Chciałem zainstalować ten sterownik w Debianie Lennym tak jak przedstawił to Kaka' w swoim poradniku. Niestety podczas instalacji wyskoczyły 2 błędy. Log z instalacji.
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Fri Mar 13 14:32:02 2009
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
precompiled interfaces : true
no ncurses color : false
query latest version : false
OpenGL header files : true
no questions : false
silent : false
no recursion : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : false
no ABI note : false
no RPMs : false
no kernel module : false
force SELinux : default
no X server check : false
force tls : (not specified)
X install prefix : (not specified)
X library install path : (not specified)
X module install path : (not specified)
OpenGL install prefix : (not specified)
OpenGL install libdir : (not specified)
utility install prefix : (not specified)
utility install libdir : (not specified)
doc install prefix : (not specified)
kernel name : (not specified)
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp mirror : [url]ftp://download.nvidia.com[/url]
RPM file list : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
ke the installer to attempt to download a kernel interface for your kernel f
rom the NVIDIA ftp site ([url]ftp://download.nvidia.com[/url])? (Answer: Yes)
-> No matching precompiled kernel interface was found on the NVIDIA ftp site;
this means that the installer will need to compile a kernel interface for
your kernel.
-> Performing CC sanity check with CC="cc".
-> Performing CC version check with CC="cc".
-> The CC version check failed:
The compiler used to compile the kernel (gcc 4.1) does not exactly match the
current compiler (gcc 4.3). The Linux 2.6 kernel module loader rejects kern
el modules built with a version of gcc that does not exactly match that of t
he compiler used to build the running kernel.
If you know what you are doing and want to ignore the gcc version check, sel
ect "No" to continue installation. Otherwise, select "Yes" to abort install
ation, set the CC environment variable to the name of the compiler used to c
ompile your kernel, and restart installation. Abort now? (Answer: No)
ERROR: Unable to find the kernel source tree for the currently running kernel.
Please make sure you have installed the kernel source files for your
kernel and that they are properly configured; on Red Hat Linux systems,
for example, be sure you have the 'kernel-source' or 'kernel-devel' RPM
installed. If you know the correct kernel source files are installed,
you may specify the kernel source path with the '--kernel-source-path'
command line option.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at [url]www.nvidia.com[/url].
Zainstalowałem nagłówki ale teraz wyświetla się coś o nie właściwej wersji gcc. Pisze, że nie można znaleść jakiejś tam struktury do mojego kernela i trzeba skompilować samemu i wyskakuje bład.
ERROR: Unable to find the development tool `cc` in your path; please make sure
that you have the package 'gcc' installed. If gcc is installed on your
system, then please check that `cc` is in your PATH.
Chcialem przeinstalowac gcc i po tym zaczelo to sie pojawiac. Przedtem byla informacja cos o zlej wersji gcc.
Zainstalowałem i robi się tak jak przedtem. Pisze, compile kernel module. Szybko dochodzi do 100% i wyskakuje komunikat, że nie udało się skompilować. Da się jakoś zamienić kompilator z 4.3 na 4.1?
creation time: Fri Mar 13 16:27:08 2009
option status:
update : false
expert : false
uninstall : false
driver info : false
silent : false
no backup : false
sanity : false
no network : false
no ABI note : false
no RPMs : false
tmpdir : /tmp
rom the NVIDIA ftp site ([url]ftp://download.nvidia.com[/url])? (Answer: No)
-> No precompiled kernel interface was found to match your kernel; this means
that the installer will need to compile a new kernel interface.
-> Kernel source path: '/lib/modules/2.6.26-1-686/build'
-> Kernel output path: '/lib/modules/2.6.26-1-686/build'
-> Performing rivafb check.
-> Performing nvidiafb check.
-> Performing Xen check.
-> Cleaning kernel module build directory.
executing: 'cd ./usr/src/nv; make clean'...
-> Building kernel module:
executing: 'cd ./usr/src/nv; make module SYSSRC=/lib/modules/2.6.26-1-686/bu
ild SYSOUT=/lib/modules/2.6.26-1-686/build'...
NVIDIA: calling KBUILD...
make CC=cc KBUILD_VERBOSE=1 -C /lib/modules/2.6.26-1-686/build SUBDIRS=/tmp
/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv modules
test -e include/linux/autoconf.h -a -e include/config/auto.conf || ( \
echo; \
echo " ERROR: Kernel configuration is invalid."; \
echo " include/linux/autoconf.h or include/config/auto.conf are mis
sing."; \
echo " Run 'make oldconfig && make prepare' on kernel src to fix it
echo; \
/bin/false)
mkdir -p /tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/.tmp_vers
ions ; rm -f /tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/.tmp_
versions/*
make -f scripts/Makefile.build obj=/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05
-pkg1/usr/src/nv
cc -Wp,-MD,/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/.nv.o
.d -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.3.2/include -D__KERNEL_
_ -Iinclude -include include/linux/autoconf.h -Wall -Wundef -Wstrict-protot
ypes -Wno-trigraphs -fno-strict-alia
sing -fno-common -Werror-implicit-function-declaration -Os -fno-stack-prot
ector -m32 -msoft-float -mregparm=3 -freg-struct-return -mpreferred-stack-bo
undary=2 -march=i686 -ffreestanding -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNA
L_FRAME=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -
mno-mmx -mno-sse2 -mno-3dnow -Iinclude/asm-x86/mach-default -fomit-frame-poi
nter -Wdeclaration-after-statement -Wno-pointer-sign -I/tmp/selfgz3955/NVI
DIA-Linux-x86-96.43.05-pkg1/usr/src/nv -Wall -Wimplicit -Wreturn-type -Wswit
ch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith -Wno-multichar -
Werror -MD -Wsign-compare -Wno-cast-qual -Wno-error -D_LOOSE_KERNEL_NAMES
-D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"96.43.05\" -UDEBUG -U_DEB
UG -DNDEBUG -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv)
" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz3955/NVIDIA-Linux-
x86-96.43.05-pkg1/usr/src/nv/.tmp_nv.o /tmp/selfgz3955/NVIDIA-Linux-x86-96.4
3.05-pkg1/usr/src/nv/nv.c
In file included from include/linux/list.h:6,
from include/linux/preempt.h:11,
from include/linux/spinlock.h:49,
from include/linux/seqlock.h:29,
from include/linux/time.h:8,
from include/linux/timex.h:57,
from include/linux/sched.h:54,
from include/linux/utsname.h:35,
from /tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src
/nv/nv-linux.h:19,
/nv/nv.c:14:
include/linux/prefetch.h: In function ‘prefetch_range’:
include/linux/prefetch.h:57: warning: pointer of type ‘void *’ used in a
rithmetic
In file included from include/asm/dma-mapping.h:9,
from include/linux/dma-mapping.h:52,
from include/asm-generic/pci-dma-compat.h:7,
from include/asm/pci.h:92,
from include/linux/pci.h:948,
/nv/nv-linux.h:85,
/nv/nv.c:14:
include/linux/scatterlist.h: In function ‘sg_virt’:
include/linux/scatterlist.h:199: warning: pointer of type ‘void *’ used
in arithmetic
In file included from /tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src
/nv/nv-linux.h:108,
/nv/nv.c:14:
include/linux/highmem.h: In function ‘zero_user_segments’:
include/linux/highmem.h:134: warning: pointer of type ‘void *’ used in a
rithmetic
rithmetic
rithmetic
rithmetic
include/linux/highmem.h:137: warning: pointer of type ‘void *’ used in a
rithmetic
rithmetic
rithmetic
rithmetic
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c: In function
‘nvos_proc_create’:
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:505: error: â
€˜proc_root_driver’ undeclared (first use in this function)
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:505: error: (
Each undeclared identifier is reported only once
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:505: error: f
or each function it appears in.)
‘__nv_setup_pat_entries’:
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:833: warning:
comparison between signed and unsigned
‘__nv_restore_pat_entries’:
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:859: warning:
‘nv_kern_cpu_callback’:
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:1170: warning
: comparison between signed and unsigned
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:1177: warning
‘nv_kern_vma_nopage’:
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:1699: error:
‘NOPAGE_SIGBUS’ undeclared (first use in this function)
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c: At top level
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:1706: error:
unknown field ‘nopage’ specified in initializer
/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:1706: warning
: initialization from incompatible pointer type
make[3]: *** [/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.o
] Błąd 1
make[2]: *** [_module_/tmp/selfgz3955/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src
/nv] Błąd 2
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make[1]: *** [module] Błąd 1
make: *** [module] Błąd 2
-> Error.
ERROR: Unable to build the NVIDIA kernel module.
