Linux od czego zacz
Linux od czego zacząć?
Witam. Jestem początkującym użytkownikiem Linuksa. Chciałbym się was zapytać co polecacie na początek. Jakie książki, stronki, artykuły itp. Interesuje mnie głównie zarządzanie sieciami
Zacznij od takiej strony: http://www.us.debian.org/doc/
Nie chce zakladac nowego, wiec sie podepne. Czy moze mi ktos powiedziec gdzie znalezc jakis guideline dla wydan Debiana. Aktualna wersja to 4 r5, czy wiadomo kiedy ma wyjsc final? Czy jest w ogole cos takiego (pamietam ze na stornie OO znalazlem kiedys cos takiego odnosnie wydan OO oczywiscie
dzieki
dzieki
greg23, http://release.debian.org/emails/release-update-200801
Release schedule
As we are progressing in our release preparations; we have reviewed
the original schedule for lenny to check for any imminent problems, and
at the moment are quite content with the current state. We are, as always,
concerned about the large number of release critical issues still unfixed
in testing, so please help do something about it (see below for ideas :P)
Now on to the actual, not much revised, schedule:
Early March 2008
Very soft freeze
Please start thinking about the release when uploading new major
upstream versions. Only upload to unstable if you are sure that
the software will be stable before we release. If you are not
convinced, use experimental as staging area.
Freeze of release goal list
We will announce the final list of release goals and report about
the progress made in each area. At this point, goals which look
too hard to complete for lenny will be removed from the list (and
automatically put on the list for lenny+1)
Start of the second BSP marathon for Lenny
See below for more information about this, but you can and should
help with it.
Early April 2008
Freeze of the essential toolchain
Mid of June 2008
Freeze of the non-essential toolchain and all libraries
The "non-essential toolchain" means things like debhelper, cdbs
and a big chunk of other things usually needed to produce binary
packages.
Mid of July 2008
Full freeze
Please don't wait with uploads for the last day before the freeze,
thanks.
September 2008
Release lenny!
