getty i inittab - logowanie na serwer przez rs232
dred
Post autor: dred »
Witam wszystkich serdecznie.
Szukam u was pomocy w moim problemie. Mój plik inittab wygląda tak:
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
~~:S:wait:/sbin/sulogin
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# What to do when CTRL-ALT-DEL is pressed.
ca:12345:ctrlaltdel:/sbin/shutdown -t1 -a -r now
# Action on special keypress (ALT-UpArrow).
#kb::kbrequest:/bin/echo "Keyboard Request--edit /etc/inittab to let this work."
# What to do when the power fails/returns.
pf: :p owerwait:/etc/init.d/powerfail start
pn: :p owerfailnow:/etc/init.d/powerfail now
po: :p owerokwait:/etc/init.d/powerfail stop
# /sbin/getty invocations for the runlevels.
# The "id" field MUST be the same as the last
# characters of the device (after "tty").
# Format:
# <id>:<runlevels>:<action>:<process>
# Note that on most Debian systems tty7 is used by the X Window System,
# so if you want to add more getty's go ahead but skip tty7 if you run X.
1:2345:respawn:/sbin/getty 38400 tty1
2:23:respawn:/sbin/getty 38400 tty2
3:23:respawn:/sbin/getty 38400 tty3
4:23:respawn:/sbin/getty 38400 tty4
#5:23:respawn:/sbin/getty 38400 tty5
#6:23:respawn:/sbin/getty 38400 tty6
# Example how to put a getty on a serial line (for a terminal)
T0:23:respawn:/sbin/getty -L ttyS0 115200 vt100
T1:23:respawn:/sbin/getty -h -L ttyS1 115200 vt100
# Example how to put a getty on a modem line.
#T3:23:respawn:/sbin/mgetty -x0 -s 57600 ttyS3
I chcąc się zalogować na serwer przez rs232 nie wyskakuje mi możliwość logowania, czyli nie ma pytania o login i hasło. Podaję moje procesy:
dred:~# ps -A
PID TTY TIME CMD
1 ? 00:00:07 init
2 ? 00:00:00 kthreadd
3 ? 00:00:00 migration/0
4 ? 00:00:16 ksoftirqd/0
5 ? 00:00:00 watchdog/0
6 ? 00:00:12 events/0
7 ? 00:00:00 khelper
39 ? 00:00:04 kblockd/0
41 ? 00:00:00 kacpid
42 ? 00:00:00 kacpi_notify
100 ? 00:00:00 kseriod
130 ? 00:00:00 pdflush
131 ? 00:00:13 pdflush
132 ? 00:00:00 kswapd0
133 ? 00:00:00 aio/0
565 ? 00:00:00 ksuspend_usbd
567 ? 00:00:00 khubd
618 ? 00:00:00 ata/0
621 ? 00:00:00 ata_aux
733 ? 00:01:16 kjournald
814 ? 00:00:00 udevd
1791 ? 00:00:03 kjournald
2060 ? 00:00:00 rc
2067 ? 00:04:02 syslogd
2076 ? 00:02:26 klogd
2085 ? 00:00:00 acpid
2095 ? 00:00:00 dbus-daemon
2111 ? 00:11:06 named
2125 ? 00:00:08 sshd
2154 ? 00:00:03 epmd
2169 ? 00:00:52 beam
2189 ? 00:00:00 inet_gethost
2190 ? 00:00:00 inet_gethost
2526 ? 06:37:38 ntop
2546 ? 00:03:13 asterisk
2589 ? 00:00:26 dhcpd3
2620 ? 00:00:02 cron
2627 ? 00:00:00 S99rc.local
2630 ? 00:00:00 rc.local
2631 ? 00:00:00 su
2632 ? 00:00:21 perl
9310 ? 00:00:31 sshd
9312 pts/0 00:00:04 bash
11980 ? 00:00:00 screen
11981 pts/1 00:00:00 bash
13555 pts/1 00:00:00 ssh
14557 ? 00:00:00 apache2
14563 ? 00:00:00 apache2
14564 ? 00:00:00 apache2
14565 ? 00:00:00 apache2
14566 ? 00:00:00 apache2
14567 ? 00:00:00 apache2
14568 ? 00:00:00 apache2
14569 ? 00:00:00 apache2
14864 pts/0 00:00:00 ps
Nie ma tam demona getty. Co ciekawe, że jak z palca wpiszę:
getty -L 115200 ttyS0 vt100
to dostaję możliwość zalogowanie się do serwera przez COMa.
Proszę Was bardzo o pomoc.
