Jak odpalam Conky z konfiguracja
http://gnome-look.org/content/show.php/ ... tent=92328
Mam bardzo wysokie zużycie CPU okolo 80% ...
przy innych konifguracjach w normie okolo 5%..
Prosze o pomoc ...
Conky wysokie zużycie CPU
Siemka.
Nie pomoge Ci ale podesle moj config conky ;-)
conky.conf
conky.conf2
.fluxbox/startup
I smiga az milo ;-)
pz
conky.conf
background yes
font 7x13
use_xft no
on_bottom no
update_interval 1.0
total_run_times 0
#own_window no
own_window yes
own_window_type normal
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
own_window_transparent yes
#own_window_transparent yes
double_buffer yes
minimum_size 250
draw_shades yes
draw_outline no
draw_borders no
stippled_borders 8
border_margin 4
border_width 1
default_color white
default_shade_color black
default_outline_color black
alignment top_left
maximum_width 300
gap_x 10
gap_y 50
no_buffers yes
uppercase no
cpu_avg_samples 1
net_avg_samples 1
#override_utf8_locale yes
#override_Xft_locale no
use_spacer no
# stuff after 'TEXT' will be formatted on screen
TEXT
${color #7f8ed3} $alignc${color #5b6dad}$nodename
${color #7f8ed3} $alignc${time %a, } ${color #5b6dad}${time %e %B %G}
${color #7f8ed3} $alignc${time %Z, } ${color #5b6dad}${time %H:%M:%S}
${color #7f8ed3} $alignc linux-$kernel
${hr 1}
Battery $battery Time left $battery_time
$battery_bar(10,300)
${hr 1}
${color #5b6dad}Uptime:${color #7f8ed3} $uptime ${color #5b6dad}$alignr Load:${color #7f8ed3} $loadavg
${color #5b6dad}CPU Frequency:${color #7f8ed3} $freq_dyn MHz ${color #5b6dad} Maximum:${color #7f8ed3} $freq MHz
${color #5b6dad}CPU Usage:${color #7f8ed3} $cpu% ${cpubar}
${color #000000}${cpugraph cpu0 25,309 000000 7f8ed3}
${color #5b6dad}Total RAM :${color #7f8ed3} $alignr $memmax
${membar}$memperc%
${color #5b6dad}Memory in use : ${color #7f8ed3} $alignr ${mem}
${color #5b6dad}Memory buffered: ${color #7f8ed3} $alignr ${buffers}
${color #5b6dad}Memory cached : ${color #7f8ed3} $alignr ${cached}
${color #5b6dad}Total Swap :${color #7f8ed3} $alignr $swapmax
${swapbar}$swapperc%
${color #5b6dad}Swap in use :${color #7f8ed3} $alignr ${swap}
${hr 1}
${color #5b6dad}Processes:${color #7f8ed3} $processes ${color #5b6dad}$alignr Running:${color #7f8ed3} $running_processes
${color #5b6dad}CPU usage $alignr PID CPU% MEM%
${color #7f8ed3}${top name 1} $alignr ${top pid 1} ${top cpu 1} ${top mem 1}
${color #7f8ed3}${top name 2} $alignr ${top pid 2} ${top cpu 2} ${top mem 2}
${color #7f8ed3}${top name 3} $alignr ${top pid 3} ${top cpu 3} ${top mem 3}
${color #7f8ed3}${top name 4} $alignr ${top pid 4} ${top cpu 4} ${top mem 4}
${color #7f8ed3}${top name 5} $alignr ${top pid 5} ${top cpu 5} ${top mem 5}
${color #5b6dad}Mem usage $alignr PID CPU% MEM%
${color #7f8ed3}${top_mem name 1} $alignr ${top_mem pid 1} ${top_mem cpu 1} ${top_mem mem 1}
${color #7f8ed3}${top_mem name 2} $alignr ${top_mem pid 2} ${top_mem cpu 2} ${top_mem mem 2}
${color #7f8ed3}${top_mem name 3} $alignr ${top_mem pid 3} ${top_mem cpu 3} ${top_mem mem 3}
${color #7f8ed3}${top_mem name 4} $alignr ${top_mem pid 4} ${top_mem cpu 4} ${top_mem mem 4}
${color #7f8ed3}${top_mem name 5} $alignr ${top_mem pid 5} ${top_mem cpu 5} ${top_mem mem 5}
${hr 1}
${color #5b6dad}hda io :${color #7f8ed3} $alignr ${diskio hda}
${color #5b6dad}hda read :${color #7f8ed3} $alignr ${diskio_read hda}
${color #5b6dad}hda write :${color #7f8ed3} $alignr ${diskio_write hda}
${color #5b6dad} / ${color #7f8ed3}${fs_used /} / ${fs_size /} ${color #7f8ed3}${fs_bar /}
${color #5b6dad}hda7 ${color #7f8ed3}${fs_used /mnt/hda7} / ${fs_size /mnt/hda7} ${color #7f8ed3}${fs_bar /mnt/hda7}
${color #5b6dad}winxp ${color #7f8ed3}${fs_used /mnt/winxp} / ${fs_size /mnt/winxp} ${color #7f8ed3}${fs_bar /mnt/winxp}
${color #5b6dad}dane ${color #7f8ed3}${fs_used /mnt/dane} / ${fs_size /mnt/dane} ${color #7f8ed3}${fs_bar /mnt/dane}
${hr 1}
${color #5b6dad}ibm fan speed :${color #7f8ed3} $alignr ${ibm_fan}rpm
${color #5b6dad}ibm cpu temp :${color #7f8ed3} $alignr ${ibm_temps 0}C
${color #5b6dad}ibm gpu temp :${color #7f8ed3} $alignr ${ibm_temps 3}C
${color #5b6dad}ibm hdd temp :${color #7f8ed3} $alignr ${ibm_temps 2}C
alignment top_right
double_buffer yes
#gap_x 100
#gap_y 50
TEXT
${color #5b6dad}wire - eth0: ${alignr}${color #5b6dad}Address: ${color #7f8ed3}${addr eth0}
${color #5b6dad}Down:${color #7f8ed3} ${downspeed eth0} k/s${color #5b6dad}${offset 80}Up:${color #7f8ed3} ${upspeed eth0} k/s
${color #000000}${downspeedgraph eth0 25,150 000000 7f8ed3} ${color #000000}${upspeedgraph eth0 25,150 000000 7f8ed3}
${color #5b6dad}wifi - eth1: ${alignr}${color #5b6dad}Address: ${color #7f8ed3}${addr eth1}
${color #5b6dad}Down:${color #7f8ed3} ${downspeed eth1} k/s${color #5b6dad}${offset 80}Up:${color #7f8ed3} ${upspeed eth1} k/s
${color #000000}${downspeedgraph eth1 25,150 000000 7f8ed3} ${color #000000}${upspeedgraph eth1 25,150 000000 7f8ed3}
${color #5b6dad}Ports:${alignr}Connections:
${color #7f8ed3}Inbound: ${tcp_portmon 1 32767 count} ${color #7f8ed3}Outbound: ${tcp_portmon 32768 61000 count}${alignr}${color #7f8ed3}ALL: ${tcp_portmon 1 65535 count}
${color #5b6dad}Inbound Connection ${alignr} Local Service/Port$color
${color #7f8ed3}${tcp_portmon 1 32767 rhost 0} ${alignr} ${tcp_portmon 1 32767 lservice 0}
${color #7f8ed3}${tcp_portmon 1 32767 rhost 1} ${alignr} ${tcp_portmon 1 32767 lservice 1}
${color #7f8ed3}${tcp_portmon 1 32767 rhost 2} ${alignr} ${tcp_portmon 1 32767 lservice 2}
${color #7f8ed3}${tcp_portmon 1 32767 rhost 3} ${alignr} ${tcp_portmon 1 32767 lservice 3}
${color #7f8ed3}${tcp_portmon 1 32767 rhost 4} ${alignr} ${tcp_portmon 1 32767 lservice 4}
${color #5b6dad}Outbound Connection ${alignr} Remote Service/Port$color
${color #7f8ed3}${tcp_portmon 32768 61000 rhost 0} ${alignr} ${tcp_portmon 32768 61000 rservice 0}
${color #7f8ed3}${tcp_portmon 32768 61000 rhost 1} ${alignr} ${tcp_portmon 32768 61000 rservice 1}
${color #7f8ed3}${tcp_portmon 32768 61000 rhost 2} ${alignr} ${tcp_portmon 32768 61000 rservice 2}
${color #7f8ed3}${tcp_portmon 32768 61000 rhost 3} ${alignr} ${tcp_portmon 32768 61000 rservice 3}
${color #7f8ed3}${tcp_portmon 32768 61000 rhost 4} ${alignr} ${tcp_portmon 32768 61000 rservice 4}
${color #5b6dad}Updates:
${color #7f8ed3}${execi 20 cat /var/log/upgrades.log}
conky &
conky -c /etc/conky/conky.conf2 &
pz
