Otoz po wpisaniu komendy sensors w terminalu widze taki oto obraz:
Adapter: Virtual device
temp1: +46.5°C (crit = +100.0°C)
w83627hf-isa-0290
Adapter: ISA adapter
VCore 1: +1.60 V (min = +1.34 V, max = +1.76 V)
VCore 2: +2.74 V (min = +1.34 V, max = +1.76 V) ALARM
+3.3V: +2.85 V (min = +2.82 V, max = +3.79 V)
+5V: +4.95 V (min = +6.85 V, max = +5.11 V) ALARM
+12V: +11.61 V (min = +14.53 V, max = +15.14 V) ALARM
-12V: -13.02 V (min = -5.12 V, max = -7.43 V) ALARM
-5V: -5.75 V (min = +2.69 V, max = -3.74 V) ALARM
V5SB: +5.32 V (min = +2.66 V, max = +2.98 V) ALARM
VBat: +3.52 V (min = +3.06 V, max = +2.00 V) ALARM
fan1: 2986 RPM (min = 1454 RPM, div = 4)
fan2: 2678 RPM (min = 1461 RPM, div = 4)
fan3: 0 RPM (min = 2836 RPM, div = 4) ALARM
temp1: +29.0°C (high = -38.0°C, hyst = +103.0°C) sensor = thermistor
temp2: +46.5°C (high = +75.0°C, hyst = +70.0°C) sensor = thermistor
temp3: -48.0°C (high = +75.0°C, hyst = +70.0°C) sensor = thermistor
cpu0_vid: +1.600 V
beep_enable:enabled
Dodam, ze u mnie fan2 to wiatraczek dodatkowy, podpiety na plycie pod zlaczke chasisfan, ma regulacje predkosci i jakiejbym w nim nie ustawil, sensors zwraca te sama predkosc..
edit:
Po restarcie mam taki oto wynik:
temp1: +23.0°C (crit = +100.0°C)
w83627hf-isa-0290
VCore 1: +1.58 V (min = +1.34 V, max = +1.76 V)
+5V: +4.95 V (min = +6.21 V, max = +4.89 V) ALARM
+12V: +11.73 V (min = +10.52 V, max = +13.19 V)
-12V: -12.61 V (min = -13.10 V, max = -12.69 V) ALARM
-5V: -5.65 V (min = +2.59 V, max = -3.79 V) ALARM
V5SB: +5.40 V (min = +0.94 V, max = +1.21 V) ALARM
VBat: +3.49 V (min = +3.57 V, max = +2.00 V) ALARM
fan1: 2960 RPM (min = 1454 RPM, div = 4)
fan2: 2700 RPM (min = 1461 RPM, div = 4)
temp1: +18.0°C (high = -38.0°C, hyst = +38.0°C) sensor = thermistor
temp2: +23.0°C (high = +75.0°C, hyst = +70.0°C) sensor = thermistor
cpu0_vid: +1.600 V
beep_enable:enabled
