/var/log/fsck/checkfs
fsck 1.41.3 (12-Oct-2008)
fsck.ext3: Bad magic number in super-block while trying to open /dev/sda8
/dev/sda8:
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
fsck died with exit status 8
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
/dev/sda1 / ext3 errors=remount-ro 0 1
/dev/sda8 /home ext3 defaults 0 2
/dev/sda7 none swap sw 0 0
/dev/hda /media/cdrom0 udf,iso9660 user,noauto 0 0
/dev/hdb5 /mnt/d ntfs-3g rw,uid=1000,gid=100,locale=pl_PL.utf8,user,auto 0 2
/dev/sda5 /mnt/h ntfs-3g rw,uid=1000,gid=100,locale=pl_PL.utf8,user,auto 0 2
/dev/sda6 /mnt/i ntfs-3g rw,uid=1000,gid=100,locale=pl_PL.utf8,user,auto 0 2
System plików bl. 1K B użyte dostępne %uż. zamont. na
/dev/sda1 6728280 2772680 3613820 44% /
udev 10240 108 10132 2% /dev
Disk /dev/hdb: 40.0 GB, 40020664320 bytes
255 heads, 63 sectors/track, 4865 cylinders
Disk identifier: 0xac41ebff
/dev/hdb1 * 1 1578 12675253+ 7 HPFS/NTFS
/dev/hdb2 1579 4865 26402827+ f W95 Ext'd (LBA)
/dev/hdb5 1579 4865 26402796 7 HPFS/NTFS
Disk /dev/sda: 250.0 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders
Disk identifier: 0xf894f894
/dev/sda1 * 1 851 6835626 83 Linux
/dev/sda2 852 30401 237360375 f W95 Ext'd (LBA)
/dev/sda5 4527 23956 156071443+ 7 HPFS/NTFS
/dev/sda6 852 1011 1285137 82 Linux swap / Solaris
/dev/sda7 1012 4526 28234206 83 Linux
/dev/sda8 23957 30401 51769431 7 HPFS/NTFS
