Próbowałem zainstalować sterowniki nvidii (riva tnt2) i wyskoczył mi pewien błąd. Zajrzałem do poradnika Kaki' i okazało się, że wszystko robiłem dobrze (tzn. tak mi się wydaje) ale sami zobaczcie:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Mon Mar 16 17:23:50 2009
option status:
  license pre-accepted    : false
  update                  : false
  force update            : false
  expert                  : false
  uninstall               : false
  driver info             : false
  precompiled interfaces  : true
  no ncurses color        : false
  query latest version    : false
  OpenGL header files     : true
  no questions            : false
  silent                  : false
  no recursion            : false
  no backup               : false
  kernel module only      : false
  sanity                  : false
  add this kernel         : false
  no runlevel check       : false
  no network              : false
  no ABI note             : false
  no RPMs                 : false
  no kernel module        : false
  force SELinux           : default
  no X server check       : false
  force tls               : (not specified)
  X install prefix        : (not specified)
  X library install path  : (not specified)
  X module install path   : (not specified)
  OpenGL install prefix   : (not specified)
  OpenGL install libdir   : (not specified)
  utility install prefix  : (not specified)
  utility install libdir  : (not specified)
  doc install prefix      : (not specified)
  kernel name             : (not specified)
  kernel include path     : (not specified)
  kernel source path      : (not specified)
  kernel output path      : (not specified)
  kernel install path     : (not specified)
  proc mount point        : /proc
  ui                      : (not specified)
  tmpdir                  : /tmp
  ftp mirror              : [url]ftp://download.nvidia.com[/url]
  RPM file list           : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
   ke the installer to attempt to download a kernel interface for your kernel f
   rom the NVIDIA ftp site ([url]ftp://download.nvidia.com[/url])? (Answer: No)
-> No precompiled kernel interface was found to match your kernel; this means
   that the installer will need to compile a new kernel interface.
-> Performing CC sanity check with CC="gcc-4.1".
-> Performing CC version check with CC="gcc-4.1".
-> Kernel source path: '/lib/modules/2.6.26-1-686/build'
-> Kernel output path: '/lib/modules/2.6.26-1-686/build'
-> Performing rivafb check.
-> Performing nvidiafb check.
-> Performing Xen check.
-> Cleaning kernel module build directory.
   executing: 'cd ./usr/src/nv; make clean'...
-> Building kernel module:
   executing: 'cd ./usr/src/nv; make module SYSSRC=/lib/modules/2.6.26-1-686/bu
   ild SYSOUT=/lib/modules/2.6.26-1-686/build'...
   NVIDIA: calling KBUILD...
   make CC=gcc-4.1  KBUILD_VERBOSE=1 -C /lib/modules/2.6.26-1-686/build SUBDIRS
   =/tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv modules
   test -e include/linux/autoconf.h -a -e include/config/auto.conf || (         \
        echo;                                                           \
        echo "  ERROR: Kernel configuration is invalid.";               \
        echo "         include/linux/autoconf.h or include/config/auto.conf are mis
   sing.";      \
        echo "         Run 'make oldconfig && make prepare' on kernel src to fix it
        echo;                                                           \
        /bin/false)
   mkdir -p /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/.tmp_ver
   sions ; rm -f /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/.tm
   p_versions/*
   make -f scripts/Makefile.build obj=/tmp/selfgz22223/NVIDIA-Linux-x86-71.86.0
   4-pkg1/usr/src/nv
     gcc-4.1 -Wp,-MD,/tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv
   /.nv.o.d  -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.1.3/include -D__K
   ERNEL__ -Iinclude  -include include/linux/autoconf.h -Wall -Wundef -Wstrict-
   prototypes -Wno-trigraphs -
   fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Os
   -fno-stack-protector -m32 -msoft-float -mregparm=3 -freg-struct-return -mpre
   ferred-stack-boundary=2  -march=i686 -ffreestanding -DCONFIG_AS_CFI=1 -DCONF
   IG_AS_CFI_SIGNAL_FRAME=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-ta
   bles -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Iinclude/asm-x86/mach-default -
   fomit-frame-pointer -Wdeclaration-after-statement -Wno-pointer-sign   -I/tmp
   /selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv -Wall -Wimplicit -Wre
   turn-type -Wswitch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith
   -Wno-multichar -Werror -MD   -Wsign-compare -Wno-cast-qual -Wno-error -D_LOO
   SE_KERNEL_NAMES -D__KERNEL__ -DMODULE -DNTRM -D_GNU_SOURCE -D_LOOSE_KERNEL_N
   AMES -D__KERNEL__ -DMODULE -DNV_VERSION_STRING=\"71.86.04\" -DNV_UNIX -DNV_L
   INUX -DNV_INT64_OK -DNVCPU_X86 -UDEBUG -U_DEBUG -DNDEBUG  -DMODULE -D"KBUILD
   _STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv)"  -D"KBUILD_MODNAME=KBUILD_STR
   (nvidia)" -c -o /tmp/selfgz22223/NVI
   DIA-Linux-x86-71.86.04-pkg1/usr/src/nv/.tmp_nv.o /tmp/selfgz22223/NVIDIA-Lin
   ux-x86-71.86.04-pkg1/usr/src/nv/nv.c
   In file included from include/linux/list.h:6,
                    from include/linux/preempt.h:11,
                    from include/linux/spinlock.h:49,
                    from include/linux/seqlock.h:29,
                    from include/linux/time.h:8,
                    from include/linux/timex.h:57,
                    from include/linux/sched.h:54,
                    from include/linux/utsname.h:35,
                    from /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/sr
   c/nv/nv-linux.h:19,
   c/nv/nv.c:14:
   include/linux/prefetch.h: In function ‘prefetch_range’:
   include/linux/prefetch.h:57: warning: pointer of type ‘void *’ used in a
   rithmetic
   In file included from include/asm/dma-mapping.h:9,
                    from include/linux/dma-mapping.h:52,
                    from include/asm-generic/pci-dma-compat.h:7,
                    from include/asm/pci.h:92,
                    from include/linux/pci.h:948,
   c/nv/nv-linux.h:79,
   c/nv/nv.c:14:
   include/linux/scatterlist.h: In function ‘sg_virt’:
   include/linux/scatterlist.h:199: warning: pointer of type ‘void *’ used
   in arithmetic
   In file included from /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/sr
   c/nv/nv-linux.h:101,
   c/nv/nv.c:14:
   include/linux/highmem.h: In function ‘zero_user_segments’:
   include/linux/highmem.h:134: warning: pointer of type ‘void *’ used in a
   rithmetic
   rithmetic
   rithmetic
   rithmetic
   include/linux/highmem.h:137: warning: pointer of type ‘void *’ used in a
   rithmetic
   rithmetic
   rithmetic
   rithmetic
   /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/nv.c: In function
   ‘nvos_proc_create’:
   /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/nv.c:564: error:
   ‘proc_root_driver’ undeclared (first use in this function)
   (Each undeclared identifier is reported only once
   for each function it appears in.)
   ‘__nv_setup_pat_entries’:
   /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/nv.c:883: warning
   : comparison between signed and unsigned
   ‘__nv_restore_pat_entries’:
   /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/nv.c:909: warning
   ‘nv_kern_cpu_callback’:
   /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/nv.c:1220: warnin
   g: comparison between signed and unsigned
   /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/nv.c:1227: warnin
   ‘nv_kern_vma_nopage’:
   /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/nv.c:1740: error:
   ‘NOPAGE_SIGBUS’ undeclared (first use in this function)
   /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/nv.c: At top leve
   l:
   /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/nv.c:1747: error:
   unknown field ‘nopage’ specified in initializer
   /tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/nv.c:1747: warnin
   g: initialization from incompatible pointer type
   make[3]: *** [/tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/src/nv/nv.
   o] Błąd 1
   make[2]: *** [_module_/tmp/selfgz22223/NVIDIA-Linux-x86-71.86.04-pkg1/usr/sr
   c/nv] Błąd 2
   NVIDIA: left KBUILD.
   nvidia.ko failed to build!
   make[1]: *** [module] Błąd 1
   make: *** [module] Błąd 2
-> Error.
ERROR: Unable to build the NVIDIA kernel module.
ERROR: Installation has failed.  Please see the file
       '/var/log/nvidia-installer.log' for details.  You may find suggestions
       on fixing installation problems in the README available on the Linux
       driver download page at [url]www.nvidia.com[/url].Dziękuję z góry i pozdrawiam.
