Oct 28 20:09:49 localhost named[2882]: starting BIND 9.3.4-P1.1 -u bind -t /var/lib/named
Oct 28 20:09:49 localhost named[2882]: found 1 CPU, using 1 worker thread
Oct 28 20:09:49 localhost named[2882]: loading configuration from '/etc/bind/named.conf'
Oct 28 20:09:49 localhost named[2882]: listening on IPv4 interface lo, 127.0.0.1#53
Oct 28 20:09:49 localhost named[2882]: listening on IPv4 interface eth1, 192.168.1.100#53
Oct 28 20:09:49 localhost named[2882]: listening on IPv4 interface eth2, 192.168.0.213#53
Oct 28 20:09:49 localhost named[2882]: /etc/bind/named.conf.options:9: using specific query-source port suppresses port randomization and can $Oct 28 20:09:49 localhost named[2882]: /etc/bind/named.conf.options:9: using specific query-source port suppresses port randomization and can $Oct 28 20:09:49 localhost named[2882]: command channel listening on 127.0.0.1#953
Oct 28 20:09:49 localhost named[2882]: command channel listening on ::1#953
Oct 28 20:09:49 localhost named[2882]: zone 0.in-addr.arpa/IN: loaded serial 1
Oct 28 20:09:49 localhost named[2882]: zone 127.in-addr.arpa/IN: loaded serial 1
[color=blue][u]Oct 28 20:09:49 localhost named[2882]: /etc/bind/1.168.192:4: SOA record not at top of zone (1.168.192.IN-ADDR.ARPA.1.168.192.IN-ADDR.ARPA)
Oct 28 20:09:49 localhost named[2882]: zone 1.168.192.IN-ADDR.ARPA/IN: loading master file /etc/bind/1.168.192: not at top of zone[/u][/color]
Oct 28 20:09:49 localhost named[2882]: zone 255.in-addr.arpa/IN: loaded serial 1
Oct 28 20:09:49 localhost named[2882]: zone localhost/IN: loaded serial 1
Oct 28 20:09:49 localhost named[2882]: zone malafirma.pl/IN: loaded serial 2008102602
Oct 28 20:09:49 localhost named[2882]: runningPliki konfiguracyjne: /etc/bind/named.conf.local
zone "malafirma.pl" IN {
type master;
file "/etc/bind/malafirma.pl";
allow-query { any; };
allow-update { none; };
allow-transfer { none; };
zone "1.168.192.IN-ADDR.ARPA" IN {
type master;
file "/etc/bind/1.168.192";
};Kod: Zaznacz cały
options {
directory "/etc/bind";
recursion no;
statistics-file "/etc/bind/bind.stats";
dump-file "/etc/bind/bind.dump";
zone-statistics yes;
notify yes;
transfer-format many-answers;
query-source address * port 53;
transfer-source * port 53;
notify-source * port 53;
forwarders {
194.204.159.1;
194.204.152.34;
auth-nxdomain yes;
listen-on { any; };
listen-on-v6 { none; };
$TTL 604800
$ORIGIN malafirma.pl.
@ IN SOA komputer1.malafirma.pl. root.malafirma.pl. (
2008102602 ; Serial
10800 ; Refresh
3600 ; Retry
86400 ; Expire
3600 ) ; Negative Cache TTL
IN NS komputer1.malafirma.pl.
komputer1 IN A 192.168.1.100
IN MX 10 mail
mail IN A 192.168.1.100
@ IN A 192.168.1.100
www IN A 192.168.1.100
ftp IN A 192.168.1.100
$TTL 604800
;$ORIGIN malafirma.pl.
1.168.192.IN-ADDR.ARPA IN SOA komputer1.malafirma.pl. root.malafirma.pl. (
2008102602 ; Serial
10800 ; Refresh
3600 ; Retry
86400 ; Expire
100 IN PTR komputer1.malafirma.pl.
100 IN PTR mail.malafirma.pl.
100 IN PTR [url]www.malafirma.pl[/url].
100 IN PTR ftp.malafirma.pl.
