[ 6098.292296] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6098.545081] wlan0: authentication with AP 00:1e:58:17:7f:bc timed out
[ 6110.533425] wlan0: Initial auth_alg=0
[ 6110.533425] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6110.731946] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6110.931943] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6111.158471] wlan0: authentication with AP 00:1e:58:17:7f:bc timed out
[ 6123.394176] wlan0: Initial auth_alg=0
[ 6123.394176] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6123.593188] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6123.843909] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6124.059922] wlan0: authentication with AP 00:1e:58:17:7f:bc timed out
[ 6136.172753] wlan0: Initial auth_alg=0
[ 6136.172759] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6136.174262] wlan0: Initial auth_alg=0
[ 6136.174267] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6136.381388] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6136.673825] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6136.884816] wlan0: authentication with AP 00:1e:58:17:7f:bc timed out
[ 6149.106869] wlan0: Initial auth_alg=0
[ 6149.106877] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6149.108428] wlan0: Initial auth_alg=0
[ 6149.108433] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6149.328597] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6149.531107] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6149.731103] wlan0: authentication with AP 00:1e:58:17:7f:bc timed out
[ 6162.112298] ACPI: PCI interrupt for device 0000:10:00.0 disabled
[ 6162.220428] ACPI: PCI Interrupt 0000:10:00.0[A] -> GSI 17 (level, low) -> IRQ 17
[ 6162.220579] PM: Writing back config space on device 0000:10:00.0 at offset 1 (was 100002, writing 100006)
[ 6162.265258] Registered led device: iwl-phy0:radio
[ 6162.265258] Registered led device: iwl-phy0:assoc
[ 6162.265258] Registered led device: iwl-phy0:RX
[ 6162.265258] Registered led device: iwl-phy0:TX
[ 6162.273257] ADDRCONF(NETDEV_UP): wlan0: link is not ready
// ponowne laczenie
[ 6188.608774] wlan0: Initial auth_alg=0
[ 6188.608774] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6188.822093] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6189.022091] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6189.244884] wlan0: authentication with AP 00:1e:58:17:7f:bc timed out
[ 6201.774893] wlan0: Initial auth_alg=0
[ 6201.774893] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6201.780128] wlan0: Initial auth_alg=0
[ 6201.780128] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6201.981507] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6202.184504] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 6202.420496] wlan0: authentication with AP 00:1e:58:17:7f:bc timed outKod: Zaznacz cały
[ 969.701816] wlan0: Initial auth_alg=0
[ 969.701816] wlan0: authenticate with AP 00:1e:58:17:7f:bc
[ 969.705510] wlan0: RX authentication from 00:1e:58:17:7f:bc (alg=0 transaction=2 status=0)
[ 969.705510] wlan0: authenticated
[ 969.705510] wlan0: associate with AP 00:1e:58:17:7f:bc
[ 969.705510] wlan0: RX AssocResp from 00:1e:58:17:7f:bc (capab=0x431 status=0 aid=2)
[ 969.705510] wlan0: associated
[ 969.705510] wlan0: switched to short barker preamble (BSSID=00:1e:58:17:7f:bc)
[ 969.705510] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 976.281229] wlan0: deauthenticate(reason=3) // <- !!!
[ 977.562020] ACPI: PCI interrupt for device 0000:10:00.0 disabled
[ 981.677017] ACPI: PCI Interrupt 0000:10:00.0[A] -> GSI 17 (level, low) -> IRQ 17
[ 981.677170] PM: Writing back config space on device 0000:10:00.0 at offset 1 (was 100002, writing 100006)
[ 981.789832] Registered led device: iwl-phy0:radio
[ 981.789832] Registered led device: iwl-phy0:assoc
[ 981.789832] Registered led device: iwl-phy0:RX
[ 981.789832] Registered led device: iwl-phy0:TX
[ 981.797832] ADDRCONF(NETDEV_UP): wlan0: link is not ready
