[+] Ostrzeżenia lub informacje podczas startu systemu
Sheryph
[+] OstrzeŻenia lub informacje podczas startu systemu
Post autor: Sheryph »
Stało się to prawdopodobnie po aktualizacji lub jak resetowałem komputer po aktualizacji to wcisnąłem enter jak już system zaczął startować. Zamieszczam log ze startu systemu:
Wed Mar 4 09:10:04 2009: .
Wed Mar 4 09:10:04 2009: Setting parameters of disc: (none).
Wed Mar 4 09:10:04 2009: Setting the system clock.
Wed Mar 4 09:10:04 2009: Setting preliminary keymap...done.
Wed Mar 4 09:10:04 2009: Setting kernel variables (/etc/sysctl.conf)...done.
Wed Mar 4 09:10:04 2009: Activating swap...done.
Wed Mar 4 09:10:04 2009: Checking root file system...fsck 1.41.3 (12-Oct-2008)
Wed Mar 4 09:10:04 2009: /dev/sda5: clean, 131671/1221600 files, 1059709/4883752 blocks (check in 3 mounts)
Wed Mar 4 09:10:04 2009: done.
Wed Mar 4 09:10:04 2009: Cleaning up ifupdown....
Wed Mar 4 09:10:04 2009: Loading kernel modules...done.
Wed Mar 4 09:10:04 2009: Setting up LVM Volume Groups Reading all physical volumes. This may take a while...
Wed Mar 4 09:10:04 2009: Checking file systems...fsck 1.41.3 (12-Oct-2008)
Wed Mar 4 09:10:05 2009: /dev/sda2: clean, 19858/2932736 files, 731402/11717409 blocks
Wed Mar 4 09:10:05 2009: /dev/sda7: clean, 23078/4825088 files, 7094724/19282008 blocks (check in 2 mounts)
Wed Mar 4 09:10:05 2009: done.
Wed Mar 4 09:10:05 2009: Mounting local filesystems...modprobe: WARNING: All config files need .conf: /etc/modprobe.d/alsa-base-blacklist, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009:.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/blacklist, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/arch-aliases, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/linux-sound-base_noOSS, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/aliases, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/alsa-base, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/ieee1394, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/display_class, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/oss-compat, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/pnp-hotplug, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/libsane, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/ueagle-atm, it will be ignored in a future release.
Wed Mar 4 09:10:05 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/sidux, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/arch, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009:.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/i2c, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/alsa-base-blacklist, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/blacklist, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/arch-aliases, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/linux-sound-base_noOSS, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/aliases, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/alsa-base, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/ieee1394, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/display_class, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/oss-compat, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/pnp-hotplug, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/libsane, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/ueagle-atm, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: modprobe: WARNING: All config files need .conf: /etc/modprobe.d/sidux, it will be ignored in a future release.
Wed Mar 4 09:10:06 2009: done.
Wed Mar 4 09:10:06 2009: Activating swapfile swap...done.
Wed Mar 4 09:10:06 2009: Setting the system clock.
Wed Mar 4 09:10:07 2009: Setting sensors limits.
Wed Mar 4 09:10:07 2009: Setting up resolvconf...done.
Wed Mar 4 09:10:07 2009: Setting up networking....
Wed Mar 4 09:10:07 2009: Configuring network interfaces...done.
Wed Mar 4 09:10:07 2009: Setting console screen modes.
Wed Mar 4 09:10:07 2009: ^[]R^[[9;30]^[[14;30]Setting up ALSA...done.
Wed Mar 4 09:10:08 2009: Setting up console font and keymap...done.
Wed Mar 4 09:10:08 2009: INIT: Entering runlevel: 5
Wed Mar 4 09:10:08 2009: Using startpar-style concurrent boot in runlevel 5.
Wed Mar 4 09:10:08 2009: VirtualBox Additions Disabled, not in a Virtual Machine ^[[33m(warning).^[[39;49m
Wed Mar 4 09:10:08 2009: Loading cpufreq kernel modules...WARNING: All config files need .conf: /etc/modprobe.d/alsa-base-blacklist, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/blacklist, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/arch-aliases, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/linux-sound-base_noOSS, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/aliases, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/alsa-base, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/ieee1394, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/display_class, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/oss-compat, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/pnp-hotplug, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/libsane, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/ueagle-atm, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/sidux, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/arch, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/i2c, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/alsa-base-blacklist, it will be ignored in a future release.
Wed Mar 4 09:10:08 2009: WARNING: All config files need .conf: /etc/modprobe.d/aliases, it will be ignored in Wed Mar 4 09:10:05 2009:.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/oss-compat, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/pnp-hotplug, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/libsane, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/ueagle-atm, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/sidux, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/arch, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/i2c, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/alsa-base-blacklist, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/blacklist, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/arch-aliases, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/linux-sound-base_noOSS, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/aliases, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/alsa-base, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/ieee1394, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: WARNING: All config files need .conf: /etc/modprobe.d/display_class, it will be ignored in a future release.
Wed Mar 4 09:10:09 2009: Starting enhanced syslogd: rsyslogd.
Wed Mar 4 09:10:09 2009: done (acpi-cpufreq).
Mnie to wygląda na to, że konfigi gdzies wcięło. Po tym wszystkim uruchamia się kde i system normalnie wstaje. Mam kde 3.5.
Czy macie jakieś propozycje jak to naprawić?
iria
Post autor: iria »
Niegroźne błędy.
Poczytaj.
Rad
Post autor: Rad »
Warning != error.
PhockouS
Post autor: PhockouS »
Cofnij paczkę do starszej wersji, ja tak zrobiłem.
Sheryph, umieść sobie w jakimś podręcznym miejscu ten odnośnik: http://translate.google.com/?hl=pl
Wed Mar 4 09:10:05 2009: modprobe: UWAGA: Wszystkie pliki konfiguracyjne potrzebne. Conf: / etc / modprobe.d / czarnej listy, to będą ignorowane w przyszłych wersjach.
Nie jest to doskonałe ale pozwoli uniknąć niepotrzebnych alarmów.
giaur
Post autor: giaur »
No tez mialem pytac, komunkat rozumiem, ale to znaczy ze co, nie bedzie juz konfiguracji modprobe czy jak? Czy beda zamiast tego jakies pliki .conf? Raczej niejasny komunikat, o co tu chodzi?
iria
Post autor: iria »
Poprawka jest już w repo Siduksa.
@giaur
W podanym przeze mnie, wyżej linku masz wszystkie informacje.
Sheryph
Wszystko wrócilo do normy po aktualizacji.
Dziękuje Wam za zainteresowanie i odpowiedzi.
Temat do zamknięcia.
SpeedVin
Post autor: SpeedVin »
Niestety u mnie w Sidzie x64 występuje nadal ten problem, a mam dodane repozytorium Siduxa ;-)
To taka uwaga dla innych ;-)
iria
Post autor: iria »
@Pasik
Co do uwag, to wykonałeś :
update-initramfs -d -k $(uname -r)
update-initramfs -c -k $(uname -r)
