xorg.conf:
# package.
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "aticonfig-Screen[0]" 0 0
EndSection
Section "Files"
# path to defoma fonts
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "v4l"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/psaux"
Option "Protocol" "PS/2"
EndSection
Section "Monitor"
Identifier "HP L1906"
HorizSync 30.0 - 83.0
VertRefresh 50.0 - 76.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "ATI Technologies Inc RV370 [Sapphire X550 Silent]"
Driver "ati"
BusID "PCI:1:0:0"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]"
Driver "fglrx"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc RV370 [Sapphire X550 Silent]"
Monitor "HP L1906"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x1024" "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]"
Device "aticonfig-Device[0]"
Monitor "aticonfig-Monitor[0]"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection
Logi:
[code:1:a5c693193a]X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux debian 2.6.18-4-686 #1 SMP Wed Feb 21 16:06:54 UTC 2007 i686
Build Date: 01 March 2007
Before reporting problems, check
http://wiki.x.org
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Mar 17 21:32:15 2007
(==) ServerLayout "Default Layout"
(**) |-->Screen "aticonfig-Screen[0]" (0)
(**) | |-->Monitor "aticonfig-Monitor[0]"
(**) | |-->Device "aticonfig-Device[0]"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/75dpi" does not exist.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(**) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to "/etc/X11/rgb"
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.0
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules/libpcidata.so
ABI class: X.Org Video Driver, version 1.0
(++) using VT number 7
(II) PCI: 00:00:0: chip 8086,2580 card 1458,2580 rev 0e class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2581 card 0000,0000 rev 0e class 06,04,00 hdr 01
(II) PCI: 00:1d:0: chip 8086,2658 card 1458,2658 rev 05 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,2659 card 1458,2659 rev 05 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,265a card 1458,265a rev 05 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,265b card 1458,265a rev 05 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,265c card 1458,5006 rev 05 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev d5 class 06,04,01 hdr 81
(II) PCI: 00:1e:2: chip 8086,266e card 1458,ae01 rev 05 class 04,01,00 hdr 00
(II) PCI: 00:1f:0: chip 8086,2640 card 0000,0000 rev 05 class 06,01,00 hdr 80
(II) PCI: 00:1f:2: chip 8086,2651 card 1458,2651 rev 05 class 01,01,80 hdr 00
(II) PCI: 00:1f:3: chip 8086,266a card 1458,266a rev 05 class 0c,05,00 hdr 00
(II) PCI: 01:00:0: chip 1002,5b63 card 0000,0000 rev 00 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,5b73 card 0000,0001 rev 00 class 03,80,00 hdr 00
(II) PCI: 02:00:0: chip 14f1,8800 card 0000,0000 rev 05 class 04,00,00 hdr 80
(II) PCI: 02:05:0: chip 11ab,4320 card 1458,e000 rev 13 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x00009000 - 0x000090ff (0x100) IX
[1] -1 0 0x00009400 - 0x000094ff (0x100) IX
[2] -1 0 0x00009800 - 0x000098ff (0x100) IX
[3] -1 0 0x00009c00 - 0x00009cff (0x100) IX
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xe8000000 - 0xe9ffffff (0x2000000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX
[1] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[2] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[3] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xea000000 - 0xecffffff (0x3000000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0x50000000 - 0x500fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) ATI Technologies Inc RV370 [ATI Sapphire X550 Silent] rev 0, Mem @ 0xe0000000/27, 0xe9000000/16, I/O @ 0x9000/8
(--) PCI: (1:0:1) ATI Technologies Inc RV370 secondary [ATI Sapphire X550 Silent] rev 0, Mem @ 0xe9010000/16
(--) PCI: (2:0:0) unknown vendor (0x14f1) unknown chipset (0x8800) rev 5, Mem @ 0xea000000/24
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xec000000 - 0xec003fff (0x4000) MX[B]
[1] -1 0 0xed002000 - 0xed0020ff (0x100) MX[B]
[2] -1 0 0xed001000 - 0xed0011ff (0x200) MX[B]
[3] -1 0 0xed000000 - 0xed0003ff (0x400) MX[B]
[4] -1 0 0xea000000 - 0xeaffffff (0x1000000) MX[B](B)
[5] -1 0 0xe9000000 - 0xe900ffff (0x10000) MX[B](B)
[6] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
[7] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[8] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[9] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[10] -1 0 0x0000c400 - 0x0000c43f (0x40) IX[B]
[11] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[12] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[13] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[14] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[15] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
[16] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
(II) Inactive PCI resource ranges:
[0] -1 0 0xe9010000 - 0xe901ffff (0x10000) MX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xec000000 - 0xec003fff (0x4000) MX[B]
[5] -1 0 0xed002000 - 0xed0020ff (0x100) MX[B]
[6] -1 0 0xed001000 - 0xed0011ff (0x200) MX[B]
[7] -1 0 0xed000000 - 0xed0003ff (0x400) MX[B]
[8] -1 0 0xea000000 - 0xeaffffff (0x1000000) MX[B](B)
[9] -1 0 0xe9000000 - 0xe900ffff (0x10000) MX[B](B)
[10] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MX[B](B)
[11] -1 0 0xe9010000 - 0xe901ffff (0x10000) MX[B](B)
[12] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[13] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[14] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[15] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[16] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[17] -1 0 0x0000c400 - 0x0000c43f (0x40) IX[B]
[18] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[19] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[20] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[21] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[22] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
[23] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
compiled for 7.1.1, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "v4l"
(II) Loading /usr/lib/xorg/modules/drivers/v4l_drv.so
(II) Module v4l: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.1.1
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: "fglrx"
(II) Loading /usr/lib/xorg/modules/drivers/fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.1.0, module version = 8.28.8
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
compiled for 7.1.1, module version = 1.1.1
(II) v4l driver for Video4Linux
(II) ATI Radeon/FireGL: The following chipsets are supported:
RADEON 9000/9000 PRO (RV250 4966), RADEON 9000 LE (RV250 4967),
MOBILITY FireGL 9000 (M9 4C64), MOBILITY RADEON 9000 (M9 4C66),
RADEON 9000 PRO (D9 4C67), RADEON 9250 (RV280 5960),
RADEON 9250/9200 Series (RV280 5961),
RADEON 9250/9200 Series (RV280 5962),
RADEON 9250/9200 Series (RV280 5964), FireMV 2200 PCI (RV280 5965),
MOBILITY RADEON 9200 (M9+ 5C61), MOBILITY RADEON 9200 (M9+ 5C63),
FireGL 8800 (R200 5148), RADEON 8500 (R200 514C),
RADEON 9100 (R200 514D), RADEON 8500 AIW (R200 4242),
RADEON 9600 (RV350 4150), RADEON 9600 SE (RV350 4151),
RADEON 9600 PRO (RV360 4152), RADEON 9600 (RV350 4E51),
MOBILITY RADEON 9600/9700 (M10/M11 4E50),
MOBILITY RADEON 9500 (M11 4E52), MOBILITY RADEON 9550 (M12 4E56),
RADEON 9500 (R300 4144), RADEON 9600 TX (R300 4146),
FireGL Z1 (R300 4147), RADEON 9700 PRO (R300 4E44),
RADEON 9500 PRO/9700 (R300 4E45), RADEON 9600 TX (R300 4E46),
FireGL X1 (R300 4E47), RADEON 9800 SE (R350 4148),
RADEON 9500 (R350 4149), RADEON 9550 (RV350 4153),
FireGL T2 (RV350 4154), RADEON 9600 (RV351 4155),
RADEON 9800 PRO (R350 4E48), RADEON 9800 (R350 4E49),
RADEON 9800 XT (R360 4E4A), FireGL X2-256/X2-256t (R350 4E4B),
MOBILITY FireGL T2/T2e (M10/M11 4E54), RADEON X300/X550 (RV370 5B60),
RADEON X600 (RV380 5B62), RADEON X550 (RV370 5B63),
FireGL V3100 (RV370 5B64), FireMV 2200 (RV370 5B65),
MOBILITY RADEON X300 (M22 5460), MOBILITY RADEON X300 (M22 5461),
MOBILITY RADEON X600 SE (M24 5462), MOBILITY FireGL V3100 (M22 5464),
RADEON X600/X550 Series (RV380 3E50), FireGL V3200 (RV380 3E54),
MOBILITY RADEON X600 (M24 3150), MOBILITY RADEON X300 (M22 3152),
MOBILITY FireGL V3200 (M24 3154), RADEON X800 (R420 4A48),
RADEON X800 PRO (R420 4A49), RADEON X800 SE (R420 4A4A),
RADEON X800 XT (R420 4A4B), RADEON X800 (R420 4A4C),
FireGL X3-256 (R420 4A4D), MOBILITY RADEON 9800 (M18 4A4E),
RADEON X800 SE (R420 4A4F),
RADEON X800 XT Platinum Edition (R420 4A50),
RADEON X800 VE (R420 4A54), RADEON X800 (R423 5548),
RADEON X800 GTO (R423 5549),
RADEON X800 XT Platinum Edition (R423 554A),
RADEON X800 GT (R423 554B), RADEON X800 XT (R423 5D57),
FireGL V7100 (R423 5550), FireGL V5100 (R423 5551),
MOBILITY RADEON X800 XT (M28 5D48), MOBILITY FireGL V5100 (M28 5D49),
MOBILITY RADEON X800 (M28 5D4A), RADEON X800 XL (R430 554D),
RADEON X800 GT (R430 554E), RADEON X800 GTO (R430 554F),
RADEON X850 XT Platinum Edition (R480 5D4D),
RADEON X800 GTO (R480 5D4F), FireGL V7200 (R480 5D50),
RADEON X850 XT (R480 5D52), RADEON X850 (R481 4B48),
RADEON X850 XT (R481 4B49), RADEON X850 SE (R481 4B4A),
RADEON X850 PRO (R481 4B4B),
RADEON X850 XT Platinum Edition (R481 4B4C),
MOBILITY FireGL V5000 (M26 564A), MOBILITY FireGL V5000 (M26 564B),
FireGL V5000 (RV410 5E48), RADEON X700 XT (RV410 5E4A),
RADEON X700 PRO (RV410 5E4B), RADEON X700 SE (RV410 5E4C),
RADEON X700 (RV410 5E4D), RADEON X700/X550 Series (RV410 5E4F),
MOBILITY RADEON X700 (M26 5652), MOBILITY RADEON X700 (M26 5653),
MOBILITY RADEON X700 XL (M26-XC 564F),
RADEON 9000/9100 IGP Series (RS300 5834),
RADEON 9000 PRO/9100 PRO IGP (RS350 7834),
MOBILITY RADEON 9000 IGP (RL300MB 7835),
MOBILITY RADEON 9000/9100 IGP (RS300M 5835),
RADEON XPRESS 200 (RS400 5A41), RADEON XPRESS 200M (RS400 5A42),
RADEON XPRESS 200 (RS480 5954), RADEON XPRESS 200M (RS480 5955),
RADEON XPRESS 200 (RS482 5974), RADEON XPRESS 200M (RS482 5975),
RADEON XPRESS 200 (RC410 5A61), RADEON XPRESS 200M (RC410 5A62),
RADEON X1800 (R520 7100), MOBILITY RADEON X1800 XT (M58 7101),
MOBILITY RADEON X1800 (M58 7102), MOBILITY FireGL V7200 (M58 7103),
FireGL V7200 (R520 7104), FireGL V5300 (R520 7105),
MOBILITY FireGL V7100 (M58 7106), RADEON X1800 Series (R520 7108),
RADEON X1800 Series (R520 7109), RADEON X1800 Series (R520 710A),
RADEON X1800 Series (R520 710B), RADEON X1800 Series (R520 710C),
FireGL V7300 (R520 710E), FireGL V7350 (R520 710F),
MOBILITY RADEON X1300 (M52 714B), MOBILITY RADEON X1300 (M52 714C),
RADEON X1600 Series (RV515 7140), RADEON X1300 Series (RV515 7142),
MOBILITY FireGL (M54 GL 7144), MOBILITY RADEON X1400 (M54 7145),
RADEON X1300 Series (RV515 7146), MOBILITY RADEON X1300 (M52 7149),
MOBILITY RADEON X1300 (M52 714A), RADEON X1300 Series (RV515 714D),
RADEON X1300 Series (RV515 714E), FireGL V3300 (RV515 7152),
RADEON X1300 Series (RV515 715E), RADEON X1300 (RV516 7180),
RADEON X1600 Series (RV516 7181), RADEON X1300 (RV516 7183),
MOBILITY RADEON X1450 (M64P 7186), RADEON X1300 (RV516 7187),
MOBILITY RADEON X1350 (M62P 718B),
MOBILITY RADEON X1350 (M62CSP 718C),
MOBILITY RADEON X1450 (M64CSP 718D),
MOBILITY RADEON X1350 (M62S 7196), RADEON X1900 (R580 7240),
RADEON X1900 (R580 7243), RADEON X1900 (R580 7244),
RADEON X1900 (R580 7245), RADEON X1900 (R580 7246),
RADEON X1900 (R580 7247), RADEON X1900 (R580 7248),
RADEON X1900 (R580 7249), RADEON X1900 (R580 724A),
RADEON X1900 (R580 724B), RADEON X1900 (R580 724C),
RADEON X1900 (R580 724D), FireStream 2U (R580 724E),
FireStream 2U (R580 724F), RADEON X1600 Series (RV530 71C0),
RADEON X1600 Series (RV530 71C2), MOBILITY FireGL V5200 (M56 71C4),
MOBILITY RADEON X1600 (M56 71C5),
RADEON X1600 Series (RV530 LE 71C6),
RADEON X1600 Series (RV530 VE 71CE), FireGL V3400 (RV530 71D2),
MOBILITY RADEON X1700 (M66-XT 71D6), FireGL V5200 (RV530 71DA),
RADEON X1600 Series (RV530 SE 71DE), RADEON X1600 XT (RV535 XT 71C1),
MOBILITY FireGL V5250 (M66GL 71D4),
MOBILITY RADEON X1700 (M66-P 71D5), RADEON Xpress 1200 (RS600 7941),
RADEON Xpress 1200 (RS600 7942)
(II) Primary Device is: PCI 01:00:0
(II) ATI Proprietary Linux Driver Version Identifier:8.28.8
(II) ATI Proprietary Linux Driver Release Identifier: LGDr8.28g1
(II) ATI Proprietary Linux Driver Build Date: Aug 17 2006 09:28:12
(II) ATI Proprietary Linux Driver Build Information: autobuild-rel-r6-8.28.1.1.2.3-driver-lnx-x86-x86_64-287161
(--) Assigning device section with no busID to primary device
(WW) fglrx: No matching Device section for instance (BusID PCI:1:0:1) found
(--) Chipset RADEON X550 (RV370 5B63) found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) fglrx(0): pEnt->device->identifier=0x81e35b8
(II) resource ranges after probing:
[12] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[13] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[14] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[18] -1 0 0x00000500 - 0x0000051f (0x20) IX[B]
[19] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[20] -1 0 0x0000c400 - 0x0000c43f (0x40) IX[B]
[21] -1 0 0x0000c000 - 0x0000c0ff (0x100) IX[B]
[22] -1 0 0x0000b800 - 0x0000b81f (0x20) IX[B]
[23] -1 0 0x0000b400 - 0x0000b41f (0x20) IX[B]
[24] -1 0 0x0000b000 - 0x0000b01f (0x20) IX[B]
[25] -1 0 0x0000bc00 - 0x0000bc1f (0x20) IX[B]
[26] -1 0 0x00009000 - 0x000090ff (0x100) IX[B](B)
[27] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[28] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) fglrx(0): === [R200PreInit] === begin, [s]
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules/libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.1.0
(II) fglrx(0): PCI bus 1 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "DPMS" "true"
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(==) fglrx(0): Gamma Correction for I is 0x06419064
(==) fglrx(0): Gamma Correction for II is 0x06419064
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "int10"
(II) Reloading /usr/lib/xorg/modules/libint10.so
(II) Loading sub module "vm86"
(II) LoadModule: "vm86"
(II) Loading /usr/lib/xorg/modules/libvm86.so
(II) Module vm86: vendor="X.Org Foundation"
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(--) fglrx(0): Chipset: "RADEON X550 (RV370 5B63)" (Chipset = 0x5b63)
(--) fglrx(0): (PciSubVendor = 0x0000, PciSubDevice = 0x0000)
(--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xe0000000
(--) fglrx(0): MMIO registers at 0xe9000000
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) Loading sub module "vbe"
(II) Reloading /usr/lib/xorg/modules/libvbe.so
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 2.0
(II) fglrx(0): VESA VBE Total Mem: 16384 kB
(II) fglrx(0): VESA VBE OEM: ATI RV370
(II) fglrx(0): VESA VBE OEM Software Rev: 1.0
(II) fglrx(0): VESA VBE OEM Vendor: ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: V380
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
(II) Reloading /usr/lib/xorg/modules/linux/libdrm.so
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 8, (OK)
drmOpenDevice: node name is /dev/dri/card1
drmOpenDevice: open result is -1, (No such device)
drmOpenDevice: Open failed
drmOpenDevice: node name is /dev/dri/card2
drmOpenDevice: node name is /dev/dri/card3
drmOpenDevice: node name is /dev/dri/card4
drmOpenDevice: node name is /dev/dri/card5
drmOpenDevice: node name is /dev/dri/card6
drmOpenDevice: node name is /dev/dri/card7
drmOpenDevice: node name is /dev/dri/card8
drmOpenDevice: node name is /dev/dri/card9
drmOpenDevice: node name is /dev/dri/card10
drmOpenDevice: node name is /dev/dri/card11
drmOpenDevice: node name is /dev/dri/card12
drmOpenDevice: node name is /dev/dri/card13
drmOpenDevice: node name is /dev/dri/card14
(WW) fglrx(0): Failed to open DRM connection
(--) fglrx(0): VideoRAM: 131072 kByte, Type: DDR SGRAM / SDRAM
(II) fglrx(0): PCIE card detected
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(II) Loading sub module "ddc"
(II) Reloading /usr/lib/xorg/modules/libddc.so
(II) fglrx(0): Connected Display1: CRT on primary DAC
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: HWP Model: 265e Serial#: 16843009
(II) fglrx(0): Year: 2006 Week: 39
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
(II) fglrx(0): Sync: Separate
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 38 vert.: 30
(II) fglrx(0): Gamma: 2.20
(II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) fglrx(0): Default color space is primary color space
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.634 redY: 0.354 greenX: 0.287 greenY: 0.621
(II) fglrx(0): blueX: 0.138 blueY: 0.077 whiteX: 0.313 whiteY: 0.329
(II) fglrx(0): Supported VESA Video Modes:
(II) fglrx(0): 720x400@70Hz
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 640x480@72Hz
(II) fglrx(0): 640x480@75Hz
(II) fglrx(0): 800x600@60Hz
(II) fglrx(0): 800x600@72Hz
(II) fglrx(0): 800x600@75Hz
(II) fglrx(0): 832x624@75Hz
(II) fglrx(0): 1024x768@60Hz
(II) fglrx(0): 1024x768@70Hz
(II) fglrx(0): 1024x768@75Hz
(II) fglrx(0): 1280x1024@75Hz
(II) fglrx(0): 1152x870@75Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported Future Video Modes:
(II) fglrx(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 108.0 MHz Image Size: 337 x 270 mm
(II) fglrx(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
(II) fglrx(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
(II) fglrx(0): Ranges: V min: 50 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 140 MHz
(II) fglrx(0): Monitor name: HP L1906
(II) fglrx(0): Serial No: CND639154T
(II) fglrx(0): End of Display1 EDID data --------------------
(II) fglrx(0): Primary Controller - CRT on primary DAC
(II) fglrx(0): Internal Desktop Setting: 0x00000008
(II) fglrx(0): POWERplay version 3. 1 power state available:
(II) fglrx(0): 1. 398/196MHz @ 50Hz [enable load balancing]
(==) fglrx(0): Qbs disabled
(==) fglrx(0): FAST_SWAP disabled
(==) fglrx(0): PseudoColor visuals disabled
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(==) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Total of 37 modes found for primary display.
(--) fglrx(0): Virtual size is 1280x1024 (pitch 0)
(**) fglrx(0): *Mode "1280x1024": 135.0 MHz (scaled from 0.0 MHz), 80.0 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1280x1024" 135.00 1280 1296 1440 1688 1024 1025 1028 1066
(**) fglrx(0): Default mode "1280x1024": 128.9 MHz (scaled from 0.0 MHz), 74.6 kHz, 70.0 Hz
(II) fglrx(0): Modeline "1280x1024" 128.94 1280 1368 1504 1728 1024 1025 1028 1066 +hsync
(**) fglrx(0): Default mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x1024" 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
(**) fglrx(0): *Mode "1280x720": 74.5 MHz (scaled from 0.0 MHz), 44.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x720" 74.48 1280 1336 1472 1664 720 721 724 746 +hsync
(**) fglrx(0): *Mode "1152x864": 108.0 MHz (scaled from 0.0 MHz), 67.5 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1152x864" 108.00 1152 1216 1344 1600 864 865 868 900
(**) fglrx(0): Default mode "1152x864": 96.8 MHz (scaled from 0.0 MHz), 63.0 kHz, 70.0 Hz
(II) fglrx(0): Modeline "1152x864" 96.76 1152 1224 1344 1536 864 865 868 900 +hsync
(**) fglrx(0): Default mode "1152x864": 81.6 MHz (scaled from 0.0 MHz), 53.7 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1152x864" 81.62 1152 1216 1336 1520 864 865 868 895 +hsync
(**) fglrx(0): *Mode "1024x768": 78.8 MHz (scaled from 0.0 MHz), 60.0 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1024x768" 78.75 1024 1040 1136 1312 768 769 772 800
(**) fglrx(0): Default mode "1024x768": 78.4 MHz (scaled from 0.0 MHz), 57.7 kHz, 72.0 Hz
(II) fglrx(0): Modeline "1024x768" 78.43 1024 1080 1192 1360 768 769 772 801 +hsync
(**) fglrx(0): Default mode "1024x768": 75.0 MHz (scaled from 0.0 MHz), 56.5 kHz, 70.0 Hz
(II) fglrx(0): Modeline "1024x768" 75.00 1024 1048 1184 1328 768 771 777 806 +hsync +vsync
(**) fglrx(0): Default mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1024x768" 65.00 1024 1048 1184 1344 768 771 777 806 +hsync +vsync
(**) fglrx(0): *Mode "1024x480": 38.2 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1024x480" 38.16 1024 1048 1152 1280 480 481 484 497 +hsync
(**) fglrx(0): *Mode "960x720": 55.9 MHz (scaled from 0.0 MHz), 44.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "960x720" 55.85 960 1008 1104 1248 720 721 724 746 +hsync
(**) fglrx(0): *Mode "864x648": 45.1 MHz (scaled from 0.0 MHz), 40.2 kHz, 60.0 Hz
(II) fglrx(0): Modeline "864x648" 45.08 864 904 992 1120 648 649 652 671 +hsync
(**) fglrx(0): *Mode "856x480": 31.7 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "856x480" 31.73 856 872 960 1064 480 481 484 497 +hsync
(**) fglrx(0): *Mode "848x480": 31.5 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "848x480" 31.48 848 864 952 1056 480 481 484 497 +hsync
(**) fglrx(0): *Mode "800x600": 49.5 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz
(II) fglrx(0): Modeline "800x600" 49.50 800 816 896 1056 600 601 604 625
(**) fglrx(0): Default mode "800x600": 50.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.0 Hz
(II) fglrx(0): Modeline "800x600" 50.00 800 856 976 1040 600 637 643 666
(**) fglrx(0): Default mode "800x600": 45.5 MHz (scaled from 0.0 MHz), 43.8 kHz, 70.0 Hz
(II) fglrx(0): Modeline "800x600" 45.50 800 840 920 1040 600 601 604 625 +hsync
(**) fglrx(0): Default mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "800x600" 40.00 800 840 968 1056 600 601 605 628
(**) fglrx(0): Default mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.0 Hz
(II) fglrx(0): Modeline "800x600" 36.00 800 824 896 1024 600 601 603 625
(**) fglrx(0): Default mode "800x600": 29.6 MHz (scaled from 0.0 MHz), 29.8 kHz, 47.0 Hz (I)
(II) fglrx(0): Modeline "800x600" 29.60 800 816 896 992 600 601 604 635 interlace +hsync
(**) fglrx(0): *Mode "720x576": 32.7 MHz (scaled from 0.0 MHz), 35.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "720x576" 32.66 720 744 816 912 576 577 580 597 +hsync
(**) fglrx(0): *Mode "720x480": 26.7 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "720x480" 26.71 720 736 808 896 480 481 484 497 +hsync
(**) fglrx(0): *Mode "704x480": 26.2 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "704x480" 26.24 704 720 792 880 480 481 484 497 +hsync
(**) fglrx(0): *Mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
(II) fglrx(0): Modeline "640x480" 31.50 640 656 720 840 480 481 484 500 +hsync +vsync
(**) fglrx(0): Default mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 72.0 Hz
(II) fglrx(0): Modeline "640x480" 31.50 640 664 704 832 480 489 492 520 +hsync +vsync
(**) fglrx(0): Default mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x480" 25.18 640 656 752 800 480 490 492 525 +hsync +vsync
(**) fglrx(0): Default mode "640x400": 28.1 MHz (scaled from 0.0 MHz), 33.7 kHz, 75.0 Hz
(II) fglrx(0): Modeline "640x400" 28.07 640 696 736 832 400 413 415 449
(**) fglrx(0): Default mode "640x400": 24.9 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x400" 24.92 640 664 760 792 400 460 462 525
(**) fglrx(0): Default mode "512x384": 19.8 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "512x384" 19.81 512 544 624 664 384 451 453 497
(**) fglrx(0): Default mode "400x300": 24.8 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "400x300" 24.75 400 408 448 528 300 601 602 625 doublescan
(**) fglrx(0): Default mode "400x300": 22.3 MHz (scaled from 0.0 MHz), 45.0 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "400x300" 22.33 400 416 480 496 300 601 605 742 doublescan
(**) fglrx(0): Default mode "320x240": 15.8 MHz (scaled from 0.0 MHz), 37.9 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "320x240" 15.75 320 328 360 416 240 481 482 501 doublescan
(**) fglrx(0): Default mode "320x240": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "320x240" 12.59 320 328 376 400 240 491 493 525 doublescan
(**) fglrx(0): Default mode "320x200": 13.1 MHz (scaled from 0.0 MHz), 31.5 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "320x200" 13.10 320 352 368 416 200 406 407 417 doublescan
(**) fglrx(0): Default mode "320x200": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "320x200" 12.59 320 336 384 400 200 457 459 524 doublescan
(++) fglrx(0): DPI set to (96, 96)
(--) fglrx(0): Virtual size is 1280x1024 (pitch 1280)
