pppd call neoKod: Zaznacz cały
Plugin pppoatm.so loaded.Kod: Zaznacz cały
apt-get install pppKod: Zaznacz cały
lock
defaultroute
noipdefault
noauth
holdoff 4
maxfail 25
persist
asyncmap 0
lcp-echo-interval 2
lcp-echo-failure 7
name xxxxxxx@yyyyyyyyyy
user xxxxxxx@yyyyyyyyyyl
plugin pppoatm.so
0.35Kod: Zaznacz cały
# Secrets for authentication using CHAP
# client server secret IP addresses
"xxxxxxx@yyyyyyyyyy" * "zzzzzzz" *Kod: Zaznacz cały
#! /bin/sh
PATH=/usr/sbin:/usr/bin:/sbin:/bin
NAME=pppd
DAEMON=/usr/sbin/pppd
PEER="neo" ########### lub net24
DAEMON_ARGS="call $PEER linkname $PEER"
PIDFILE=/var/run/ppp-$PEER.pid
SCRIPTNAME=/etc/init.d/neo ############# lub /etc/init.d/net24
# Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
do_start()
start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null \
|| return 1
start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON -- \
$DAEMON_ARGS \
|| return 2
do_stop()
start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --name $NAME
RETVAL="$?"
[ "$RETVAL" = 2 ] && return 2
start-stop-daemon --stop --quiet --oknodo --retry=0/30/KILL/5 --exec $DAEMON
[ "$?" = 2 ] && return 2
rm -f $PIDFILE
return "$RETVAL"
case "$1" in
start)
[ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
do_start
case "$?" in
0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;;
2) [ "$VERBOSE" != no ] && log_end_msg 1 ;;
esac
stop)
[ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME"
do_stop
case "$?" in
esac
restart|force-reload)
log_daemon_msg "Restarting $DESC" "$NAME"
do_stop
case "$?" in
0|1)
do_start
case "$?" in
0) log_end_msg 0 ;;
1) log_end_msg 1 ;; # Old process is still running
*) log_end_msg 1 ;; # Failed to start
esac
# Failed to stop
log_end_msg 1
esac
#echo "Usage: $SCRIPTNAME {start|stop|restart|reload|force-reload}" >&2
echo "Usage: $SCRIPTNAME {start|stop|restart|force-reload}" >&2
exit 3
esacKod: Zaznacz cały
chmod u+x /etc/init.d/neo
update-rc.d neo defaults 95
nameserver 194.204.152.34
nameserver 194.204.159.1Kod: Zaznacz cały
