CRS232 i krzaki w terminalu - po
slayer
CRS232 i krzaki w terminalu - połączenie Debian, Windows
Post autor: slayer »
System to Debian podłączony kablem null-modem z Windowsem. W terminalu Windowsa ustawione 19200 8-N-1. Po wysłaniu jakiegoś tekstu za pomocą tego kodu w terminalu dostaje same krzaki. Kompiluje poleceniem: gcc - o serial serial.c
W internecie znalazłem taki kod:
#include <stdio.h>
#include <stdlib.h>
#include <stdio.h>
#include <unistd.h>
#include <sys/time.h>
#include <sys/types.h>
#include <sys/ioctl.h>
#include <string.h>
#include <termios.h>
#include <fcntl.h>
static int serial_fd;
void serial_set_dtr(int s) // pin 4
    unsigned int v;
    if (serial_fd<0) return;
    ioctl(serial_fd,TIOCMGET,&v);
    if (s) v|=TIOCM_DTR; else v&=~TIOCM_DTR;
    ioctl(serial_fd,TIOCMSET,&v);
int serial_open(char *dev_name, int speed)
    struct termios t;
    int fd;
    int spd;
    switch(speed)
   case 115200: spd=B115200; break;
        case 57600: spd=B57600; break;
   case 38400: spd=B38400; break;
   case 19200: spd=B19200; break;
   case 9600: spd=B9600; break;
   default: return -2;
    fd = open (dev_name, O_RDWR);
    if(fd<0) return -1;
    tcgetattr (fd, &t);
    t.c_iflag = IGNBRK | IGNPAR;
    t.c_oflag = t.c_lflag = t.c_line = 0;
    t.c_cflag = CS8 | CREAD |  CLOCAL | HUPCL | spd;
    tcsetattr (fd, TCSAFLUSH, &t);
    serial_fd = fd;
    return 0;
void serial_close()
    close(serial_fd);
int serial_write(char *data, int len)
    return write(serial_fd, data, len);
int serial_read(char *data, int len)
    int nbytes=0;
    while(len)
   if(read(serial_fd, data, 1)==1) { len--;data++; nbytes++; }
    return nbytes;
void serial_write_byte(unsigned char b)
    write (serial_fd,&b,1);
unsigned char serial_read_byte()
    unsigned char b;
    serial_read(&b,1);
//    fprintf(stderr,"%02x ", b);
    return b;
int serial_data_avail()
    fd_set set;
    struct timeval tv;
    FD_ZERO(&set);
    FD_SET(serial_fd,&set);
    tv.tv_sec = 0;
    tv.tv_usec = 0;
    return select(serial_fd+1, &set, NULL, NULL, &tv)>0;
unsigned int sys_get_clock_usec()
    struct timezone tz={0,0};
    struct timeval tv;
    gettimeofday(&tv,&tz);
    return tv.tv_usec + tv.tv_sec * 1000000;
void sys_delay(int msecs)
    usleep(msecs*1000);
int main()
   serial_open("/dev/ttyS1", 19200);
   serial_write("tekst", 5);
   serial_close();
   return 0;
Macie jakieś propozycje co jest źle?
