Mam problem z apache2 taki, że co tydzień resetuje się. Mam napisane skrypty www do uruchomienia programu. Jak apache2 zresetuje się to pada razem z nim uruchomiony program.
W error.log znalazłem to:
[Sun Feb 22 06:25:55 2009] [notice] Apache/2.2.3 (Debian) PHP/5.2.0-8+etch13 configured -- resuming normal operations
Poogladaj sobie skrypty crona; jak jestes pewien, ze to zawsze dzieje sie co tydzien o 6:25 rano, to pierwszym podejrzanym bylyby skrypty z /etc/cron.weekly/.
#! /bin/sh
# sysklogd Cron script to rotate system log files weekly.
# If you want to rotate logfiles daily, edit
# this script and /etc/cron.daily/sysklogd to get
# the logfiles in sync (they must not occur in both
# files).
# This is a configration file. You are invited to edit
# it and maintain it on your own. You'll have to do
# that if you don't like the default policy
# wrt. rotating logfiles (i.e. with large logfiles
# weekly and daily rotation may interfere). If you edit
# this file and don't let dpkg upgrade it, you have full
# control over it. Please read the manpage to
# syslogd-listfiles.
# Written by Ian A. Murdock <imurdock@debian.org>.
# $Id: cron.weekly,v 1.10 2004-03-31 16:18:15 joey Exp $
test -x /usr/sbin/syslogd-listfiles || exit 0
test -x /sbin/syslogd || exit 0
test -f /usr/share/sysklogd/dummy || exit 0
set -e
cd /var/log
for LOG in `syslogd-listfiles --weekly`
do
if [ -s $LOG ]; then
savelog -g adm -m 640 -u root -c 4 $LOG >/dev/null
fi
done
# Restart syslogd
/etc/init.d/sysklogd reload-or-restart > /dev/null
#!/bin/sh
# man-db cron weekly
set -e
if ! [ -d /var/cache/man ]; then
# Recover from deletion, per FHS.
mkdir -p /var/cache/man
chown man:root /var/cache/man
chmod 2755 /var/cache/man
fi
# regenerate man database
if [ -x /usr/bin/mandb ]; then
# --pidfile /dev/null so it always starts; mandb isn't really a daemon,
# but we want to start it like one.
start-stop-daemon --start --pidfile /dev/null \
--startas /usr/bin/mandb --oknodo --chuid man \
-- --quiet
fi
exit 0
[ Dodano: 2009-03-01, 13:52 ]
Dziś rano znowu to samo ;/
