Przeszedłem z Ubuntu na Debiana Lenny i bardzo on mi się podoba - jest szybszy ale mam problem z instalacją sterowników do karty graficznej (Nvidia GF 9600).
Zainstalowałem sterownik pobrany ze strony Nvidii i wszystko poszło dobrze.
Po wykonaniu:
/etc/init.d/gdm stopMój xorg.conf wygląda następująco:
# xorg.conf (X.Org X Window System server configuration file)
# package.
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
Option "UseFBDev" "true"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSectionPróbowałem:
dpkg-reconfigure -phigh xserver-xorgMój Xorg.0.log wygląda następująco:
X.Org X Server 1.4.2
Release Date: 11 June 2008
Build Operating System: Linux Debian (xorg-server 2:1.4.2-9)
Current Operating System: Linux krzysiek-debian 2.6.26-1-686 #1 SMP Wed Nov 26 19:14:11 UTC 2008 i686
Build Date: 15 November 2008 05:39:59PM
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Dec 11 16:34:47 2008
(==) No Layout section. Using the first Screen section.
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Configured Monitor"
(==) No device specified for screen "Default Screen".
Using the first device section listed.
(**) | |-->Device "Configured Video Device"
(==) |-->Input Device "Configured Mouse"
(==) |-->Input Device "Generic Keyboard"
(==) The core pointer device wasn't specified explicitly in the layout.
Using the first mouse device.
(==) The core keyboard device wasn't specified explicitly in the layout.
Using the first keyboard device.
(==) No FontPath specified. Using compiled-in default.
Entry deleted from font path.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to "/etc/X11/rgb"
(II) Loader magic: 0x81e38a0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 2.0
X.Org XInput driver : 2.0
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
compiled for 1.4.2, module version = 1.0.0
ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: 00:00:0: chip 1002,7910 card 1458,5000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:02:0: chip 1002,7913 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:12:0: chip 1002,4380 card 1458,b002 rev 00 class 01,06,01 hdr 00
(II) PCI: 00:13:0: chip 1002,4387 card 1458,5004 rev 00 class 0c,03,10 hdr 80
(II) PCI: 00:13:1: chip 1002,4388 card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:2: chip 1002,4389 card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:3: chip 1002,438a card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:4: chip 1002,438b card 1458,5004 rev 00 class 0c,03,10 hdr 00
(II) PCI: 00:13:5: chip 1002,4386 card 1458,5004 rev 00 class 0c,03,20 hdr 00
(II) PCI: 00:14:0: chip 1002,4385 card 1458,4385 rev 14 class 0c,05,00 hdr 80
(II) PCI: 00:14:1: chip 1002,438c card 1458,5002 rev 00 class 01,01,8a hdr 00
(II) PCI: 00:14:2: chip 1002,4383 card 1458,a002 rev 00 class 04,03,00 hdr 00
(II) PCI: 00:14:3: chip 1002,438d card 1458,5001 rev 00 class 06,01,00 hdr 80
(II) PCI: 00:14:4: chip 1002,4384 card 0000,0000 rev 00 class 06,04,01 hdr 81
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 10de,0622 card 1043,8275 rev a1 class 03,00,00 hdr 00
(II) PCI: 02:0f:0: chip 10ec,8167 card 1458,e000 rev 10 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:2:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000e000 - 0x0000efff (0x1000) IX
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf8000000 - 0xfbffffff (0x4000000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:20:3), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:20:4), (0,2,2), BCTRL: 0x0000 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfdf00000 - 0xfdffffff (0x100000) MX
(II) Bus 2 prefetchable memory range:
[0] -1 0 0xfde00000 - 0xfdefffff (0x100000) MX
(--) PCI:*(1:0:0) nVidia Corporation unknown chipset (0x0622) rev 161, Mem @ 0xfa000000/24, 0xd0000000/28, 0xf8000000/25, I/O @ 0xef00/7
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xfdfff000 - 0xfdfff0ff (0x100) MX[B]
[1] -1 0 0xfe024000 - 0xfe027fff (0x4000) MX[B]
[2] -1 0 0xfe029000 - 0xfe0290ff (0x100) MX[B]
[3] -1 0 0xfe02a000 - 0xfe02afff (0x1000) MX[B]
[4] -1 0 0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
[5] -1 0 0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
[6] -1 0 0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
[7] -1 0 0xfe02e000 - 0xfe02efff (0x1000) MX[B]
[8] -1 0 0xfe02f000 - 0xfe02f3ff (0x400) MX[B]
[9] -1 0 0xf8000000 - 0xf9ffffff (0x2000000) MX[B](B)
[10] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[11] -1 0 0xfa000000 - 0xfaffffff (0x1000000) MX[B](B)
[12] -1 0 0x0000de00 - 0x0000deff (0x100) IX[B]
[13] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[14] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[15] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[16] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[17] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[18] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[19] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[20] -1 0 0x0000fc00 - 0x0000fc03 (0x4) IX[B]
[21] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[22] -1 0 0x0000fe00 - 0x0000fe03 (0x4) IX[B]
[23] -1 0 0x0000ff00 - 0x0000ff07 (0x8) IX[B]
[24] -1 0 0x0000ef00 - 0x0000ef7f (0x80) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xfdfff000 - 0xfdfff0ff (0x100) MX[B]
[5] -1 0 0xfe024000 - 0xfe027fff (0x4000) MX[B]
[6] -1 0 0xfe029000 - 0xfe0290ff (0x100) MX[B]
[7] -1 0 0xfe02a000 - 0xfe02afff (0x1000) MX[B]
[8] -1 0 0xfe02b000 - 0xfe02bfff (0x1000) MX[B]
[9] -1 0 0xfe02c000 - 0xfe02cfff (0x1000) MX[B]
[10] -1 0 0xfe02d000 - 0xfe02dfff (0x1000) MX[B]
[11] -1 0 0xfe02e000 - 0xfe02efff (0x1000) MX[B]
[12] -1 0 0xfe02f000 - 0xfe02f3ff (0x400) MX[B]
[13] -1 0 0xf8000000 - 0xf9ffffff (0x2000000) MX[B](B)
[14] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
[15] -1 0 0xfa000000 - 0xfaffffff (0x1000000) MX[B](B)
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[18] -1 0 0x0000de00 - 0x0000deff (0x100) IX[B]
[19] -1 0 0x0000f900 - 0x0000f90f (0x10) IX[B]
[20] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[21] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[22] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[23] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[24] -1 0 0x00000b00 - 0x00000b0f (0x10) IX[B]
[25] -1 0 0x0000fb00 - 0x0000fb0f (0x10) IX[B]
[26] -1 0 0x0000fc00 - 0x0000fc03 (0x4) IX[B]
[27] -1 0 0x0000fd00 - 0x0000fd07 (0x8) IX[B]
[28] -1 0 0x0000fe00 - 0x0000fe03 (0x4) IX[B]
[29] -1 0 0x0000ff00 - 0x0000ff07 (0x8) IX[B]
[30] -1 0 0x0000ef00 - 0x0000ef7f (0x80) IX[B](B)
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Loading extension SHAPE
(II) Loading extension SYNC
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
Backtrace:
Bardzo proszę o pomoc bo jako początkującemu opadły mi ręce - mój kernel 2.6.26-1-686.
