Problem z wymazaniem p
Otaq
Problem z wymazaniem płyty CD-RW
Post autor: Otaq »
Mam nagrywarkę DVD LG GSA-4163B i nie jestem w stanie skasować zawartości płyt CD-RW. Próbowałem formatować płytę za pomocą GnomeBakera i Brasero i żaden nie dał rady...
Szczegóły z GnomeBakera:
wodim: Operation not permitted. Warning: Cannot raise RLIMIT_MEMLOCK limits.scsidev: '/dev/hdc'
devname: '/dev/hdc'
scsibus: -2 target: -2 lun: -2
Linux sg driver version: 3.5.27
Wodim version: 1.1.9
SCSI buffer size: 64512
Beginning DMA speed test. Set CDR_NODMATEST environment variable if device
communication breaks or freezes immediately after that.
TOC Type: 1 = CD-ROM
Device type : Removable CD-ROM
Version : 0
Response Format: 2
Capabilities :
Vendor_info : 'HL-DT-ST'
Identification : 'DVDRAM GSA-4163B'
Revision : 'A106'
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Current: 0x000A (CD-RW)
Profile: 0x0012 (DVD-RAM)
Profile: 0x0011 (DVD-R sequential recording)
Profile: 0x0014 (DVD-RW sequential recording)
Profile: 0x0013 (DVD-RW restricted overwrite)
Profile: 0x001A (DVD+RW)
Profile: 0x001B (DVD+R)
Profile: 0x002B (DVD+R/DL)
Profile: 0x0010 (DVD-ROM)
Profile: 0x0009 (CD-R)
Profile: 0x000A (CD-RW) (current)
Profile: 0x0008 (CD-ROM) (current)
Profile: 0x0002 (Removable disk)
Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
Driver flags : MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
Drive buf size : 1053696 = 1029 KB
Drive DMA Speed: 13696 kB/s 77x CD 9x DVD
Current Secsize: 2048
ATIP info from disk:
Indicated writing power: 3
Reference speed: 6
Is not unrestricted
Is erasable
Disk sub type: High speed Rewritable (CAV) media (1)
ATIP start of lead in: -11649 (97:26/51)
ATIP start of lead out: 359849 (79:59/74)
1T speed low: 4 1T speed high: 10
2T speed low: 4 2T speed high: 0 (reserved val 6)
power mult factor: 1 5
recommended erase/write power: 5
A1 values: 24 1A D8
A2 values: 26 B2 4A
Disk type: Phase change
Manuf. index: 10
Manufacturer: Lead Data Inc.
Starting to write CD/DVD at speed 10.0 in real BLANK mode for single session.
Last chance to quit, starting real write in 5 seconds.Speed set to 1764 KB/s
4 seconds. 3 seconds. 2 seconds. 1 seconds. 0 seconds. Operation starts.
Performing OPC...
Blanking entire disk
Errno: 0 (Success), blank unit scsi sendcmd: no error
CDB: A1 00 00 00 00 00 00 00 00 00 00 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 03 00 00 00 00 10 36 30 00 90 02 00 00 00
Sense Key: 0x3 Medium Error, Segment 0
Sense Code: 0x02 Qual 0x00 (no seek complete) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 18.163s timeout 9600s
wodim: Cannot blank disk, aborting.
Pomyślałem, że spróbuję za pomocą konsoli.
Wynik polecenia:
wodim blank=all
wodim: Operation not permitted. Warning: Cannot raise RLIMIT_MEMLOCK limits.Device was not specified. Trying to find an appropriate drive...
Detected CD-R drive: /dev/cdrw
Using /dev/cdrom of unknown capabilities
Version : 0
Response Format: 2
Capabilities :
Vendor_info : 'TOSHIBA '
Identification : 'DVD-ROM SD-M1712'
Revision : '1004'
Device seems to be: Generic mmc2 DVD-ROM.
wodim: Sorry, no CD/DVD-Recorder or unsupported CD/DVD-Recorder found on this target.
Nie wiem czemu próbuje kasować płytę za pomocą napędu DVD-ROM? Dowiązanie "/dev/cdrw" prowadzi do nagrywarki.
Dodam, że na innym komputerze płytę dało się sformatować i nagrałem ją bez problemu u mnie. Teraz znów chciałbym ją skasować i głupio mi co chwilę chodzić do znajomego żeby kasować płyty.
grucha
Post autor: grucha »
A spróbuj, czy z roota zadziała.
Otaq
Post autor: Otaq »
Długo nie odpowiadałem :-P
Niestety wymazanie płyty spod roota nie udało się :-( Ani Brasero ani GnomeBaker nie dały rady...
Za pomocą konsoli efekt też jest taki sam jak na koncie zwykłego użytkownika.
