29f has been reserved
Mar 27 14:40:03 debian kernel: [    0.512155] system 00:07: ioport range 0x4d0-0x4d1 has been reserved
Mar 27 14:40:03 debian kernel: [    0.512157] system 00:07: ioport range 0x800-0x87f has been reserved
Mar 27 14:40:03 debian kernel: [    0.512160] system 00:07: ioport range 0x500-0x57f has been reserved
Mar 27 14:40:03 debian kernel: [    0.512162] system 00:07: iomem range 0xfed08000-0xfed08fff has been reserved
Mar 27 14:40:03 debian kernel: [    0.512165] system 00:07: iomem range 0xfed1c000-0xfed1ffff has been reserved
Mar 27 14:40:03 debian kernel: [    0.512168] system 00:07: iomem range 0xfed20000-0xfed3ffff has been reserved
Mar 27 14:40:03 debian kernel: [    0.512170] system 00:07: iomem range 0xfed50000-0xfed8ffff has been reserved
Mar 27 14:40:03 debian kernel: [    0.512178] system 00:0a: iomem range 0xffc00000-0xffefffff has been reserved
Mar 27 14:40:03 debian kernel: [    0.512186] system 00:0c: iomem range 0xfec00000-0xfec00fff has been reserved
Mar 27 14:40:03 debian kernel: [    0.512189] system 00:0c: iomem range 0xfee00000-0xfee00fff could not be reserved
Mar 27 14:40:03 debian kernel: [    0.512196] system 00:0f: iomem range 0xe0000000-0xefffffff has been reserved
Mar 27 14:40:03 debian kernel: [    0.512203] system 00:10: iomem range 0x0-0x9ffff could not be reserved
Mar 27 14:40:03 debian kernel: [    0.512206] system 00:10: iomem range 0xc0000-0xcffff has been reserved
Mar 27 14:40:03 debian kernel: [    0.512209] system 00:10: iomem range 0xe0000-0xfffff could not be reserved
Mar 27 14:40:03 debian kernel: [    0.512211] system 00:10: iomem range 0x100000-0xcfffffff could not be reserved
Mar 27 14:40:03 debian kernel: [    0.512214] system 00:10: iomem range 0xe0000000-0xffffffff could not be reserved
Mar 27 14:40:03 debian kernel: [    0.513954] PCI: Bridge: 0000:00:01.0
Mar 27 14:40:03 debian kernel: [    0.513954]   IO window: disabled.
Mar 27 14:40:03 debian kernel: [    0.513954]   MEM window: 0xfc000000-0xfe9fffff
Mar 27 14:40:03 debian kernel: [    0.513954]   PREFETCH window: 0x00000000d0000000-0x00000000dfffffff
Mar 27 14:40:03 debian kernel: [    0.513954] PCI: Bridge: 0000:00:1c.0
Mar 27 14:40:03 debian kernel: [    0.513954]   MEM window: disabled.
Mar 27 14:40:03 debian kernel: [    0.513954]   PREFETCH window: 0x00000000faf00000-0x00000000faffffff
Mar 27 14:40:03 debian kernel: [    0.513954] PCI: Bridge: 0000:00:1c.5
Mar 27 14:40:03 debian kernel: [    0.513954]   IO window: d000-dfff
Mar 27 14:40:03 debian kernel: [    0.513954]   MEM window: 0xfea00000-0xfeafffff
Mar 27 14:40:03 debian kernel: [    0.513954]   PREFETCH window: disabled.
Mar 27 14:40:03 debian kernel: [    0.513954] PCI: Bridge: 0000:00:1e.0
Mar 27 14:40:03 debian kernel: [    0.513954]   IO window: e000-efff
Mar 27 14:40:03 debian kernel: [    0.513954]   MEM window: 0xfeb00000-0xfebfffff
Mar 27 14:40:03 debian kernel: [    0.513954]   PREFETCH window: 0x00000000f0000000-0x00000000f00fffff
Mar 27 14:40:03 debian kernel: [    0.513954] ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 16
Mar 27 14:40:03 debian kernel: [    0.513954] ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 17 (level, low) -> IRQ 17
Mar 27 14:40:03 debian kernel: [    0.513954] ACPI: PCI Interrupt 0000:00:1c.5[b] -> GSI 16 (level, low) -> IRQ 16
Mar 27 14:40:03 debian kernel: [    0.513954] NET: Registered protocol family 2
Mar 27 14:40:03 debian kernel: [    0.558269] IP route cache hash table entries: 262144 (order: 9, 2097152 bytes)
Mar 27 14:40:03 debian kernel: [    0.558269] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
Mar 27 14:40:03 debian kernel: [    0.558269] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Mar 27 14:40:03 debian kernel: [    0.558269] TCP: Hash tables configured (established 524288 bind 65536)
Mar 27 14:40:03 debian kernel: [    0.558269] TCP reno registered
Mar 27 14:40:03 debian kernel: [    0.577212] NET: Registered protocol family 1
Mar 27 14:40:03 debian kernel: [    0.577315] checking if image is initramfs... it is
Mar 27 14:40:03 debian kernel: [    1.027632] Freeing initrd memory: 7810k freed
Mar 27 14:40:03 debian kernel: [    1.030971] audit: initializing netlink socket (disabled)
Mar 27 14:40:03 debian kernel: [    1.030971] type=2000 audit(1238161187.012:1): initialized
Mar 27 14:40:03 debian kernel: [    1.036500] Total HugeTLB memory allocated, 0
Mar 27 14:40:03 debian kernel: [    1.036500] VFS: Disk quotas dquot_6.5.1
Mar 27 14:40:03 debian kernel: [    1.036500] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Mar 27 14:40:03 debian kernel: [    1.036500] msgmni has been set to 16015
Mar 27 14:40:03 debian kernel: [    1.036500] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
Mar 27 14:40:03 debian kernel: [    1.036500] io scheduler noop registered
Mar 27 14:40:03 debian kernel: [    1.036500] io scheduler anticipatory registered
Mar 27 14:40:03 debian kernel: [    1.036500] io scheduler deadline registered
Mar 27 14:40:03 debian kernel: [    1.036500] io scheduler cfq registered (default)
Mar 27 14:40:03 debian kernel: [    1.036500] assign_interrupt_mode Found MSI capability
Mar 27 14:40:03 debian kernel: [    1.036514] Linux agpgart interface v0.103
Mar 27 14:40:03 debian kernel: [    1.036514] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Mar 27 14:40:03 debian kernel: [    1.036514] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Mar 27 14:40:03 debian kernel: [    1.036514] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Mar 27 14:40:03 debian kernel: [    1.040441] brd: module loaded
Mar 27 14:40:03 debian kernel: [    1.040441] input: Macintosh mouse button emulation as /class/input/input0
Mar 27 14:40:03 debian kernel: [    1.040441] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
Mar 27 14:40:03 debian kernel: [    1.045007] serio: i8042 KBD port at 0x60,0x64 irq 1
Mar 27 14:40:03 debian kernel: [    1.045007] serio: i8042 AUX port at 0x60,0x64 irq 12
Mar 27 14:40:03 debian kernel: [    1.063800] mice: PS/2 mouse device common for all mice
Mar 27 14:40:03 debian kernel: [    1.063800] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
Mar 27 14:40:03 debian kernel: [    1.063800] rtc0: alarms up to one month, y3k
Mar 27 14:40:03 debian kernel: [    1.063800] cpuidle: using governor ladder
Mar 27 14:40:03 debian kernel: [    1.063800] cpuidle: using governor menu
Mar 27 14:40:03 debian kernel: [    1.063800] No iBFT detected.
Mar 27 14:40:03 debian kernel: [    1.063800] TCP cubic registered
Mar 27 14:40:03 debian kernel: [    1.063800] NET: Registered protocol family 17
Mar 27 14:40:03 debian kernel: [    1.063800] registered taskstats version 1
Mar 27 14:40:03 debian kernel: [    1.063800] rtc_cmos 00:03: setting system clock to 2009-03-27 13:39:47 UTC (1238161187)
Mar 27 14:40:03 debian kernel: [    1.063800] Freeing unused kernel memory: 392k freed
Mar 27 14:40:03 debian kernel: [    1.082107] input: AT Translated Set 2 keyboard as /class/input/input1
Mar 27 14:40:03 debian kernel: [    1.127197] ACPI: ACPI0007:00 is registered as cooling_device0
Mar 27 14:40:03 debian kernel: [    1.127197] ACPI: ACPI0007:01 is registered as cooling_device1
Mar 27 14:40:03 debian kernel: [    1.127197] ACPI: ACPI0007:02 is registered as cooling_device2
Mar 27 14:40:03 debian kernel: [    1.127197] ACPI: ACPI0007:03 is registered as cooling_device3
Mar 27 14:40:03 debian kernel: [    1.229900] USB Universal Host Controller Interface driver v3.0
Mar 27 14:40:03 debian kernel: [    1.229900] ACPI: PCI Interrupt 0000:00:1a.0[A] -> GSI 16 (level, low) -> IRQ 16
Mar 27 14:40:03 debian kernel: [    1.229900] uhci_hcd 0000:00:1a.0: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.229900] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
Mar 27 14:40:03 debian kernel: [    1.229900] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000c800
Mar 27 14:40:03 debian kernel: [    1.229900] usb usb1: configuration #1 chosen from 1 choice
Mar 27 14:40:03 debian kernel: [    1.229900] hub 1-0:1.0: USB hub found
Mar 27 14:40:03 debian kernel: [    1.229900] hub 1-0:1.0: 2 ports detected
Mar 27 14:40:03 debian kernel: [    1.255884] No dock devices found.
Mar 27 14:40:03 debian kernel: [    1.255884] SCSI subsystem initialized
Mar 27 14:40:03 debian kernel: [    1.340531] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
Mar 27 14:40:03 debian kernel: [    1.340531] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 27 14:40:03 debian kernel: [    1.340531] usb usb1: Product: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.340531] usb usb1: Manufacturer: Linux 2.6.26-1-amd64 uhci_hcd
Mar 27 14:40:03 debian kernel: [    1.340531] usb usb1: SerialNumber: 0000:00:1a.0
Mar 27 14:40:03 debian kernel: [    1.340531] ACPI: PCI Interrupt 0000:00:1a.1[b] -> GSI 21 (level, low) -> IRQ 21
Mar 27 14:40:03 debian kernel: [    1.340531] uhci_hcd 0000:00:1a.1: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.340531] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
Mar 27 14:40:03 debian kernel: [    1.340531] uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000c880
Mar 27 14:40:03 debian kernel: [    1.340531] usb usb2: configuration #1 chosen from 1 choice
Mar 27 14:40:03 debian kernel: [    1.340531] hub 2-0:1.0: USB hub found
Mar 27 14:40:03 debian kernel: [    1.340531] hub 2-0:1.0: 2 ports detected
Mar 27 14:40:03 debian kernel: [    1.445666] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
Mar 27 14:40:03 debian kernel: [    1.445666] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 27 14:40:03 debian kernel: [    1.445666] usb usb2: Product: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.445666] usb usb2: Manufacturer: Linux 2.6.26-1-amd64 uhci_hcd
Mar 27 14:40:03 debian kernel: [    1.445666] usb usb2: SerialNumber: 0000:00:1a.1
Mar 27 14:40:03 debian kernel: [    1.445666] ACPI: PCI Interrupt 0000:00:1a.2[C] -> GSI 18 (level, low) -> IRQ 18
Mar 27 14:40:03 debian kernel: [    1.445666] uhci_hcd 0000:00:1a.2: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.445666] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 3
Mar 27 14:40:03 debian kernel: [    1.445666] uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000cc00
Mar 27 14:40:03 debian kernel: [    1.445666] usb usb3: configuration #1 chosen from 1 choice
Mar 27 14:40:03 debian kernel: [    1.445666] hub 3-0:1.0: USB hub found
Mar 27 14:40:03 debian kernel: [    1.445666] hub 3-0:1.0: 2 ports detected
Mar 27 14:40:03 debian kernel: [    1.577678] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
Mar 27 14:40:03 debian kernel: [    1.577678] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 27 14:40:03 debian kernel: [    1.577678] usb usb3: Product: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.577678] usb usb3: Manufacturer: Linux 2.6.26-1-amd64 uhci_hcd
Mar 27 14:40:03 debian kernel: [    1.577678] usb usb3: SerialNumber: 0000:00:1a.2
Mar 27 14:40:03 debian kernel: [    1.577678] ACPI: PCI Interrupt 0000:00:1a.7[C] -> GSI 18 (level, low) -> IRQ 18
Mar 27 14:40:03 debian kernel: [    1.577678] ehci_hcd 0000:00:1a.7: EHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.577678] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 4
Mar 27 14:40:03 debian kernel: [    1.581666] ehci_hcd 0000:00:1a.7: debug port 1
Mar 27 14:40:03 debian kernel: [    1.581673] ehci_hcd 0000:00:1a.7: irq 18, io mem 0xfbfffc00
Mar 27 14:40:03 debian kernel: [    1.595058] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Mar 27 14:40:03 debian kernel: [    1.595103] usb usb4: configuration #1 chosen from 1 choice
Mar 27 14:40:03 debian kernel: [    1.595128] hub 4-0:1.0: USB hub found
Mar 27 14:40:03 debian kernel: [    1.595133] hub 4-0:1.0: 6 ports detected
Mar 27 14:40:03 debian kernel: [    1.699127] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
Mar 27 14:40:03 debian kernel: [    1.699129] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 27 14:40:03 debian kernel: [    1.699131] usb usb4: Product: EHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.699133] usb usb4: Manufacturer: Linux 2.6.26-1-amd64 ehci_hcd
Mar 27 14:40:03 debian kernel: [    1.699135] usb usb4: SerialNumber: 0000:00:1a.7
Mar 27 14:40:03 debian kernel: [    1.699058] ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 23
Mar 27 14:40:03 debian kernel: [    1.699058] uhci_hcd 0000:00:1d.0: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.699058] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
Mar 27 14:40:03 debian kernel: [    1.699058] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000c080
Mar 27 14:40:03 debian kernel: [    1.699058] usb usb5: configuration #1 chosen from 1 choice
Mar 27 14:40:03 debian kernel: [    1.699058] hub 5-0:1.0: USB hub found
Mar 27 14:40:03 debian kernel: [    1.699058] hub 5-0:1.0: 2 ports detected
Mar 27 14:40:03 debian kernel: [    1.811983] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
Mar 27 14:40:03 debian kernel: [    1.811983] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 27 14:40:03 debian kernel: [    1.811983] usb usb5: Product: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.811983] usb usb5: Manufacturer: Linux 2.6.26-1-amd64 uhci_hcd
Mar 27 14:40:03 debian kernel: [    1.811983] usb usb5: SerialNumber: 0000:00:1d.0
Mar 27 14:40:03 debian kernel: [    1.811983] ACPI: PCI Interrupt 0000:00:1d.1[b] -> GSI 19 (level, low) -> IRQ 19
Mar 27 14:40:03 debian kernel: [    1.811983] uhci_hcd 0000:00:1d.1: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.811983] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
Mar 27 14:40:03 debian kernel: [    1.811983] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000c400
Mar 27 14:40:03 debian kernel: [    1.811983] usb usb6: configuration #1 chosen from 1 choice
Mar 27 14:40:03 debian kernel: [    1.811983] hub 6-0:1.0: USB hub found
Mar 27 14:40:03 debian kernel: [    1.811983] hub 6-0:1.0: 2 ports detected
Mar 27 14:40:03 debian kernel: [    1.926978] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
Mar 27 14:40:03 debian kernel: [    1.926978] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 27 14:40:03 debian kernel: [    1.926978] usb usb6: Product: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.926978] usb usb6: Manufacturer: Linux 2.6.26-1-amd64 uhci_hcd
Mar 27 14:40:03 debian kernel: [    1.926978] usb usb6: SerialNumber: 0000:00:1d.1
Mar 27 14:40:03 debian kernel: [    1.926978] ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 18
Mar 27 14:40:03 debian kernel: [    1.926978] uhci_hcd 0000:00:1d.2: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    1.926978] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
Mar 27 14:40:03 debian kernel: [    1.926978] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000c480
Mar 27 14:40:03 debian kernel: [    1.926978] usb usb7: configuration #1 chosen from 1 choice
Mar 27 14:40:03 debian kernel: [    1.926978] hub 7-0:1.0: USB hub found
Mar 27 14:40:03 debian kernel: [    1.926978] hub 7-0:1.0: 2 ports detected
Mar 27 14:40:03 debian kernel: [    2.030978] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
Mar 27 14:40:03 debian kernel: [    2.030978] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 27 14:40:03 debian kernel: [    2.030978] usb usb7: Product: UHCI Host Controller
Mar 27 14:40:03 debian kernel: [    2.030978] usb usb7: Manufacturer: Linux 2.6.26-1-amd64 uhci_hcd
Mar 27 14:40:03 debian kernel: [    2.030978] usb usb7: SerialNumber: 0000:00:1d.2
Mar 27 14:40:03 debian kernel: [    2.032481] ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 23
Mar 27 14:40:03 debian kernel: [    2.032481] ehci_hcd 0000:00:1d.7: EHCI Host Controller
Mar 27 14:40:03 debian kernel: [    2.032481] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 8
Mar 27 14:40:03 debian kernel: [    2.035094] ehci_hcd 0000:00:1d.7: debug port 1
Mar 27 14:40:03 debian kernel: [    2.035101] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xfbfff800
Mar 27 14:40:03 debian kernel: [    2.056482] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Mar 27 14:40:03 debian kernel: [    2.056529] usb usb8: configuration #1 chosen from 1 choice
Mar 27 14:40:03 debian kernel: [    2.056553] hub 8-0:1.0: USB hub found
Mar 27 14:40:03 debian kernel: [    2.056558] hub 8-0:1.0: 6 ports detected
Mar 27 14:40:03 debian kernel: [    2.162947] usb usb8: New USB device found, idVendor=1d6b, idProduct=0002
Mar 27 14:40:03 debian kernel: [    2.162949] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mar 27 14:40:03 debian kernel: [    2.162951] usb usb8: Product: EHCI Host Controller
Mar 27 14:40:03 debian kernel: [    2.162953] usb usb8: Manufacturer: Linux 2.6.26-1-amd64 ehci_hcd
Mar 27 14:40:03 debian kernel: [    2.162955] usb usb8: SerialNumber: 0000:00:1d.7
Mar 27 14:40:03 debian kernel: [    2.164482] ACPI: PCI Interrupt 0000:00:1f.2[b] -> GSI 19 (level, low) -> IRQ 19
Mar 27 14:40:03 debian kernel: [    3.213705] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl RAID mode
Mar 27 14:40:03 debian kernel: [    3.213709] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part
Mar 27 14:40:03 debian kernel: [    3.214832] scsi0 : ahci
Mar 27 14:40:03 debian kernel: [    3.214832] scsi1 : ahci
Mar 27 14:40:03 debian kernel: [    3.214832] scsi2 : ahci
Mar 27 14:40:03 debian kernel: [    3.214832] scsi3 : ahci
Mar 27 14:40:03 debian kernel: [    3.214832] scsi4 : ahci
Mar 27 14:40:03 debian kernel: [    3.214832] scsi5 : ahci
Mar 27 14:40:03 debian kernel: [    3.214832] ata1: SATA max UDMA/133 abar m2048@0xfbffe800 port 0xfbffe900 irq 1276
Mar 27 14:40:03 debian kernel: [    3.214832] ata2: SATA max UDMA/133 abar m2048@0xfbffe800 port 0xfbffe980 irq 1276
Mar 27 14:40:03 debian kernel: [    3.214832] ata3: SATA max UDMA/133 abar m2048@0xfbffe800 port 0xfbffea00 irq 1276
Mar 27 14:40:03 debian kernel: [    3.214832] ata4: SATA max UDMA/133 abar m2048@0xfbffe800 port 0xfbffea80 irq 1276
Mar 27 14:40:03 debian kernel: [    3.214832] ata5: SATA max UDMA/133 abar m2048@0xfbffe800 port 0xfbffeb00 irq 1276
Mar 27 14:40:03 debian kernel: [    3.214832] ata6: SATA max UDMA/133 abar m2048@0xfbffe800 port 0xfbffeb80 irq 1276
Mar 27 14:40:03 debian kernel: [    3.809794] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Mar 27 14:40:03 debian kernel: [    3.809794] ata1.00: ATA-7: SAMSUNG HD252HJ, 1AC01113, max UDMA7
Mar 27 14:40:03 debian kernel: [    3.809794] ata1.00: 488397168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Mar 27 14:40:03 debian kernel: [    3.821785] ata1.00: configured for UDMA/133
Mar 27 14:40:03 debian kernel: [    4.390314] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Mar 27 14:40:03 debian kernel: [    4.476087] ata2.00: ATA-7: SAMSUNG HD252HJ, 1AC01113, max UDMA7
Mar 27 14:40:03 debian kernel: [    4.476087] ata2.00: 488397168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Mar 27 14:40:03 debian kernel: [    4.476087] ata2.00: configured for UDMA/133
Mar 27 14:40:03 debian kernel: [    4.976109] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Mar 27 14:40:03 debian kernel: [    4.976102] ata3.00: ATA-7: SAMSUNG HD252HJ, 1AC01113, max UDMA7
Mar 27 14:40:03 debian kernel: [    4.976102] ata3.00: 488397168 sectors, multi 0: LBA48 NCQ (depth 31/32)
Mar 27 14:40:03 debian kernel: [    4.976102] ata3.00: configured for UDMA/133
Mar 27 14:40:03 debian kernel: [    5.724106] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Mar 27 14:40:03 debian kernel: [    4.976102] ata4.00: ATAPI: HL-DT-ST DVDRAM GH22NS40, NL00, max UDMA/100
Mar 27 14:40:03 debian kernel: [    5.724098] ata4.00: configured for UDMA/100
Mar 27 14:40:03 debian kernel: [    6.152077] ata5: SATA link down (SStatus 0 SControl 300)
Mar 27 14:40:03 debian kernel: [    6.488077] ata6: SATA link down (SStatus 0 SControl 300)
Mar 27 14:40:03 debian kernel: [    6.504068] scsi 0:0:0:0: Direct-Access     ATA      SAMSUNG HD252HJ  1AC0 PQ: 0 ANSI: 5
Mar 27 14:40:03 debian kernel: [    6.504068] scsi 1:0:0:0: Direct-Access     ATA      SAMSUNG HD252HJ  1AC0 PQ: 0 ANSI: 5
Mar 27 14:40:03 debian kernel: [    6.504068] scsi 2:0:0:0: Direct-Access     ATA      SAMSUNG HD252HJ  1AC0 PQ: 0 ANSI: 5
Mar 27 14:40:03 debian kernel: [    6.507618] scsi 3:0:0:0: CD-ROM            HL-DT-ST DVDRAM GH22NS40  NL00 PQ: 0 ANSI: 5
Mar 27 14:40:03 debian kernel: [    6.509568] ACPI: PCI Interrupt 0000:02:00.0[A] -> GSI 17 (level, low) -> IRQ 17
Mar 27 14:40:03 debian kernel: [    6.941098] r8169 Gigabit Ethernet driver 2.2LK-NAPI loaded
Mar 27 14:40:03 debian kernel: [    6.941098] ACPI: PCI Interrupt 0000:04:00.0[A] -> GSI 16 (level, low) -> IRQ 16
Mar 27 14:40:03 debian kernel: [    6.941098] eth1: RTL8169sb/8110sb at 0xffffc20000c38c00, 00:1f:1f:04:63:4c, XID 10000000 IRQ 16
Mar 27 14:40:03 debian kernel: [    6.941098] ACPI: PCI Interrupt 0000:04:01.0[A] -> GSI 17 (level, low) -> IRQ 17
Mar 27 14:40:03 debian kernel: [    6.941098] eth2: RTL8169sb/8110sb at 0xffffc20000c3a800, 00:1f:1f:15:13:65, XID 10000000 IRQ 17
Mar 27 14:40:03 debian kernel: [    6.941098] ACPI: PCI Interrupt 0000:04:03.0[A] -> GSI 19 (level, low) -> IRQ 19
Mar 27 14:40:03 debian kernel: [    6.994080] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[19]  MMIO=[febfe000-febfe7ff]  Max Packet=[2048]  IR/IT contexts=[8/8]
Mar 27 14:40:03 debian kernel: [    7.002073] Driver 'sd' needs updating - please use bus_type methods
Mar 27 14:40:03 debian kernel: [    7.002073] sd 0:0:0:0: [sda] 488397168 512-byte hardware sectors (250059 MB)
Mar 27 14:40:03 debian kernel: [    7.002073] sd 0:0:0:0: [sda] Write Protect is off
Mar 27 14:40:03 debian kernel: [    7.002073] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Mar 27 14:40:03 debian kernel: [    7.002073]  sda:<4>Driver 'sr' needs updating - please use bus_type methods
Mar 27 14:40:03 debian kernel: [    7.012383]  sda1 sda2 < sda5 sda6 sda7 sda8 sda9 >
Mar 27 14:40:03 debian kernel: [    7.079397] sd 0:0:0:0: [sda] Attached SCSI disk
Mar 27 14:40:03 debian kernel: [    7.079397] sd 1:0:0:0: [sdb] 488397168 512-byte hardware sectors (250059 MB)
Mar 27 14:40:03 debian kernel: [    7.079397] sd 1:0:0:0: [sdb] Write Protect is off
Mar 27 14:40:03 debian kernel: [    7.079397] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Mar 27 14:40:03 debian kernel: [    7.079397]  sdb: unknown partition table
Mar 27 14:40:03 debian kernel: [    7.079397] sd 1:0:0:0: [sdb] Attached SCSI disk
Mar 27 14:40:03 debian kernel: [    7.079397] sd 2:0:0:0: [sdc] 488397168 512-byte hardware sectors (250059 MB)
Mar 27 14:40:03 debian kernel: [    7.079397] sd 2:0:0:0: [sdc] Write Protect is off
Mar 27 14:40:03 debian kernel: [    7.079397] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Mar 27 14:40:03 debian kernel: [    7.079397]  sdc: unknown partition table
Mar 27 14:40:03 debian kernel: [    7.127590] sd 2:0:0:0: [sdc] Attached SCSI disk
Mar 27 14:40:03 debian kernel: [    7.144487] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
Mar 27 14:40:03 debian kernel: [    7.144487] Uniform CD-ROM driver Revision: 3.20
Mar 27 14:40:03 debian kernel: [    7.146260] sd 0:0:0:0: Attached scsi generic sg0 type 0
Mar 27 14:40:03 debian kernel: [    7.146276] sd 1:0:0:0: Attached scsi generic sg1 type 0
Mar 27 14:40:03 debian kernel: [    7.146291] sd 2:0:0:0: Attached scsi generic sg2 type 0
Mar 27 14:40:03 debian kernel: [    7.146305] sr 3:0:0:0: Attached scsi generic sg3 type 5
Mar 27 14:40:03 debian kernel: [    7.434649] md: linear personality registered for level -1
Mar 27 14:40:03 debian kernel: [    7.434649] md: multipath personality registered for level -4
Mar 27 14:40:03 debian kernel: [    7.437616] md: raid0 personality registered for level 0
Mar 27 14:40:03 debian kernel: [    7.438650] md: raid1 personality registered for level 1
Mar 27 14:40:03 debian kernel: [    7.438650] xor: automatically using best checksumming function: generic_sse
Mar 27 14:40:03 debian kernel: [    7.462482]    generic_sse: 10834.000 MB/sec
Mar 27 14:40:03 debian kernel: [    7.462482] xor: using function: generic_sse (10834.000 MB/sec)
Mar 27 14:40:03 debian kernel: [    7.462482] async_tx: api initialized (async)
Mar 27 14:40:03 debian kernel: [    7.533149] raid6: int64x1   2629 MB/s
Mar 27 14:40:03 debian kernel: [    7.601149] raid6: int64x2   3532 MB/s
Mar 27 14:40:03 debian kernel: [    7.669149] raid6: int64x4   3105 MB/s
Mar 27 14:40:03 debian kernel: [    7.737150] raid6: int64x8   1991 MB/s
Mar 27 14:40:03 debian kernel: [    7.805150] raid6: sse2x1    4776 MB/s
Mar 27 14:40:03 debian kernel: [    7.873150] raid6: sse2x2    5287 MB/s
Mar 27 14:40:03 debian kernel: [    7.941150] raid6: sse2x4    8458 MB/s
Mar 27 14:40:03 debian kernel: [    7.941150] raid6: using algorithm sse2x4 (8458 MB/s)
Mar 27 14:40:03 debian kernel: [    7.941150] md: raid6 personality registered for level 6
Mar 27 14:40:03 debian kernel: [    7.941150] md: raid5 personality registered for level 5
Mar 27 14:40:03 debian kernel: [    7.941150] md: raid4 personality registered for level 4
Mar 27 14:40:03 debian kernel: [    7.954444] md: raid10 personality registered for level 10
Mar 27 14:40:03 debian kernel: [    7.990770] md: bind<sdc>
Mar 27 14:40:03 debian kernel: [    7.990770] md: bind<sdb>
Mar 27 14:40:03 debian kernel: [    7.996219] md0: setting max_sectors to 32, segment boundary to 8191
Mar 27 14:40:03 debian kernel: [    7.996221] raid0: looking at sdb
Mar 27 14:40:03 debian kernel: [    7.996222] raid0:   comparing sdb(244198464) with sdb(244198464)
Mar 27 14:40:03 debian kernel: [    7.996224] raid0:   END
Mar 27 14:40:03 debian kernel: [    7.996224] raid0:   ==> UNIQUE
Mar 27 14:40:03 debian kernel: [    7.996225] raid0: 1 zones
Mar 27 14:40:03 debian kernel: [    7.996226] raid0: looking at sdc
Mar 27 14:40:03 debian kernel: [    7.996227] raid0:   comparing sdc(244198464) with sdb(244198464)
Mar 27 14:40:03 debian kernel: [    7.996228] raid0:   EQUAL
Mar 27 14:40:03 debian kernel: [    7.996229] raid0: FINAL 1 zones
Mar 27 14:40:03 debian kernel: [    7.996231] raid0: done.
Mar 27 14:40:03 debian kernel: [    7.996231] raid0 : md_size is 488396928 blocks.
Mar 27 14:40:03 debian kernel: [    7.996233] raid0 : conf->hash_spacing is 488396928 blocks.
Mar 27 14:40:03 debian kernel: [    7.996234] raid0 : nb_zone is 1.
Mar 27 14:40:03 debian kernel: [    7.996235] raid0 : Allocating 8 bytes for hash.
Mar 27 14:40:03 debian kernel: [    8.084042] PM: Starting manual resume from disk
Mar 27 14:40:03 debian kernel: [    8.132524] EXT3-fs: INFO: recovery required on readonly filesystem.
Mar 27 14:40:03 debian kernel: [    8.132526] EXT3-fs: write access will be enabled during recovery.
Mar 27 14:40:03 debian kernel: [    8.162424] kjournald starting.  Commit interval 5 seconds
Mar 27 14:40:03 debian kernel: [    8.216924] EXT3-fs: recovery complete.
Mar 27 14:40:03 debian kernel: [    8.216924] EXT3-fs: mounted filesystem with ordered data mode.
Mar 27 14:40:03 debian kernel: [    8.893860] udevd version 125 started
Mar 27 14:40:03 debian kernel: [    9.155694] input: Power Button (FF) as /class/input/input2
Mar 27 14:40:03 debian kernel: [    9.209898] ACPI: Power Button (FF) [PWRF]
Mar 27 14:40:03 debian kernel: [    9.209956] input: Power Button (CM) as /class/input/input3
Mar 27 14:40:03 debian kernel: [    9.274751] ACPI: Power Button (CM) [PWRB]
Mar 27 14:40:03 debian kernel: [    9.301995] input: PC Speaker as /class/input/input4
Mar 27 14:40:03 debian kernel: [    9.557446] ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 22 (level, low) -> IRQ 22
Mar 27 14:40:03 debian kernel: [    9.592102] hda_codec: Unknown model for ALC883, trying auto-probe from BIOS...
Mar 27 14:40:03 debian kernel: [    9.618760] ACPI: PCI Interrupt 0000:00:1f.3[C] -> GSI 18 (level, low) -> IRQ 18
Mar 27 14:40:03 debian kernel: [   10.120774] Adding 24025168k swap on /dev/sda7.  Priority:-1 extents:1 across:24025168k
Mar 27 14:40:03 debian kernel: [   10.169853] input: ImPS/2 Generic Wheel Mouse as /class/input/input5
Mar 27 14:40:03 debian kernel: [   10.285724] EXT3 FS on sda1, internal journal
Mar 27 14:40:03 debian kernel: [   11.325157] loop: module loaded
Mar 27 14:40:03 debian kernel: [   20.403151] kjournald starting.  Commit interval 5 seconds
Mar 27 14:40:03 debian kernel: [   20.410268] EXT3 FS on sda9, internal journal
Mar 27 14:40:03 debian kernel: [   20.410268] EXT3-fs: mounted filesystem with ordered data mode.
Mar 27 14:40:03 debian kernel: [   20.459501] kjournald starting.  Commit interval 5 seconds
Mar 27 14:40:03 debian kernel: [   20.459600] EXT3 FS on sda8, internal journal
Mar 27 14:40:03 debian kernel: [   20.459600] EXT3-fs: mounted filesystem with ordered data mode.
Mar 27 14:40:03 debian kernel: [   20.482985] kjournald starting.  Commit interval 5 seconds
Mar 27 14:40:03 debian kernel: [   20.494485] EXT3 FS on sda5, internal journal
Mar 27 14:40:03 debian kernel: [   20.494485] EXT3-fs: mounted filesystem with ordered data mode.
Mar 27 14:40:03 debian kernel: [   20.538986] kjournald starting.  Commit interval 5 seconds
Mar 27 14:40:03 debian kernel: [   20.538986] EXT3 FS on sda6, internal journal
Mar 27 14:40:03 debian kernel: [   20.538986] EXT3-fs: mounted filesystem with ordered data mode.
Mar 27 14:40:03 debian kernel: [   20.577265] kjournald starting.  Commit interval 5 seconds
Mar 27 14:40:03 debian kernel: [   20.579044] EXT3 FS on md0, internal journal
Mar 27 14:40:03 debian kernel: [   20.579044] EXT3-fs: mounted filesystem with ordered data mode.
Mar 27 14:40:03 debian kernel: [   22.613398] ATL1E 0000:02:00.0: ATL1E: eth0 NIC Link is Up<100 Mbps Full Duplex>
Mar 27 14:40:07 debian kernel: [   27.381695] ip_tables: (C) 2000-2006 Netfilter Core Team
Mar 27 14:40:34 debian kernel: [   57.867794] theforgottenser[3360]: segfault at 110 ip 45d4de sp 40b174e8 error 4 in theforgottenserver[400000+207000]
Mar 27 14:40:35 debian kernel: [   58.261010] theforgottenser[3375]: segfault at 4008 ip 7f96d202718a sp 4182b9f0 error 4 in libxml2.so.2.6.32[7f96d1fd0000+152000]
AdeBe
Post autor: AdeBe »
Proszę zmień temat na trochę konkretniejszy.
Przy okazji napisz więcej szczegółów:
jaki sprzęt (i na jaki) został zmieniony, dokładniej opisz objawy.
Logi są pomocne, ale opis problemu też jest niezbędny.
AdeBe
klekSu:
  1. Jaki dostawca internetu?
  2. Jak się łączysz z internetem?
  3. Jaka wersja systemu?
  4. Co próbujesz zrobić i w którym momencie pojawiają się te błędy?
Praktycznie nic nie napisałeś co mogłoby ułatwić udzielenie pomocy.
Fragment mojego logu wygląda tak:
Mar 20 07:14:15 a kernel: [    3.321306] intelfb: Version 0.9.6
Mar 20 07:14:15 a kernel: [    3.326463] brd: module loaded
Mar 20 07:14:15 a kernel: [    3.329135] loop: module loaded
Mar 20 07:14:15 a kernel: [    3.331099] nbd: registered device at major 43
Mar 20 07:14:15 a kernel: [    3.336839] tun: Universal TUN/TAP device driver, 1.6
Mar 20 07:14:15 a kernel: [    3.336850] tun: (C) 1999-2004 Mx Knyansky <maxk@qcomm.com>
Czy on ci coś mówi?
