Proszę o pomoc.NX> 203 NXSSH running with pid: 340
NX> 285 Enabling check on switch command
NX> 285 Enabling skip of SSH config files
NX> 285 Setting the preferred NX options
NX> 200 Connected to address: 87.98.138.212 on port: 22
NX> 202 Authenticating user: nx
NX> 208 Using auth method: publickey
HELLO NXSERVER - Version 3.1.0-2 - LFE
NX> 105 Hello NXCLIENT - Version 3.1.0
NX> 134 Accepted protocol: 3.1.0
NX> 105 Set shell_mode: shell
NX> 105 Set auth_mode: password
NX> 105 Login
NX> 101 User: davidch
NX> 102 Password: *****************
NX> 103 Welcome to: r16764.ovh.net user: davidch
NX> 105 Listsession --user="davidch" --status="suspended\054running" --geometry="1024x768x32+render" --type="unix-gnome"
NX> 127 Available sessions:
Display Type Session ID Options Depth Screen Status Session Name
1013 unix-gnome 21BF3768211F78EA6EE99EAF9E0CB4F7 -RD--PSA 32 1024x738 Suspended Test Debian Deskopt
NX> 147 Server capacity: reached for user: davidch
NX> 105 Restoresession --link="adsl" --backingstore="1" --encryption="1" --cache="16M" --images="64M" --shmem="1" --shpix="1" --strict="0" --composite="1" --media="1" --mediahelper="esd" --session="Test\040Debian\040Deskopt" --type="unix-gnome" --geometry="1024x738" --client="winnt" --keyboard="pc102\057pl" --id="21BF3768211F78EA6EE99EAF9E0CB4F7" --resize="1"
NX> 596 NX> 596 ERROR: NXNODE Ver. 3.1.0-3 (Error id e96BE52)
NX> 596 NX> 596 ERROR: resume session: run commands
NX> 596 NX> 596 ERROR: execution of last command failed
NX> 596 NX> 596 last command: /bin/bash --login -c 'kill -USR2 23821'
NX> 596 NX> 596 exit value: 1
NX> 596 NX> 596 stdout:
NX> 596 NX> 596 stderr: /bin/bash: line 0: kill: (23821) - Nie ma takiego procesu
NX> 596 NX> 596 init: stdin arguments: user=davidch,userip=83%2e12%2e79%2e26,uniqueid=21B F3768211F78EA6EE99EAF9E0CB4F7,display=1013,images= 64M,cache=16M,client=winnt,media=1,backingstore=1, encryption=1,strict=0,clipboard=both,shpix=1,rootl ess=0,composite=1,session=Test%20Debian%20Deskopt, shmem=1,type=unix-gnome,virtualdesktop=1,resize=1,keyboard=pc102%2fp l,id=21BF3768211F78EA6EE99EAF9E0CB4F7,mediahelper= esd,geometry=1024x738,link=adsl,render=1,subscript ionid=None,productid=LFE,balance_host=87%2e98%2e13 8%2e212,encryption_mode=3,connection=local
NX> 280 Exiting on signal: 15
Restartowałem serwer ale nic nie pomaga, dodam że wcześniej skasowałem drugiego użytkownika serwera przez ssh komendą
deluser kimi[Dodano: 2008-12-13, 20:49]
Znalazłem takie coś:
Więc proszę o podpowiedz jak wyczyścić ten katalog /.nx/1. Zaloguj się przez SSH i sprawdź czy przypadkiem nie masz zajętego całego miejsca na serwerze. A przynajmniej na partycjo HOME. Sądzę, że to może być powodem. Jedna osoba, której obsługiwałem serwer też miała podobnie i to zajęcia właśnie całego dysku spowodowało problem.
2. Z godzinę temu właściwie udało mi się sprawę załatwić.
Odinstalowałem FreeNXa 1.5, który był standardowo zainstalowany na moim Ubuntu i zainstalowałem NX Free Edition 3.2. Też miałem problemy, ale tu chociaż w logach znalazłem podpowiedzi.
Rzeczywiście, w logach była informacja o tym, że nie ma miejsca na dysku (w katalogu /.nx/). Chociaż oczywiście miejsce na dysku było. Pomogło skasowanie tego katalogu i nagle wszystko zaczęło działać.
Przepraszam za post pod postem.
[ Dodano: 2008-12-19, 15:49 ]
Zna ktos odpowiedz bo głowie sie i nic nie wiem
