każda sieciówka jest w innym komputerze
sieciówka intel pro100: lspci -vv
Ethernet controller: Intel Corporation 82801DB PRO/100 VE (LOM) Ethernet Controller (rev 81)
Subsystem: ASUSTeK Computer Inc. Unknown device 8071
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
Latency: 32 (2000ns min, 14000ns max), Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 209
Region 0: Memory at f0000000 (32-bit, non-prefetchable) [size=4K]
Region 1: I/O ports at b800 [size=200]
Capabilities: [dc] Power Management version 2
Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 PME-Enable- DSel=0 DScale=2 PME-Status: Cap+ 66MHz- wynika z tego również, że sieciówka mogłaby pracować na 66Mhz, dobrze myślę?
Inna sieciówka Intel PRO/1000 MT - sieciówka na pci-x wsadzona w zwykle gniazdo pci.
Ethernet controller: Intel Corporation 82545GM Gigabit Ethernet Controller (rev 04)
Subsystem: Intel Corporation PRO/1000 MT Server Adapter
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR+ FastB2B-
Status: Cap+ 66Mhz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
Latency: 64 (63750ns min), cache line size 04
Interrupt: pin A routed to IRQ 21
Region 0: Memory at f7ee0000 (64-bit, non-prefetchable) [size=128K]
Region 2: Memory at f7e80000 (64-bit, non-prefetchable) [size=256K]
Region 4: I/O ports at df00 [size=200]
Expansion ROM at fea00000 [disabled] [size=256K]
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [e4] PCI-X non-bridge device.
Command: DPERE- ERO+ RBC=0 OST=0
Status: Bus=0 Dev=0 Func=0 64bit- 133MHz- SCD- USC-, DC=simple, DMMRBC=0, DMOST=0, DMCRS=0, RSCEM-Jeszcze ciekawostka proszę zwrócić uwagę na:
Region 2: Memory at f7e80000 (64-bit, non-prefetchable) [size=256K]Teraz jeszcze 3 sieciówka DELL/Intel PRO/1000 MT - sieciówka pci-x wsadzona w gniazdo pci-x i z jedną pamiecią?
Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
Latency: 52 (63750ns min), Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 225
Region 0: Memory at dd220000 (64-bit, non-prefetchable) [size=128K]
Region 4: I/O ports at 4040 [size=200]
Command: DPERE- ERO+ RBC=512 OST=1
Status: Dev=02:02.0 64bit+ 133MHz+ SCD- USC- DC=simple DMMRBC=2048 DMOST=1 DMCRS=16 RSCEM- 266MHz- 533MHz-
Capabilities: [f0] Message Signalled Interrupts: Mask- 64bit+ Queue=0/0 Enable-
Address: 0000000000000000 Data: 0000
