= brak belekdarek@darek-desktop:~$ beryl
XGL Absent, checking for NVIDIA
Nvidia Absent, assuming AIGLX
beryl: symbol lookup error: beryl: undefined symbol: XCompositeGetOverlayWindow
= restart X'ówdarek@darek-desktop:~$ beryl-manager
= restart X'ówdarek@darek-desktop:~$ emerald
= restart X'ówdarek@darek-desktop:~$ emerald --replace
=brak belekdarek@darek-desktop:~$ compiz
darek@darek-desktop:~$ glxinfo | grep direct
direct rendering: Yes
Xorg:
# package.
Section "Files"
# path to defoma fonts
FontPath "/usr/share/X11/fonts/misc"
FontPath "/usr/share/X11/fonts/cyrillic"
FontPath "/usr/share/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/X11/fonts/Type1"
FontPath "/usr/share/X11/fonts/100dpi"
FontPath "/usr/share/X11/fonts/75dpi"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "int10"
Load "type1"
Load "vbe"
load "glx"
load "GLcore"
load "v4l"
Load "dri"
Load "dbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
option "CoreKeyboard"
option "XkbRules" "xorg"
option "XkbModel" "pc105"
option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
option "CorePointer"
option "Device" "/dev/input/mice"
option "Protocol" "ExplorerPS/2"
option "ZAxisMapping" "4 5"
option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
option "Device" "/dev/wacom"# Change to
option "Type" "stylus"
option "ForceDevice" "ISDV4"# Tablet PC ONLY
# /dev/input/event
# for USB
EndSection
Driver "wacom"
Identifier "eraser"
option "Type" "eraser"
# /dev/input/event
# for USB
EndSection
Driver "wacom"
Identifier "cursor"
option "Type" "cursor"
# /dev/input/event
# for USB
EndSection
Section "Device"
identifier "ATI Technologies, Inc. RV350 AP [Radeon 9600]"
boardname "ati"
busid "PCI:1:0:0"
driver "ati"
screen 0
option "MergedFB" "off"
Option "AddARGBGLXVisuals" "On"
Option "XAANoOffscreenPixmaps" "true"
Option "RenderAccel" "true"
EndSection
Section "Monitor"
identifier "Q773"
vendorname "Plug 'n' Play"
modelname "Plug 'n' Play"
modeline "640x480@60" 25.2 640 656 752 800 480 490 492 525 -vsync -hsync
modeline "640x480@72" 31.5 640 664 704 832 480 489 491 520 -vsync -hsync
modeline "640x480@75" 31.5 640 656 720 840 480 481 484 500 -vsync -hsync
modeline "640x480@85" 36.0 640 696 752 832 480 481 484 509 -vsync -hsync
modeline "800x600@56" 36.0 800 824 896 1024 600 601 603 625 +hsync +vsync
modeline "800x600@72" 50.0 800 856 976 1040 600 637 643 666 +hsync +vsync
modeline "800x600@75" 49.5 800 816 896 1056 600 601 604 625 +hsync +vsync
modeline "800x600@85" 56.3 800 832 896 1048 600 601 604 631 +hsync +vsync
modeline "800x600@60" 40.0 800 840 968 1056 600 601 605 628 +hsync +vsync
modeline "832x624@75" 57.284 832 864 928 1152 624 625 628 667 -vsync -hsync
modeline "1024x768@85" 94.5 1024 1072 1168 1376 768 769 772 808 +hsync +vsync
modeline "1024x768@75" 78.8 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
modeline "1024x768@70" 75.0 1024 1048 1184 1328 768 771 777 806 -vsync -hsync
modeline "1024x768@60" 65.0 1024 1048 1184 1344 768 771 777 806 -vsync -hsync
modeline "1024x768@43" 44.9 1024 1032 1208 1264 768 768 776 817 +hsync interlace +vsync
modeline "1152x864@75" 108.0 1152 1216 1344 1600 864 865 868 900 +hsync +vsync
modeline "1152x768@54" 64.995 1152 1178 1314 1472 768 771 777 806 +hsync +vsync
modeline "1280x854" 80.0 1280 1309 1460 1636 854 857 864 896 +hsync +vsync
modeline "1280x960@60" 102.1 1280 1360 1496 1712 960 961 964 994 -hsync +vsync
modeline "1280x1024@60" 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
modeline "1400x1050@60" 122.61 1400 1488 1640 1880 1050 1051 1054 1087 -hsync +vsync
gamma 1.0
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies, Inc. RV350 AP [Radeon 9600]"
Monitor "Q773"
DefaultDepth 24
SubSection "Display"
depth 24
virtual 1400 1050
modes "1280x1024@60" "1400x1050@60" "1024x768@85" "1024x768@75" "832x624@75" "1024x768@70" "800x600@60" "1024x768@60" "800x600@85" "1024x768@43" "800x600@75" "1152x864@75" "800x600@72" "1152x768@54" "800x600@56" "1280x854" "640x480@85" "1280x960@60" "640x480@75" "640x480@72" "640x480@60"
EndSubSection
EndSection
Section "ServerLayout"
Option "AIGLX" "on"
Identifier "Default Layout"
screen 0 "Default Screen" 0 0
InputDevice "stylus" "SendCoreEvents"
InputDevice "cursor" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "device" #
identifier "device1"
boardname "ati"
busid "PCI:1:0:0"
driver "ati"
screen 1
EndSection
Section "screen" #
identifier "screen1"
device "device1"
defaultdepth 24
monitor "monitor1"
EndSection
Section "monitor" #
identifier "monitor1"
gamma 1.0
EndSection
Section "Extensions"
Option "Composite" "Enable"
Option "RENDER" "Enable"
EndSection
Szukałem na forum i znalazłem to to że problemem może być Yakuake - zamknąłem i nadal to samo. Próbowałem rozwiązać problem wg tego FAQ - nic nie skutkuje
PS. Fajne połączenie wychodzi przy uruchomieniu w sesji KDE nautilusa, gnome-theme-manager'a i zabiciu kdesktop - pasek zadań = KDE, pulpit = GNOME, przegladarka plików = Nautilus
