ERROR: Connection dropped by IMAP server.-- edit:
Jako że w nocy byłem już dość zmęczony uzupełniam posta o pewne rzeczy:
dlemon:~# netstat -tap
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 *:46058 *:* LISTEN 2656/rpc.statd
tcp 0 0 localhost.localdo:mysql *:* LISTEN 2335/mysqld
tcp 0 0 *:sunrpc *:* LISTEN 1976/portmap
tcp 0 0 *:auth *:* LISTEN 2517/inetd
tcp 0 0 192.168.1.104:domain *:* LISTEN 3674/named
tcp 0 0 localhost.locald:domain *:* LISTEN 3674/named
tcp 0 0 localhost.localdoma:953 *:* LISTEN 3674/named
tcp 0 0 *:smtp *:* LISTEN 3397/master
tcp6 0 0 *:imaps *:* LISTEN 2480/couriertcpd
tcp6 0 0 * :p op3s *:* LISTEN 2504/couriertcpd
tcp6 0 0 * :p op3 *:* LISTEN 2485/couriertcpd
tcp6 0 0 *:imap2 *:* LISTEN 2468/couriertcpd
tcp6 0 0 *:www *:* LISTEN 2699/apache2
tcp6 0 0 *:domain *:* LISTEN 3674/named
tcp6 0 0 *:ssh *:* LISTEN 2915/sshd
tcp6 0 0 ip6-localhost:953 *:* LISTEN 3674/named
tcp6 0 0 *:https *:* LISTEN 2699/apache2
tcp6 0 720 ::ffff:192.168.1.10:ssh ::ffff:192.168.1.1:7796 ESTABLISHED3689/0
dlemon:/etc/postfix# cat main.cf
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific: Specifying a file name will cause the first
# line of that file to be used as the name. The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
# TLS parameters
smtpd_tls_cert_file = /etc/postfix/smtpd.cert
smtpd_tls_key_file = /etc/postfix/smtpd.key
smtpd_use_tls = yes
smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
myhostname = dlemon.webcitron.pl
mydestination = dlemon.webcitron.pl, localhost, localhost.localdomain
relayhost =
mynetworks = 127.0.0.0/8
mailbox_command = procmail -a "$EXTENSION"
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, mysql:/etc/postfix/mysql-virtual_email2email.cf
virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql-virtual_domains.cf
virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailboxes.cf
virtual_mailbox_base = /home/vmail
virtual_uid_maps = static:5000
virtual_gid_maps = static:5000
smtpd_sasl_auth_enable = yes
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination
transport_maps = proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
virtual_create_maildirsize = yes
virtual_mailbox_extended = yes
virtual_mailbox_limit_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailbox_limit_maps.cf
virtual_mailbox_limit_override = yes
virtual_maildir_limit_message = "The user you are trying to reach is over quota."
virtual_overquota_bounce = yes
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks $virtual_mailbox_limit_maps
dlemon:/etc/postfix# cat sasl/smtpd.conf
pwcheck_method: saslauthd
mech_list: plain login
allow_plaintext: true
auxprop_plugin: mysql
sql_hostnames: 127.0.0.1
sql_user: mail_admin
sql_passwd: 8a!cAd3w
sql_database: mail
sql_select: select password from user where email='%u'
dlemon:/etc/postfix# telnet localhost 25
Trying 127.0.0.1...
Connected to localhost.webcitron.pl.
Escape character is '^]'.
220 dlemon.webcitron.pl ESMTP Postfix (Debian/GNU)
ehlo localhost
250-dlemon.webcitron.pl
250-PIPELINING
250-SIZE 10240000
250-VRFY
250-ETRN
250-STARTTLS
250-AUTH LOGIN PLAIN
250-AUTH=LOGIN PLAIN
250-ENHANCEDSTATUSCODES
250-8BITMIME
250 DSN
Buszując po Internecie w tej sprawie doszedłem do tego że katalogi do przechowywania meili mogą nie być dobrze ustawione. Jako że z serwerem poczty mam do czynienia pierwszy raz niebardzo wiem jak je ustawić (istnieje katalog /home/vmail). Ktoś pomoże ?
