7PGXW
Posty: 197 Rejestracja: 13 grudnia 2008, 11:52
Post
autor: 7PGXW » 20 marca 2009, 17:56
Zainstalowałem pakiet ntfs-3g, odpalam nautilusa z uprawnieniami roota i nie mogę nic skopiować na dysk. :/
sudo nautilus
seahorse nautilus module initialized
Initializing gnome-mount extension
** (nautilus:4440): WARNING **: Failed to initialize libhal context: (null) : (null)
** (nautilus:4440): WARNING **: Could not initialize hal context
Shutting down gnome-mount extension
** Message: don't know how to handle video/x-pn-realvideo, rmversion=(int)4, format=(int)1073758208, subformat=(int)17305632, width=(int)656, height=(int)272, framerate=(fraction)30/1, codec_data=(buffer)0108102040004000
totem-video-thumbnailer: 'file:///media/F/angus%20stringi%20i%20przytulanki.rmvb' isn't thumbnailable
Reason: Media contains no supported video streams.
** Message: don't know how to handle video/x-pn-realvideo, rmversion=(int)4, format=(int)1073774592, subformat=(int)21499936, width=(int)352, height=(int)172, framerate=(fraction)785449/32768, codec_data=(buffer)0148102040008000
totem-video-thumbnailer: 'file:///media/F/Blade%20Trinity.rmvb' isn't thumbnailable
** Message: don't know how to handle video/x-pn-realvideo, rmversion=(int)4, format=(int)1073758208, subformat=(int)17305632, width=(int)640, height=(int)272, framerate=(fraction)25/1, codec_data=(buffer)0108102040004000
totem-video-thumbnailer: 'file:///media/F/Old%20School%20Dubbing%20PL.rmvb' isn't thumbnailable
No accelerated IMDCT transform found
** Message: don't know how to handle video/x-pn-realvideo, rmversion=(int)4, format=(int)1073758208, subformat=(int)17305632, width=(int)512, height=(int)384, framerate=(fraction)30/1, codec_data=(buffer)0108102040004000
totem-video-thumbnailer: 'file:///media/F/Whitecoats%20(Nie-ostry%20dyzur)%20LektorPL.rmvb' isn't thumbnailable
** Message: Hit unexpected error "Niedozwolona operacja" while doing a file operation.
ilin
Posty: 2292 Rejestracja: 26 sierpnia 2007, 11:54
Post
autor: ilin » 20 marca 2009, 17:59
Dlaczego nautilus z roota ?
Pokaz
7PGXW
Post
autor: 7PGXW » 20 marca 2009, 18:22
ilin pisze: Dlaczego nautilus z roota ?
¯eby przez nautlusa zamontować albo móc kopiować. Chociaż zamontowałem przez mount -t ntfs /dev/sdb1 /mnt i w sumie działało (ale ciągle nie da się nagrywać).
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
/dev/sda1 / ext3 errors=remount-ro 0 1
/dev/sda4 none swap sw 0 0
/dev/scd0 /media/cdrom0 udf,iso9660 user,noauto 0 0
fdisk -l
/dev/sda1 1 1402 11261533+ 83 Linux
/dev/sda2 * 1403 2804 11261565 83 Linux
/dev/sda3 2881 9729 55014592+ 83 Linux
/dev/sda4 2805 2880 610470 82 Linux swap / Solaris
Partition table entries are not in disk order
Disk /dev/sdb: 160.0 GB, 160041885696 bytes
255 heads, 63 sectors/track, 19457 cylinders
Disk identifier: 0x37253725
/dev/sdb1 1 19456 156280288+ 7 HPFS/NTFS
Zewnętrzny dysk podpięty pod USB (zapomniałem napisać).
ilin
Post
autor: ilin » 20 marca 2009, 18:28
Dopisz sobie ten dysk do fstaba i będziesz miał swięty spokój.
/dev/sdb1 /mnt/dysk ntfs-3g rw,uid=1000,gid=100,fmask=0111,dmask=0,locale=pl_PL.utf8,silent
Oczywiście katalog /mnt/dysk musisz utworzyć.
To musi być w jednej lini Tagi rozjeżdżają
Zobacz to.
http://dug.net.pl/faq/faq-6-100-Montowa ... i_NTFS.php
7PGXW
Post
autor: 7PGXW » 20 marca 2009, 23:10
Problem wynikał chyba z tego, że montowałem w folderze media a nie mnt. :P
Ale dzięki za pomoc.
ilin
Post
autor: ilin » 21 marca 2009, 07:42
To żada różnica.
U Ciebie raczej jakiś problem z halem występowal bo za jego pomocą montowałeś.
Ja preferuję dopisanie na sztywno do /etc/fstab i jest święty spokój.
Hal przy aktualkach czasem płata figle.
Na debianie tego co prawda jeszcze nie zaobserwowalem natomiast na archu ostatnio z tym był nagminny problem.
