Po odpaleniu sterownika pojawia się:
Pakiety nagłówkowe zainstalowane wszystkie jak w opisie.ERROR: Unable to build the NVIDIA kernel module.
Liczę na szybką pomoc. Pozdrawiam.
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sun Feb 15 03:55:11 2009
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
precompiled interfaces : true
no ncurses color : false
query latest version : false
OpenGL header files : true
no questions : false
silent : false
no recursion : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : false
no ABI note : false
no RPMs : false
no kernel module : false
force SELinux : default
no X server check : false
force tls : (not specified)
X install prefix : (not specified)
X library install path : (not specified)
X module install path : (not specified)
OpenGL install prefix : (not specified)
OpenGL install libdir : (not specified)
utility install prefix : (not specified)
utility install libdir : (not specified)
doc install prefix : (not specified)
kernel name : (not specified)
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp mirror : ftp://download.nvidia.com
RPM file list : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
ke the installer to attempt to download a kernel interface for your kernel f
rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: No)
-> No precompiled kernel interface was found to match your kernel; this means
that the installer will need to compile a new kernel interface.
-> Performing CC sanity check with CC="cc".
-> Performing CC version check with CC="cc".
-> Kernel source path: '/lib/modules/2.6.26-1-686/build'
-> Kernel output path: '/lib/modules/2.6.26-1-686/build'
-> Performing rivafb check.
-> Performing nvidiafb check.
-> Performing Xen check.
-> Cleaning kernel module build directory.
executing: 'cd ./usr/src/nv; make clean'...
-> Building kernel module:
executing: 'cd ./usr/src/nv; make module SYSSRC=/lib/modules/2.6.26-1-686/bu
ild SYSOUT=/lib/modules/2.6.26-1-686/build'...
NVIDIA: calling KBUILD...
make CC=cc KBUILD_VERBOSE=1 -C /lib/modules/2.6.26-1-686/build SUBDIRS=/tmp
/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv modules
test -e include/linux/autoconf.h -a -e include/config/auto.conf || ( \
echo; \
echo " ERROR: Kernel configuration is invalid."; \
echo " include/linux/autoconf.h or include/config/auto.conf are mis
sing."; \
echo " Run 'make oldconfig && make prepare' on kernel src to fix it
echo; \
/bin/false)
mkdir -p /tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/.tmp_vers
ions ; rm -f /tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/.tmp_
versions/*
make -f scripts/Makefile.build obj=/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05
-pkg1/usr/src/nv
cc -Wp,-MD,/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/.nv.o
.d -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.1.3/include -D__KERNEL_
_ -Iinclude -include include/linux/autoconf.h -Wall -Wundef -Wstrict-protot
ypes -Wno-trigraphs -fno-strict-alia
sing -fno-common -Werror-implicit-function-declaration -Os -fno-stack-prot
ector -m32 -msoft-float -mregparm=3 -freg-struct-return -mpreferred-stack-bo
undary=2 -march=i686 -ffreestanding -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNA
L_FRAME=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -
mno-mmx -mno-sse2 -mno-3dnow -Iinclude/asm-x86/mach-default -fomit-frame-poi
nter -Wdeclaration-after-statement -Wno-pointer-sign -I/tmp/selfgz7530/NVI
DIA-Linux-x86-96.43.05-pkg1/usr/src/nv -Wall -Wimplicit -Wreturn-type -Wswit
ch -Wformat -Wchar-subscripts -Wparentheses -Wpointer-arith -Wno-multichar -
Werror -MD -Wsign-compare -Wno-cast-qual -Wno-error -D_LOOSE_KERNEL_NAMES
-D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING=\"96.43.05\" -UDEBUG -U_DEB
UG -DNDEBUG -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv)
" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -c -o /tmp/selfgz7530/NVIDIA-Linux-
x86-96.43.05-pkg1/usr/src/nv/.tmp_nv.o /tmp/selfgz7530/NVIDIA-Linux-x86-96.4
3.05-pkg1/usr/src/nv/nv.c
In file included from include/linux/list.h:6,
from include/linux/preempt.h:11,
from include/linux/spinlock.h:49,
from include/linux/seqlock.h:29,
from include/linux/time.h:8,
from include/linux/timex.h:57,
from include/linux/sched.h:54,
from include/linux/utsname.h:35,
from /tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src
/nv/nv-linux.h:19,
/nv/nv.c:14:
include/linux/prefetch.h: In function ‘prefetch_range’:
include/linux/prefetch.h:57: warning: pointer of type ‘void *’ used in a
rithmetic
In file included from include/asm/dma-mapping.h:9,
from include/linux/dma-mapping.h:52,
from include/asm-generic/pci-dma-compat.h:7,
from include/asm/pci.h:92,
from include/linux/pci.h:948,
/nv/nv-linux.h:85,
/nv/nv.c:14:
include/linux/scatterlist.h: In function ‘sg_virt’:
include/linux/scatterlist.h:199: warning: pointer of type ‘void *’ used
in arithmetic
In file included from /tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src
/nv/nv-linux.h:108,
/nv/nv.c:14:
include/linux/highmem.h: In function ‘zero_user_segments’:
include/linux/highmem.h:134: warning: pointer of type ‘void *’ used in a
rithmetic
rithmetic
rithmetic
rithmetic
include/linux/highmem.h:137: warning: pointer of type ‘void *’ used in a
rithmetic
rithmetic
rithmetic
rithmetic
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c: In function
‘nvos_proc_create’:
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:505: error: â
€˜proc_root_driver’ undeclared (first use in this function)
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:505: error: (
Each undeclared identifier is reported only once
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:505: error: f
or each function it appears in.)
‘__nv_setup_pat_entries’:
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:833: warning:
comparison between signed and unsigned
‘__nv_restore_pat_entries’:
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:859: warning:
‘nv_kern_cpu_callback’:
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:1170: warning
: comparison between signed and unsigned
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:1177: warning
‘nv_kern_vma_nopage’:
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:1699: error:
‘NOPAGE_SIGBUS’ undeclared (first use in this function)
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c: At top level
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:1706: error:
unknown field ‘nopage’ specified in initializer
/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.c:1706: warning
: initialization from incompatible pointer type
make[3]: *** [/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src/nv/nv.o
] Błąd 1
make[2]: *** [_module_/tmp/selfgz7530/NVIDIA-Linux-x86-96.43.05-pkg1/usr/src
/nv] Błąd 2
NVIDIA: left KBUILD.
nvidia.ko failed to build!
make[1]: *** [module] Błąd 1
make: *** [module] Błąd 2
-> Error.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at http://www.nvidia.com.
