Debian 5.0 - xorg.conf i wyciszanie dźwi
bullseye
Debian 5.0 - xorg.conf i wyciszanie dźwięku domyślne
Post autor: bullseye »
Na dniach zainstalowałem Debiana 5.0 wraz z Gnomem.
I mam w sumie dwa nurtujące mnie pytania:
  1. Czemu mój Xorg jest pusty praktycznie? Co zrobić by był poprawny?
    Section "InputDevice"
    	Identifier	"Generic Keyboard"
    	Driver		"kbd"
    	Option		"XkbRules"	"xorg"
    	Option		"XkbModel"	"pc105"
    	Option		"XkbLayout"	"pl"
    EndSection
    	Identifier	"Configured Mouse"
    	Driver		"mouse"
    EndSection
    Section "Device"
    	Identifier	"Configured Video Device"
    EndSection
    Section "Monitor"
    	Identifier	"Configured Monitor"
    EndSection
    Section "Screen"
    	Identifier	"Default Screen"
    	Monitor		"Configured Monitor"
    EndSection
    lspci:
    00:00.0 Host bridge: nVidia Corporation nForce2 IGP2 (rev c1)
    00:00.1 RAM memory: nVidia Corporation nForce2 Memory Controller 1 (rev c1)
    00:00.2 RAM memory: nVidia Corporation nForce2 Memory Controller 4 (rev c1)
    00:00.3 RAM memory: nVidia Corporation nForce2 Memory Controller 3 (rev c1)
    00:00.4 RAM memory: nVidia Corporation nForce2 Memory Controller 2 (rev c1)
    00:00.5 RAM memory: nVidia Corporation nForce2 Memory Controller 5 (rev c1)
    00:01.0 ISA bridge: nVidia Corporation nForce2 ISA Bridge (rev a4)
    00:01.1 SMBus: nVidia Corporation nForce2 SMBus (MCP) (rev a2)
    00:02.0 USB Controller: nVidia Corporation nForce2 USB Controller (rev a4)
    00:02.1 USB Controller: nVidia Corporation nForce2 USB Controller (rev a4)
    00:02.2 USB Controller: nVidia Corporation nForce2 USB Controller (rev a4)
    00:08.0 PCI bridge: nVidia Corporation nForce2 External PCI Bridge (rev a3)
    00:09.0 IDE interface: nVidia Corporation nForce2 IDE (rev a2)
    00:1e.0 PCI bridge: nVidia Corporation nForce2 AGP (rev c1)
    01:07.0 Ethernet controller: VIA Technologies, Inc. VT6105/VT6106S [Rhine-III] (rev 86)
    01:08.0 Multimedia audio controller: Ensoniq 5880 AudioPCI (rev 02)
    02:00.0 VGA compatible controller: ATI Technologies Inc RV350 AS [Radeon 9550]
    02:00.1 Display controller: ATI Technologies Inc RV350 AS [Radeon 9550] (Secondary)
  2. Czemu po każdym ponownym uruchomieniu komputera system domyślnie wycisza i wyłącza dźwięk? Jest to trochę wkurzające i uciążliwe?
silentwr
Post autor: silentwr »
Poszukaj na forum o alsie i xorg'u jest bardzo dużo podobnych tematów wraz z rozwiązaniami.
Euzebiusz29
Post autor: Euzebiusz29 »
Poszukaj jak radzi silentwr, ale zajrzy też do tego tematu klik
pavbaranov
Post autor: pavbaranov »
Działa Ci Xorg? Jeśli tak, to czego chcesz? Jeśli nie - to zgłoś problem.
Jeśli chodzi o dźwięk - zobacz to co podpowiadają przedpiszący.
bullseye
Biore sie za czytanie :)
Dzieki za pomoc.
Nie do konca wiem czy dziala, szczegolnie sekcja z karta graficzna, bo co restart badz dwa cos w systemie pada dajac w rezultacie dziwna rozdzielczosc (Wide Screen zwezony do 17" kwadratu jakim jest moj monitor), strzelam ze to Xorg bo nic w nim nie ma, a zazwyczaj wyswietlalo sie (na Ubuntu chociazby) sekcja z grafika i monitorem. DirectRendering dziala i w sumie poza ta rozdzielczoscia co jakis czas wszystko dziala idealnie.
Euzebiusz29
A sterowniki zainstalowałeś do nvidii? Jeśli jeszcze nie to polecam dział dla początkujących.
silentwr
Kolega ma Radeona. :P
bullseye
Hmm napisałem ze DirectRendering działa dajac w wyniku Yes, wiec sterownik zainstalowany, glxfears daje kolo 2000fps wiec to standart dla mojej karty :)
ilin
Post autor: ilin »
Wygeneruj sobie nowego xorg.conf za pomocą X -configure jak nie pomoze to go wyrzucisz.
Co do dzwięku to jak poustawiasz glośnosci wydaj z roota polecenie
alsactl store
bullseye
Wielkie dzieki za pomoc :)
Alsa działa poprawnie (tzn dzwiek odpala sie tak jak ustawilem).
Ale po zaladowaniu Xorga jak ponizej, srodowisko graficzne nie wstaje i nie mam pojecia czemu :(
Section "ServerLayout"
	Identifier     "X.org Configured"
	Screen      0  "Screen0" 0 0
	InputDevice    "Mouse0" "CorePointer"
	InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
	Driver		"kbd"
EndSection
	Identifier  "Mouse0"
	Driver      "mouse"
	Option	    "Protocol" "auto"
	Option	    "Device" "/dev/input/mice"
	Option	    "ZAxisMapping" "4 5 6 7"
EndSection
Section "Files"
	RgbPath      "/etc/X11/rgb"
	ModulePath   "/usr/lib/xorg/modules"
	FontPath     "/usr/share/fonts/X11/misc"
	FontPath     "/usr/share/fonts/X11/cyrillic"
	FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/Type1"
	FontPath     "/usr/share/fonts/X11/100dpi"
	FontPath     "/usr/share/fonts/X11/75dpi"
	FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
	Load  "glx"
	Load  "extmod"
	Load  "xtrap"
	Load  "record"
	Load  "GLcore"
	Load  "dbe"
	Load  "dri"
EndSection
Section "Monitor"
	#DisplaySize	  340   270	# mm
	Identifier   "Monitor0"
	VendorName   "MAX"
	ModelName    "Belinea101728"
 ### Comment all HorizSync and VertRefresh values to use DDC:
	HorizSync    30.0 - 83.0
	VertRefresh  50.0 - 77.0
	Option	    "DPMS"
EndSection
Section "Device"
        ### Available Driver options are:-
        ### Values: [i]: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
        ### [arg]: arg optional
        #Option     "NoAccel"            	# [<bool>]
        #Option     "SWcursor"           	# [<bool>]
        #Option     "Dac6Bit"            	# [<bool>]
        #Option     "Dac8Bit"            	# [<bool>]
        #Option     "BusType"            	# [<str>]
        #Option     "CPPIOMode"          	# [<bool>]
        #Option     "CPusecTimeout"      	# [i]
        #Option     "AGPMode"            	# [i]
        #Option     "AGPFastWrite"       	# [<bool>]
        #Option     "AGPSize"            	# [i]
        #Option     "GARTSize"           	# [i]
        #Option     "RingSize"           	# [i]
        #Option     "BufferSize"         	# [i]
        #Option     "EnableDepthMoves"   	# [<bool>]
        #Option     "EnablePageFlip"     	# [<bool>]
        #Option     "NoBackBuffer"       	# [<bool>]
        #Option     "DMAForXv"           	# [<bool>]
        #Option     "FBTexPercent"       	# [i]
        #Option     "DepthBits"          	# [i]
        #Option     "PCIAPERSize"        	# [i]
        #Option     "AccelDFS"           	# [<bool>]
        #Option     "DDCMode"            	# [<bool>]
        #Option     "IgnoreEDID"         	# [<bool>]
        #Option     "DisplayPriority"    	# [<str>]
        #Option     "PanelSize"          	# [<str>]
        #Option     "ForceMinDotClock"   	# <freq>
        #Option     "ColorTiling"        	# [<bool>]
        #Option     "VideoKey"           	# [i]
        #Option     "RageTheatreCrystal" 	# [i]
        #Option     "RageTheatreTunerPort" 	# [i]
        #Option     "RageTheatreCompositePort" 	# [i]
        #Option     "RageTheatreSVideoPort" 	# [i]
        #Option     "TunerType"          	# [i]
        #Option     "RageTheatreMicrocPath" 	# <str>
        #Option     "RageTheatreMicrocType" 	# <str>
        #Option     "ScalerWidth"        	# [i]
        #Option     "RenderAccel"        	# [<bool>]
        #Option     "SubPixelOrder"      	# [<str>]
        #Option     "ShowCache"          	# [<bool>]
        #Option     "DynamicClocks"      	# [<bool>]
        #Option     "VGAAccess"          	# [<bool>]
        #Option     "ReverseDDC"         	# [<bool>]
        #Option     "LVDSProbePLL"       	# [<bool>]
        #Option     "AccelMethod"        	# <str>
        #Option     "DRI"                	# [<bool>]
        #Option     "ConnectorTable"     	# <str>
        #Option     "DefaultConnectorTable" 	# [<bool>]
        #Option     "DefaultTMDSPLL"     	# [<bool>]
        #Option     "TVDACLoadDetect"    	# [<bool>]
        #Option     "ForceTVOut"         	# [<bool>]
        #Option     "TVStandard"         	# <str>
        #Option     "IgnoreLidStatus"    	# [<bool>]
        #Option     "DefaultTVDACAdj"    	# [<bool>]
        #Option     "Int10"              	# [<bool>]
	Identifier  "Card0"
	Driver      "radeon"
	VendorName  "ATI Technologies Inc"
	BoardName   "RV350 AS [Radeon 9550]"
	BusID       "PCI:2:0:0"
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Card0"
	Monitor    "Monitor0"
	SubSection "Display"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
