karta Broadcom BCM4311 rev 02
Lenny
jajko 2.6.27.5
gnome i kde(próbuje pod gnome)
Przez synaptica ndiswrapper zainstalował się poprawnie, ale jak mu dam:
 modprobe ndiswrapperKod: Zaznacz cały
FATAL: Module ndiswrapper not found./home/art/Desktop/ndiswrapper-1.53# make
make -C driver
make[1]: Wejście do katalogu `/home/art/Desktop/ndiswrapper-1.53/driver'
make -C /usr/src/linux-2.6.27.5 M=/home/art/Desktop/ndiswrapper-1.53/driver
make[2]: Wejście do katalogu `/usr/src/linux-2.6.27.5'
CC [M] /home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.o
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c: In function ‘ndis_translate_scan’:
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1037: warning: passing argument 1 of ‘iwe_stream_add_event’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1037: warning: passing argument 3 of ‘iwe_stream_add_event’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1037: warning: passing argument 4 of ‘iwe_stream_add_event’ makes pointer from integer without a cast
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1037: error: too few arguments to function ‘iwe_stream_add_event’
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1047: warning: passing argument 1 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1047: warning: passing argument 3 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1047: warning: passing argument 4 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1047: error: too few arguments to function ‘iwe_stream_add_point’
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1053: warning: passing argument 1 of ‘iwe_stream_add_event’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1053: warning: passing argument 3 of ‘iwe_stream_add_event’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1053: warning: passing argument 4 of ‘iwe_stream_add_event’ makes pointer from integer without a cast
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1053: error: too few arguments to function ‘iwe_stream_add_event’
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1064: warning: passing argument 1 of ‘iwe_stream_add_event’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1064: warning: passing argument 3 of ‘iwe_stream_add_event’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1064: warning: passing argument 4 of ‘iwe_stream_add_event’ makes pointer from integer without a cast
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1064: error: too few arguments to function ‘iwe_stream_add_event’
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1079: warning: passing argument 1 of ‘iwe_stream_add_event’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1079: warning: passing argument 3 of ‘iwe_stream_add_event’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1079: warning: passing argument 4 of ‘iwe_stream_add_event’ makes pointer from integer without a cast
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1079: error: too few arguments to function ‘iwe_stream_add_event’
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1093: warning: passing argument 1 of ‘iwe_stream_add_event’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1093: warning: passing argument 3 of ‘iwe_stream_add_event’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1093: warning: passing argument 4 of ‘iwe_stream_add_event’ makes pointer from integer without a cast
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1093: error: too few arguments to function ‘iwe_stream_add_event’
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1104: warning: passing argument 1 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1104: warning: passing argument 3 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1104: warning: passing argument 4 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1104: error: too few arguments to function ‘iwe_stream_add_point’
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1120: warning: passing argument 1 of ‘iwe_stream_add_value’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1120: warning: passing argument 4 of ‘iwe_stream_add_value’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1120: warning: passing argument 5 of ‘iwe_stream_add_value’ makes pointer from integer without a cast
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1120: error: too few arguments to function ‘iwe_stream_add_value’
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1131: warning: passing argument 1 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1131: warning: passing argument 3 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1131: warning: passing argument 4 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1131: error: too few arguments to function ‘iwe_stream_add_point’
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1137: warning: passing argument 1 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1137: warning: passing argument 3 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1137: warning: passing argument 4 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1137: error: too few arguments to function ‘iwe_stream_add_point’
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1159: warning: passing argument 1 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1159: warning: passing argument 3 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1159: warning: passing argument 4 of ‘iwe_stream_add_point’ from incompatible pointer type
/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.c:1159: error: too few arguments to function ‘iwe_stream_add_point’
make[3]: *** [/home/art/Desktop/ndiswrapper-1.53/driver/iw_ndis.o] Błąd 1
make[2]: *** [_module_/home/art/Desktop/ndiswrapper-1.53/driver] Błąd 2
make[2]: Opuszczenie katalogu `/usr/src/linux-2.6.27.5'
make[1]: *** [modules] Błąd 2
make[1]: Opuszczenie katalogu `/home/art/Desktop/ndiswrapper-1.53/driver'
make: *** [all] Błąd 2
