Proszę o pomoc w odpaleniu Wifi.
Sprzęt: Laptop Dell D510 Karta - Intel 2200BG
modinfo ipw2200Kod: Zaznacz cały
filename: /lib/modules/2.6.26-1-686/kernel/drivers/net/wireless/ipw2200.ko
license: GPL
author: Copyright(c) 2003-2006 Intel Corporation
version: 1.2.2kmprq
description: Intel(R) PRO/Wireless 2200/2915 Network Driver
srcversion: 5A09C3DEB43C3E766A1F3D1
alias: pci:v00008086d00004224sv*sd*bc*sc*i*
alias: pci:v00008086d00004223sv*sd*bc*sc*i*
alias: pci:v00008086d00004221sv*sd*bc*sc*i*
alias: pci:v00008086d00004220sv*sd*bc*sc*i*
alias: pci:v00008086d0000104Fsv*sd*bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002762bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002761bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002754bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002753bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002752bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002751bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002742bc*sc*i*
alias: pci:v00008086d00001043sv0000103Csd00002741bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002741bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002732bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002731bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002722bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002721bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002712bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002711bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002702bc*sc*i*
alias: pci:v00008086d00001043sv00008086sd00002701bc*sc*i*
depends: ieee80211,firmware_class
vermagic: 2.6.26-1-686 SMP mod_unload modversions 686
parm: disable:manually disable the radio (default 0 [radio on]) (int)
parm: associate:auto associate when scanning (default on) (int)
parm: auto_create:auto create adhoc network (default on) (int)
parm: led:enable led control on some systems (default 0 off)
(int)
parm: debug:debug output mask (int)
parm: channel:channel to limit associate to (default 0 [ANY]) (int)
parm: rtap_iface:create the rtap interface (1 - create, default 0) (int)
parm: qos_enable:enable all QoS functionalitis (int)
parm: qos_burst_enable:enable QoS burst mode (int)
parm: qos_no_ack_mask:mask Tx_Queue to no ack (int)
parm: burst_duration_CCK:set CCK burst value (int)
parm: burst_duration_OFDM:set OFDM burst value (int)
parm: mode:network mode (0=BSS,1=IBSS,2=Monitor) (int)
parm: bt_coexist:enable bluetooth coexistence (default off) (int)
parm: hwcrypto:enable hardware crypto (default off) (int)
parm: cmdlog:allocate a ring buffer for logging firmware commands (int)
parm: roaming:enable roaming support (default on) (int)
parm: antenna:select antenna 1=Main, 3=Aux, default 0 [both], 2=slow_diversity (choose the one with lower background noise) (int)
ifconfig eth1 upKod: Zaznacz cały
eth1: ERROR while getting interface flags: Nie ma takiego urządzeniaKod: Zaznacz cały
modinfo ieee80211Kod: Zaznacz cały
filename: /lib/modules/2.6.26-1-686/kernel/net/ieee80211/ieee80211.ko
license: GPL
author: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
description: 802.11 data/management/control stack
version: git-1.1.13
srcversion: 380386BF43F8373E55CFB15
depends: ieee80211_crypt
vermagic: 2.6.26-1-686 SMP mod_unload modversions 686Kod: Zaznacz cały
iwconfigKod: Zaznacz cały
lo no wireless extensions.
eth0 no wireless extensions.Kod: Zaznacz cały
lsmod | grep ipw2200Kod: Zaznacz cały
ipw2200 123560 0
ieee80211 27048 1 ipw2200
firmware_class 6816 2 ipw2200, pcmciaWic macd manager nie znajduje sieci.
Kierowałem się opisem http://wiki.debian.org/ipw2200#Lenny
Nie instalowałem ipw2200.
[Dodano: 2009-03-20, 15:29]
Tak więc po nieprzespanej nocy problem rozwiązałem w bardzo prosty sposób, czyli przeinstalowałem Debian a podczas instalacji gdy spytał o plik ipw2200-bss.fw.
Podpiąłem pendriva z firmware3.0 i bez problemu instalacja przeszła dalej.
Szkoda tylko że od razu nie skorzystałem z tej metody zaoszczędziłbym sporo czasu.
A Wifi zadziałało z bo bez żadnych konfiguracji wykryło wszystkie sieci.
Temat zamknięty.
[Dodano: 2009-03-20, 16:38]
A miało być tak pięknie:
Tym razem mam problem z Widc.
Znajduje sieć bez problemy, jednak w momencie, gdy próbuje się z nią połączyć coś tam przetwarza i po pewnym czasie wszystkie sieci znikają i pojawia się informacja Nie znaleziono sieci bezprzewodowych. Proszę o pomoc bo mam już ochotę wyrzucić tą dystrybucję dlaczego w Linuksie wszystko musi być tak skomplikowane.
W Network manager sytuacja jest podobna. Gdy próbuje połączyć się z moją siecią najpierw NM usiłuje się połączyć a po chwili nic się nie dzieje a network manager powraca do połączenia kablowego. Pościągałem wszystkie zabezpieczenia z rutera i dalej nie może się połączyć.
Dodałem użytkownika do netdev zakomentowałem wszystko oprócz ,,auto lo inface'' w /etc/network/interfaces.
Macie jakiś pomysł?
