Instalacja sterowników Nvidia FX 5200
Witam. Próbowałem zainstalować sterowniki do mojej karty graficznej Nvidia FX 5200, niestety próba się nie powiodła. Instalator wywala mi błąd braku zgodności czegoś tam. Wszystko robię według tej instrukcji:
http://kaka.ovh.org/howto/nvidia_drivers/
Debian GNU/Linux 5.0
Kernel: 2.6.18-6-486
Pozdrawiam i czekam na odpowiedzi.
zoltymleczyk
- Beginner
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sun Mar 22 22:33:34 2009
installer version: 1.0.7
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
precompiled interfaces : true
no ncurses color : false
query latest version : false
OpenGL header files : true
no questions : false
silent : false
no recursion : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : false
no ABI note : false
no RPMs : false
no kernel module : false
force SELinux : default
no X server check : false
no cc version check : false
force tls : (not specified)
X install prefix : (not specified)
X library install path : (not specified)
X module install path : (not specified)
OpenGL install prefix : (not specified)
OpenGL install libdir : (not specified)
utility install prefix : (not specified)
utility install libdir : (not specified)
doc install prefix : (not specified)
kernel name : (not specified)
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp mirror : [url]ftp://download.nvidia.com[/url]
RPM file list : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 173.14.18.
-> No precompiled kernel interface was found to match your kernel; would you li
ke the installer to attempt to download a kernel interface for your kernel f
rom the NVIDIA ftp site ([url]ftp://download.nvidia.com[/url])? (Answer: Yes)
-> No matching precompiled kernel interface was found on the NVIDIA ftp site;
this means that the installer will need to compile a kernel interface for
your kernel.
-> Performing CC sanity check with CC="cc".
-> Performing CC version check with CC="cc".
-> The CC version check failed:
The compiler used to compile the kernel (gcc 4.1) does not exactly match the
current compiler (gcc 4.3). The Linux 2.6 kernel module loader rejects kern
el modules built with a version of gcc that does not exactly match that of t
he compiler used to build the running kernel.
If you know what you are doing and want to ignore the gcc version check, sel
ect "No" to continue installation. Otherwise, select "Yes" to abort install
ation, set the CC environment variable to the name of the compiler used to c
ompile your kernel, and restart installation. Abort now? (Answer: Yes)
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at [url]www.nvidia.com[/url].
Później klikam na tak i informuje mnie, że nie odnalazł żadnego.no precompiled kernek interface... Would you like to attemp to download?
Następny błąd to:
Pozdrawiam.The CC version check failed. ¯e wymagana jest gcc 4.1, a mam gcc 9.33
według mnie na takiej wersji debiana z tak archaicznym jądrem będzie dużo niespełnionych zależności. poza tym:
dobry jesteś xD
mam gcc 9.33 ups przepraszam... sterowniki nvidi możesz kompilować swoja wersją kompilatora
po prostu nie wychodź z instalatora wpisując "no". Choć nie wiem dlaczego ludzie tak nie lubią sterów w jądrze od społeczności tkz "nv" przecież one fajne są xD
Abort now? (Answer: Yes) Wszystkie te problemy są opisane w poradniku, który podałeś w pierwszym poście. Z tego wynika, że nie dokładnie go przeczytałeś. Na pytanie o ściągnięcie "kernel interface" odpowiedz "No", natomiast w przy ostrzeżenie o kompilator zignoruj, o ile pamiętam trzeba dać "Yes".djdoublev pisze: Problem początkowo się pojawia przy " no precompiled kernek interface... Would you like to attemp to download?"
Pozdniej klikam na tak i pisze, ze nie odnalazl zadnego.
następny błąd to:
Nie zapomnij zainstalować uprzednio linux-headers i build-essential (to wszystko jest w poradniku).
