I tutaj są następne problemy:
root@driftclan:~# x11vnc -usepw -shared -forever -display :1
24/01/2009 21:18:46 -usepw: found /root/.vnc/passwd
Settings:
display: :2
authfile: null
subwin: 0x0
-sid mode: 0
clip: null
flashcmap: 0
shiftcmap: 0
force_idx: 0
cmap8to24: 0
8to24_opts: null
24to32: 0
visual: null
overlay: 0
ovl_cursor: 1
scaling: 0 1.0000
viewonly: 0
shared: 1
conn_once: 0
timeout: 0
inetd: 0
filexfer: 1
http: 0
connect: null
connectfile null
vnc_conn: 1
allow: null
input: null
passfile: null
unixpw: 0
unixpw_lst: null
stunnel: 0
accept: null
accept: null
gone: null
users: null
using_shm: 1
flipbytes: 0
onetile: 0
solid: null
blackout: null
xinerama: 1
xtrap: 0
xrandr: 0
xrandrmode: null
padgeom: null
logfile: null
logappend: 0
flag: null
rc_file: ""
norc: 0
dbg: 0
bg: 0
mod_tweak: 1
isolevel3: 0
xkb: 0
skipkeys: null
sloppykeys: 0
skip_dups: 0
addkeysyms: 1
xkbcompat: 0
clearmods: 0
remap: null
norepeat: 1
norepeatcnt:2
nofb: 0
watchbell: 1
watchsel: 1
watchprim: 1
seldir: null
cursor: 1
multicurs: 0
curs_mode: null
arrow: 1
xfixes: 1
alphacut: 240
alphafrac: 0.33
alpharemove:0
alphablend: 1
cursorshape:1
cursorpos: 1
xwarpptr: 0
buttonmap: null
dragging: 1
wireframe: 0xff,3,0,32+8+8+8,all,0.15+0.30+5.0+0.125
wirecopy: always
scrollcopy: always
scr_area: 60000
scr_skip: ##Soffice.bin,##StarOffice
scr_inc: ##Nomatch
scr_keys: null
scr_term: null
scr_keyrep: null
scr_parms: 0+64+32+32,0.02+0.10+0.9,0.03+0.06+0.5+0.1+5.0
fixscreen: null
noxrecord: 0
grabbuster: 0
ptr_mode: 2
inputskip: 10
speeds: null
wmdt: null
debug_ptr: 0
debug_key: 0
defer: 30
waitms: 30
wait_ui: 2.00
nowait_bog: 0
slow_fb: 0.00
readtimeout: 20
take_naps: 1
sb: 60
fbpm: 1
xdamage: 1
xd_area: 20000
xd_mem: 1.000
sigpipe: null
threads: 0
fs_frac: 0.75
gaps_fill: 4
grow_fill: 3
tile_fuzz: 2
snapfb: 0
rawfb: null
pipeinput: null
gui: 0
gui_mode: null
noremote: 0
unsafe: 0
privremote: 0
safer: 0
nocmds: 0
deny_all: 0
pid: 23633
24/01/2009 21:18:46 x11vnc version: 0.8.2 lastmod: 2006-07-12
24/01/2009 21:18:58 ***************************************
24/01/2009 21:18:58 *** XOpenDisplay failed (:2)
*** x11vnc was unable to open the X DISPLAY: ":2", it cannot continue.
*** There may be "Xlib:" error messages above with details about the failure.
Some tips and guidelines:
* An X server (the one you wish to view) must be running before x11vnc is
started: x11vnc does not start the X server.
* You must use -display <disp>, -OR- set and export your DISPLAY
environment variable to refer to the display of the desired X server.
- Usually the display is simply ":0" (in fact x11vnc uses this if you forget
to specify it), but in some multi-user situations it could be ":1", ":2",
or even ":137". Ask your administrator or a guru if you are having
difficulty determining what your X DISPLAY is.
* Next, you need to have sufficient permissions (Xauthority)
to connect to the X DISPLAY. Here are some Tips:
- Often, you just need to run x11vnc as the user logged into the X session.
So make sure to be that user when you type x11vnc.
- Being root is usually not enough because the incorrect MIT-MAGIC-COOKIE
file will be accessed. The cookie file contains the secret key that
allows x11vnc to connect to the desired X DISPLAY.
- You can explicity indicate which MIT-MAGIC-COOKIE file should be used
by the -auth option, e.g.:
x11vnc -auth /home/someuser/.Xauthority -display :0
x11vnc -auth /tmp/.gdmzndVlR -display :0
you must have read permission for the auth file.
- If NO ONE is logged into an X session yet, but there is a greeter login
program like "gdm", "kdm", "xdm", or "dtlogin" running, you will need
to find and use the raw display manager MIT-MAGIC-COOKIE file.
Some examples for various display managers:
gdm: -auth /var/gdm/:0.Xauth
kdm: -auth /var/lib/kdm/A:0-crWk72
xdm: -auth /var/lib/xdm/authdir/authfiles/A:0-XQvaJk
dtlogin: -auth /var/dt/A:0-UgaaXa
Only root will have read permission for the file, and so x11vnc must be run
as root. The random characters in the filenames will of course change,
and the directory the cookie file resides in may also be system dependent.
Sometimes the command "ps wwaux | grep auth" can reveal the file location.
See also: [url]http://www.karlrunge.com/x11vnc/#faq[/url]
Ale po prostu nie chce się połączyć:
Status: connection InitiatedKod: Zaznacz cały
Failed to connect to server (193.**.***.***)
