Mam problem, otóż gdy chce uruchomić serwer (open tibia serwer) wyskakuje mi błąd
plik config.lua jest tam gdzie powinien być, więc nie wiem w czym jest problem.>> Loading config
> ERROR: Unable to load config.lua!
err:heap:HEAP_ValidateInUseArena Heap 0x110000: in-use arena 0x113c18 next block has PREV_FREE flag
err:heap:HEAP_ValidateInUseArena Heap 0x110000: in-use arena 0x113c38 next block has PREV_FREE flag
wine: Unhandled page fault on read access to 0x0000000c at address 0x65f1a0 (thr ead 0016), starting debugger...
Unhandled exception: page fault on read access to 0x0000000c in 32-bit code (0x0 065f1a0).
Register dump:
CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b
EIP:0065f1a0 ESP:7eacda08 EBP:7eacda28 EFLAGS:00010246( - 00 -RIZP1)
EAX:00113908 EBX:00000000 ECX:00113cc8 EDX:00000000
ESI:00113cc8 EDI:00113c80
Stack dump:
0x7eacda08: 00113cc8 00770a98 00770aa0 00770a9c
0x7eacda18: 00770a98 00770a90 000003e8 00000000
0x7eacda28: 7eacda48 00733ae8 00113c80 00770a94
0x7eacda38: 7eacda48 00733a74 00770a90 00000102
0x7eacda48: 7eacdab8 005cb599 00770a90 00113c80
0x7eacda58: 00000227 7bc868fc 00000000 00110000
Backtrace:
=>1 0x0065f1a0 in theforgottenserver (+0x25f1a0) (0x7eacda28)
2 0x00733ae8 in theforgottenserver (+0x333ae8) (0x7eacda48)
3 0x005cb599 in theforgottenserver (+0x1cb599) (0x7eacdab8)
4 0x7edf8e81 in msvcrt (+0x28e81) (0x7eacdad8)
5 0x7bc691be call_thread_entry_point+0xe() in ntdll (0x7eacdae8)
6 0x7bc69832 in ntdll (+0x59832) (0x7eacdb88)
7 0x7bc69a43 in ntdll (+0x59a43) (0x7eace478)
8 0xf7dbbfbc start_thread+0x6d() in libpthread.so.0 (0x7eace4e8)
9 0xf7d5580e __clone+0x5e() in libc.so.6 (0x00000000)
0x0065f1a0: movl 0xc(%edx),%eax
Modules:
Module Address Debug info Name (36 modules)
PE 340000- 39e000 Deferred sqlite3
PE 3a0000- 3b6000 Deferred mysql
PE 400000- 7a8000 Export theforgottenserver
PE 9b0000- baf000 Deferred libmysql
PE 10000000-1001d000 Deferred lua5.1
PE 61b80000-61b9c000 Deferred zlib1
PE 66000000-66157000 Deferred libiconv-2
PE 70f40000-7132d000 Deferred libxml2-2
ELF 7b800000-7b929000 Deferred kernel32<elf>
\-PE 7b820000-7b929000 \ kernel32
ELF 7bc00000-7bca2000 Export ntdll<elf>
\-PE 7bc10000-7bca2000 \ ntdll
ELF 7bf00000-7bf03000 Deferred <wine-loader>
ELF 7ecdf000-7ecf3000 Deferred mswsock<elf>
\-PE 7ece0000-7ecf3000 \ mswsock
ELF 7ecf3000-7ed06000 Deferred libresolv.so.2
ELF 7ed06000-7ed24000 Deferred iphlpapi<elf>
\-PE 7ed10000-7ed24000 \ iphlpapi
ELF 7ed24000-7ed50000 Deferred ws2_32<elf>
\-PE 7ed30000-7ed50000 \ ws2_32
ELF 7ed50000-7ed6a000 Deferred wsock32<elf>
\-PE 7ed60000-7ed6a000 \ wsock32
ELF 7ed6a000-7edbb000 Deferred advapi32<elf>
\-PE 7ed80000-7edbb000 \ advapi32
ELF 7edbb000-7ee23000 Export msvcrt<elf>
\-PE 7edd0000-7ee23000 \ msvcrt
ELF 7efa0000-7efab000 Deferred libnss_files.so.2
ELF 7efab000-7efb5000 Deferred libnss_nis.so.2
ELF 7efb5000-7efcb000 Deferred libnsl.so.1
ELF 7efcb000-7efd4000 Deferred libnss_compat.so.2
ELF 7efd4000-7eff8000 Deferred libm.so.6
ELF f7c88000-f7c8c000 Deferred libdl.so.2
ELF f7c8c000-f7db7000 Export libc.so.6
ELF f7db7000-f7dc8000 Export libpthread.so.0
ELF f7dc8000-f7efe000 Deferred libwine.so.1
ELF f7f09000-f7f21000 Deferred ld-linux.so.2
Threads:
process tid prio (all id:s are in hex)
00000008 (D) Z:\opt\ots\TheForgottenServer.exe
00000018 0
00000017 0
00000016 0 <==
00000015 0
00000009 0
0000000c
00000013 0
00000012 0
0000000e 0
0000000d 0
0000000f
00000014 0
00000011 0
00000010 0
Backtrace:
Dodam, że jedyny dostęp jaki mam to tylko dzięki programowi PuTTy. Nie ma trybu graficznego
