root@ks367269:~# cd stable
root@ks367269:~/stable# ./configure --prefix=/stable
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for gcc option to accept ISO C89... none needed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking whether byte ordering is bigendian... no
checking whether pointers can be stored in ints (old code)... yes (with -m32)
checking whether gcc supports -Wno-unused-parameter... yes
checking whether gcc supports -Wno-pointer-sign... yes
checking whether gcc supports -Wno-switch... yes
checking for setrlimit... no
checking for inflateEnd in -lz... no
configure: error: zlib library not found or incompatible, please specify the correct path with --with-zlib=DIR... stopping
root@ks367269:~/stable# make
make: *** Nie podano obiektów i nie znaleziono makefile. Stop.
root@ks367269:~/stable# make sql
make: *** Brak reguł do wykonania obiektu `sql'. Stop.
# apt-get install libgmp3
# apt-get install libgmp3-dev
# apt-get install zlib1g
# apt-get install zlib1g-dev
# apt-get install zlibc
Pomoże ktoś?
