Mój problem polega na czymś takim:
[tydell@myhost ~]$ glxinfo | grep direct
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
[tydell@myhost ~]$ sudo glxinfo | grep direct
direct rendering: Yes
[tydell@myhost ~]$Aby mnie to działało normalnie musiałbym uruchamiać X'y poprzez sudo chyba.
Czy ktoś ma jakieś rozwiązanie tej sytuacji?
Za pomoc dziękuję.
[tydell@myhost ~]$ lspci -nn | grep VGA
01:05.0 VGA compatible controller [0300]: ATI Technologies Inc RS482 [Radeon Xpress 200M] [1002:5975]
[tydell@myhost ~]$ glxinfo |grep vendor
server glx vendor string: SGI
client glx vendor string: SGI
OpenGL vendor string: DRI R300 Project
name of display: :0.0
display: :0 screen: 0
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_swap_control, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_swap_control, GLX_MESA_swap_frame_usage, GLX_OML_swap_method,
GLX_OML_sync_control, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
GLX_SGI_swap_control, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
OpenGL renderer string: Mesa DRI R300 20060815 x86/MMX+/3DNow!+/SSE2 NO-TCL
OpenGL version string: 1.3 Mesa 7.2
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_imaging,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_point_parameters,
GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_program, GL_ARB_window_pos,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_clip_volume_hint, GL_EXT_copy_texture, GL_EXT_draw_range_elements,
GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_point_parameters,
GL_EXT_polygon_offset, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
GL_APPLE_packed_pixels, GL_ATI_texture_env_combine3,
GL_ATI_texture_mirror_once, GL_ATIX_texture_env_combine3,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_MESA_pack_invert, GL_MESA_ycbcr_texture, GL_NV_blend_square,
GL_NV_light_max_exponent, GL_NV_texgen_reflection,
GL_NV_texture_rectangle, GL_NV_vertex_program, GL_SGI_color_matrix,
GL_SGI_color_table, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SGIX_shadow_ambient, GL_SUN_multi_draw_arrays
3 GLX Visuals
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x21 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x22 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x55 32 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
16 GLXFBConfigs:
0x56 0 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x57 0 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x58 0 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x59 0 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x5a 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x5b 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x5c 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x5d 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x5e 0 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x5f 0 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x60 0 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None
0x61 0 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 Slow
0x62 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x63 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x64 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x65 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
Naruszenie ochrony pamięciKod: Zaznacz cały
# Auto-generated by Archie mkxcfg
Section "ServerLayout"
# PS/2 Mouse not detected
# Serial Mouse not detected
Identifier "Xorg Configured"
Screen 0 "Screen0" 0 0
InputDevice "Generic Keyboard" "CoreKeyboard"
#InputDevice "USB Mouse" "CorePointer"
InputDevice "Synaptics" "CorePointer"
Option "AIGLX" "true"
EndSection
Section "Files"
# Additional fonts: Locale, Gimp, TTF...
# FontPath "/usr/share/lib/X11/fonts/latin2/75dpi"
# FontPath "/usr/share/lib/X11/fonts/latin2/100dpi"
# True type and type1 fonts are also handled via xftlib, see /etc/X11/XftConfig!
# RgbPath "/usr/share/X11/rgb"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/misc:unscaled"
FontPath "/usr/share/fonts/misc"
FontPath "/usr/share/fonts/75dpi:unscaled"
FontPath "/usr/share/fonts/75dpi"
FontPath "/usr/share/fonts/100dpi:unscaled"
FontPath "/usr/share/fonts/100dpi"
FontPath "/usr/share/fonts/PEX"
FontPath "/usr/share/fonts/cyrillic"
FontPath "/usr/share/fonts/Type1"
FontPath "/usr/share/fonts/ttf/western"
FontPath "/usr/share/fonts/ttf/decoratives"
FontPath "/usr/share/fonts/truetype"
FontPath "/usr/share/fonts/truetype/openoffice"
FontPath "/usr/share/fonts/truetype/ttf-bitstream-vera"
FontPath "/usr/share/fonts/latex-ttf-fonts"
FontPath "/usr/share/fonts/defoma/CID"
FontPath "/usr/share/fonts/defoma/TrueType"
EndSection
Section "Module"
Load "ddc" # ddc probing of monitor
Load "dbe"
Load "dri"
Load "extmod"
Load "glx"
Load "bitmap" # bitmap-fonts
Load "type1"
Load "freetype"
Load "record"
Load "fglrx"
Load "synaptics"
EndSection
Section "ServerFlags"
Option "AllowMouseOpenFail" "true"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "pl"
EndSection
Identifier "Serial Mouse"
Driver "mouse"
Option "Protocol" "Microsoft"
Option "Device" "/dev/ttyS0"
Option "Emulate3Timeout" "70"
Option "SendCoreEvents" "true"
EndSection
Identifier "PS/2 Mouse"
Driver "mouse"
Option "Protocol" "auto"
Option "ZAxisMapping" "4 5"
Option "Device" "/dev/psaux"
EndSection
#Section "InputDevice"
# Identifier "USB Mouse"
# Driver "mouse"
# Option "Device" "/dev/input/mice"
# Option "SendCoreEvents" "true"
# Option "Protocol" "IMPS/2"
# Option "ZAxisMapping" "4 5"
# Option "Buttons" "5"
#EndSection
Driver "synaptics"
Identifier "Synaptics"
Option "Device" "/dev/input/mouse1"
Option "Protocol" "auto-dev"
Option "LeftEdge" "1700"
Option "RightEdge" "5300"
Option "TopEdge" "1700"
Option "BottomEdge" "4200"
Option "FingerLow" "25"
Option "FingerHigh" "30"
Option "MaxTapTime" "180"
Option "MaxTapMove" "220"
Option "VertScrollDelta" "100"
Option "MinSpeed" "0.06"
Option "MaxSpeed" "0.12"
Option "AccelFactor" "0.0010"
Option "SHMConfig" "on"
# Option "Repeater" "/dev/ps2mouse"
EndSection
Section "Monitor"
# Warning: This may fry old Monitors
# Very conservative. May flicker.
# VertRefresh 50.0 - 62.0 # Extreme conservative. Will flicker. TFT default.
# Default modes distilled from
# "VESA and Industry Standards and Guide for Computer Display Monitor
# Timing", version 1.0, revision 0.8, adopted September 17, 1998.
# $XFree86: xc/programs/Xserver/hw/xfree86/etc/vesamodes,v 1.4 1999/11/18 16:52:17 tsi Exp $
# 640x350 @ 85Hz (VESA) hsync: 37.9kHz
Identifier "Monitor0"
HorizSync 28.0 - 96.0
VertRefresh 50.0 - 75.0
ModeLine "640x350" 31.5 640 672 736 832 350 382 385 445 +hsync -vsync
ModeLine "640x400" 31.5 640 672 736 832 400 401 404 445 -hsync +vsync
ModeLine "720x400" 35.5 720 756 828 936 400 401 404 446 -hsync +vsync
ModeLine "640x480" 25.2 640 656 752 800 480 490 492 525 -hsync -vsync
ModeLine "640x480" 31.5 640 664 704 832 480 489 491 520 -hsync -vsync
ModeLine "640x480" 31.5 640 656 720 840 480 481 484 500 -hsync -vsync
ModeLine "640x480" 36.0 640 696 752 832 480 481 484 509 -hsync -vsync
ModeLine "800x600" 36.0 800 824 896 1024 600 601 603 625 +hsync +vsync
ModeLine "800x600" 40.0 800 840 968 1056 600 601 605 628 +hsync +vsync
ModeLine "800x600" 50.0 800 856 976 1040 600 637 643 666 +hsync +vsync
ModeLine "800x600" 49.5 800 816 896 1056 600 601 604 625 +hsync +vsync
ModeLine "800x600" 56.3 800 832 896 1048 600 601 604 631 +hsync +vsync
ModeLine "1024x768" 44.9 1024 1032 1208 1264 768 768 776 817 +hsync +vsync interlace
ModeLine "1024x768" 65.0 1024 1048 1184 1344 768 771 777 806 -hsync -vsync
ModeLine "1024x768" 75.0 1024 1048 1184 1328 768 771 777 806 -hsync -vsync
ModeLine "1024x768" 78.8 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
ModeLine "1024x768" 94.5 1024 1072 1168 1376 768 769 772 808 +hsync +vsync
ModeLine "1152x864" 108.0 1152 1216 1344 1600 864 865 868 900 +hsync +vsync
ModeLine "1280x960" 108.0 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync
ModeLine "1280x960" 148.5 1280 1344 1504 1728 960 961 964 1011 +hsync +vsync
ModeLine "1280x1024" 108.0 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
ModeLine "1280x1024" 135.0 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync
ModeLine "1280x1024" 157.5 1280 1344 1504 1728 1024 1025 1028 1072 +hsync +vsync
ModeLine "1600x1200" 162.0 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
ModeLine "1600x1200" 175.5 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
ModeLine "1600x1200" 189.0 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
ModeLine "1600x1200" 202.5 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
ModeLine "1600x1200" 229.5 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync
ModeLine "1792x1344" 204.8 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync
ModeLine "1792x1344" 261.0 1792 1888 2104 2456 1344 1345 1348 1417 -hsync +vsync
ModeLine "1856x1392" 218.3 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync
ModeLine "1856x1392" 288.0 1856 1984 2208 2560 1392 1393 1396 1500 -hsync +vsync
ModeLine "1920x1440" 234.0 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync
ModeLine "1920x1440" 297.0 1920 2064 2288 2640 1440 1441 1444 1500 -hsync +vsync
ModeLine "1800x1440" 230.0 1800 1896 2088 2392 1440 1441 1444 1490 +hsync +vsync
ModeLine "1800x1440" 250.0 1800 1896 2088 2392 1440 1441 1444 1490 +hsync +vsync
ModeLine "640x480" 43.2 640 680 744 848 480 481 484 509 -hsync +vsync
ModeLine "768x576" 35.0 768 792 872 976 576 577 580 597 -hsync +vsync
ModeLine "768x576" 42.9 768 800 880 992 576 577 580 601 -hsync +vsync
ModeLine "768x576" 45.5 768 808 888 1008 576 577 580 602 -hsync +vsync
ModeLine "768x576" 51.8 768 808 888 1008 576 577 580 605 -hsync +vsync
ModeLine "768x576" 62.6 768 816 896 1024 576 577 580 611 -hsync +vsync
ModeLine "800x600" 68.2 800 848 936 1072 600 601 604 636 -hsync +vsync
ModeLine "1024x768" 113.3 1024 1096 1208 1392 768 769 772 814 -hsync +vsync
ModeLine "1152x864" 81.6 1152 1216 1336 1520 864 865 868 895 -hsync +vsync
ModeLine "1152x864" 119.7 1152 1224 1352 1552 864 865 868 907 -hsync +vsync
ModeLine "1152x864" 143.5 1152 1232 1360 1568 864 865 868 915 -hsync +vsync
ModeLine "1280x960" 124.5 1280 1368 1504 1728 960 961 964 1001 -hsync +vsync
ModeLine "1280x960" 129.9 1280 1368 1504 1728 960 961 964 1002 -hsync +vsync
ModeLine "1280x960" 179.0 1280 1376 1520 1760 960 961 964 1017 -hsync +vsync
ModeLine "1280x1024" 191.0 1280 1376 1520 1760 1024 1025 1028 1085 -hsync +vsync
ModeLine "1400x1050" 122.6 1400 1488 1640 1880 1050 1051 1054 1087 -hsync +vsync
ModeLine "1400x1050" 149.3 1400 1496 1648 1896 1050 1051 1054 1094 -hsync +vsync
ModeLine "1400x1050" 155.8 1400 1496 1648 1896 1050 1051 1054 1096 -hsync +vsync
ModeLine "1400x1050" 179.3 1400 1504 1656 1912 1050 1051 1054 1103 -hsync +vsync
ModeLine "1400x1050" 214.4 1400 1512 1664 1928 1050 1051 1054 1112 -hsync +vsync
ModeLine "1600x1200" 280.6 1600 1728 1904 2208 1200 1201 1204 1271 -hsync +vsync
Option "DPMS" "true"
# HorizSync 28.0 - 78.0 # Warning: This may fry very old Monitors
EndSection
Section "Monitor"
Identifier "amdcccle-Monitor[1]-0"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
EndSection
Section "Device"
Identifier "Card0"
Driver "radeon"
VendorName "All"
BoardName "All"
BusID "PCI:1:5:0"
Option "RenderAccel" "true"
Option "DRI" "true"
Option "MergedDPI" "96 96"
Option "XAANoOffscreenPixmaps" "true"
Option "HWCursor" "true"
Option "ColorTiling" "on"
Option "AccelMethod" "EXA"
Option "MigrationHeuristic" "greedy"
Option "EnablePageFlip" "on"
EndSection
#Section "Device"
# Identifier "amdcccle-Device[1]-0"
# Driver "fglrx"
# BusID "01:05:0"
#EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
Modes "1440x900" "1280x800" "1024x768" "800x600" "640x480"
EndSubSection
Depth 32
EndSubSection
EndSection
Section "Screen"
Identifier "amdcccle-Screen[1]-0"
Device "amdcccle-Device[1]-0"
Monitor "amdcccle-Monitor[1]-0"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Group "video"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "Enable"
Option "RENDER" "Enable"
EndSection
