Snort pokazuje jako IP atakującego router (192.168.13.37), IP "serwera" to 192.168.1.99 jak zrobić żeby pokazywał IP osób z sieci? Wszystkie inne programy dobrze pokazują.From root@debian.home.gateway Fri Jan 23 06:25:02 2009
Return-path: <root@debian.home.gateway>
Envelope-to: root@debian.home.gateway
Delivery-date: Fri, 23 Jan 2009 06:25:02 +0100
Received: from root by debian with local (Exim 4.69)
(envelope-from <root@debian.home.gateway>)
id 1LQEXN-0001Az-EI
for root@debian.home.gateway; Fri, 23 Jan 2009 06:25:02 +0100
To: root@debian.home.gateway
Subject: [SNORT] debian daily report
Message-Id: <E1LQEXN-0001Az-EI@debian>
Date: Fri, 23 Jan 2009 06:25:02 +0100
Status: RO
Events between 01 22 22:33:41 and 01 23 04:57:05
Total events: 4
Signatures recorded: 2
Source IP recorded: 2
Destination IP recorded: 1
Events from same host to same destination using same method
# of from to method
3 192.168.13.37 192.168.1.99 WEB-MISC /doc/ access
Percentage and number of events from a host to a destination
% # of from to
75.00 3 192.168.13.37 192.168.1.99
Percentage and number of events from one host to any with same method
% # of from method
75.00 3 192.168.13.37 WEB-MISC /doc/ access
Percentage and number of events to one certain host
% # of to method
75.00 3 192.168.1.99 WEB-MISC /doc/ access
The distribution of event methods
% # of method
75.00 3 WEB-MISC /doc/ access
3 192.168.13.37 -> 192.168.1.99
Przy okazji jak zmienić tą domenę
root@debian.home.gatewayKod: Zaznacz cały
root@debian
