rtorrent.rc:
scgi_port = localhost:5000
min_peers = 40
max_peers = 100
min_peers_seed = 10
max_peers_seed = 50
max_uploads = 15
#upload_rate = 50
directory = /home/kierzniak/torrents/doing
session = /home/kierzniak/.rtsession
schedule = watch_directory,5,5,load_start=/home/kierzniak/torrents/watch/*.torrent
schedule = tied_directory,5,5,start_tied=
schedule = untied_directory,5,5,close_untied=
on_finished = move_complete,"execute=mv,-u,$d.get_base_path=,/home/kierzniak/torrents/done/ ;d.set_directory=/home/kierzniak/torrents/done/"
on_start = link1,"create_link=tied,,.started"
on_stop = link1,"delete_link=tied,,.started"
on_finished = link1,"create_link=tied,,.finished"
on_erase = link1,"delete_link=tied,,.finished"
schedule = low_diskspace,5,60,close_low_diskspace=100M
#schedule = ratio,60,60,"stop_on_ratio=120,200M,2000"
port_range = 63963-63981
port_random = no
check_hash = yes
use_udp_trackers = yes
encryption = allow_incoming,try_outgoing,enable_retry
dht = auto
dht_port = 63982[/scroll]
[scroll]<?php
This file is part of wTorrent.
wTorrent is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 3 of the License, or
(at your option) any later version.
wTorrent is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
Modified version of class done by David Marco Martinez
// Base URL of application (where index.php is)
define( 'URL', 'http://kierzniak/' );
define( 'BASE', 'http://kierzniak/' );
// SQLite database file (set folder permision 0777 or chmod to httpd server) (wTorrent will create database when running install.php)
define( 'DB_FILE', 'db/database.db');
// Host or IP to connect to rTorrent
define( 'RT_HOST', 'localhost');
define( 'RT_PORT', 5000);
define( 'RT_DIR', 'RPC2/');
define( 'RT_AUTH', true);
define( 'RT_USER', 'kierzniak');
define( 'RT_PASSWD', 'kierzniak');
// where to use multicall or not
// if wTorrent makes your rtorrent crash, set this to true
define( 'NO_MULTICALL', true);
// Directory in which to save uploaded .torrent files (set folder permision 0777 or chmod to httpd server)
define( 'DIR_TORRENTS', 'torrents/');
// Full path to application directory (where index.php is)
define( 'DIR_EXEC', '/var/www/');
// Permision to set for uploaded .torrent files (don't touch unless you know)
define( 'PERM_TORRENTS', 0777);
// Default location to save downloaded files (can be set for every uploaded .torrent on the ui)
define( 'DIR_DOWNLOAD', '/home/kierzniak/doing');
// Don't touch any of the data below unless you know what you are doing
define( 'DIR_LANG', 'home/lang/' );
define( 'DIR_TPL', 'home/tpl/' );
define( 'DIR_TPL_COMPILE', 'tpl_c/' );
define( 'DIR_TPL_HTML', 'home/html/' );
define( 'DIR_BACKUP', 'backup/' );
define( 'DIR_UPLOAD', 'torrents/');
define( 'TITLE', 'wTorrent' );
define( 'META_TITLE', 'rTorrent web interface' );
define( 'META_KEYWORDS', 'rtorrent xmlrpc interface php web html' );
define( 'META_DESCRIPTION', 'rtorrent web inrface using xmlrpc' );
define( 'DIR_CSS_DETALLS', 'home/css/detalls.css' );
define( 'DIR_CSS_ESTIL', 'home/css/estil.css' );
define( 'DIR_JS', 'home/js/javasc.js' );
define( 'DIR_JSHADE', 'home/js/shadedborder.js' );
define( 'DIR_JSPROTO', 'home/js/prototype.js' );
define( 'DIR_SCRIPTACULOUS','home/js/scriptaculous/scriptaculous.js');
define( 'DIR_FAVICO', 'favicon.ico' );
//define( 'USER_RTORRENT', 'rtorrent');
define( 'DIR_IMG', 'home/img/' );
define( 'SRC_INDEX', 'index.php' );
define( 'SCRAMBLE', false);
define( 'APP', 'wTorrent' );
// Librerias generales
require_once( 'lib/inc/includes.inc.php' );
// Autodeclaracion de clases
autoload( 'lib/cls/', 'cls/', 'home/cls/' );
// Definicion de rutas para UNIX
ini_set( 'include_path', DIR_EXEC );
kierzniak:XML-RPC:d9eabf0352c8ffe3d0c42e253b9168f3
# Debian lighttpd configuration file
############ Options you really have to take care of ####################
## modules to load
# mod_access, mod_accesslog and mod_alias are loaded by default
# all other module should only be loaded if neccesary
# - saves some time
# - saves memory
server.modules = (
"mod_access",
"mod_alias",
"mod_accesslog",
"mod_scgi",
"mod_fastcgi",
# "mod_rewrite",
# "mod_redirect",
# "mod_status",
# "mod_evhost",
# "mod_compress",
# "mod_usertrack",
# "mod_rrdtool",
# "mod_webdav",
# "mod_expire",
# "mod_flv_streaming",
# "mod_evasive"
## a static document-root, for virtual-hosting take look at the
## server.virtual-* options
server.document-root = "/var/www/"
## where to send error-messages to
server.errorlog = "/var/log/lighttpd/error.log"
## files to check for if .../ is requested
index-file.names = ( "index.php", "index.html",
"index.htm", "default.htm" )
## Use the "Content-Type" extended attribute to obtain mime type if possible
# mimetype.use-xattr = "enable"
#### accesslog module
accesslog.filename = "/var/log/lighttpd/access.log"
## deny access the file-extensions
# ~ is for backupfiles from vi, emacs, joe, ...
# .inc is often used for code includes which should in general not be part
# of the document-root
url.access-deny = ( "~", ".inc" )
######### Options that are good to be but not neccesary to be changed #######
## bind to port (default: 80)
# server.port = 81
## bind to localhost only (default: all interfaces)
## server.bind = "localhost"
## error-handler for status 404
#server.error-handler-404 = "/error-handler.html"
#server.error-handler-404 = "/error-handler.php"
## to help the rc.scripts
server.pid-file = "/var/run/lighttpd.pid"
## Format: <errorfile-prefix><status>.html
## -> ..../status-404.html for 'File not found'
#server.errorfile-prefix = "/var/www/"
## virtual directory listings
dir-listing.encoding = "utf-8"
server.dir-listing = "enable"
## send unhandled HTTP-header headers to error-log
#debug.dump-unknown-headers = "enable"
### only root can use these options
# chroot() to directory (default: no chroot() )
#server.chroot = "/"
## change uid to <uid> (default: don't care)
server.username = "www-data"
server.groupname = "www-data"
#### compress module
#compress.cache-dir = "/var/tmp/lighttpd/cache/compress/"
#compress.filetype = ("text/plain", "text/html")
#### status module
# status.status-url = "/server-status"
# status.config-url = "/server-config"
#### url handling modules (rewrite, redirect, access)
# url.rewrite = ( "^/$" => "/server-status" )
# url.redirect = ( "^/wishlist/(.+)" => "http://www.123.org/$1" )
# define a pattern for the host url finding
# %% => % sign
# %0 => domain name + tld
# %1 => tld
# %2 => domain name without tld
# %3 => subdomain 1 name
# %4 => subdomain 2 name
# evhost.path-pattern = "/home/storage/dev/www/%3/htdocs/"
#### expire module
# expire.url = ( "/buggy/" => "access 2 hours", "/asdhas/" => "access plus 1 seconds 2 minutes")
#### rrdtool
# rrdtool.binary = "/usr/bin/rrdtool"
# rrdtool.db-name = "/var/www/lighttpd.rrd"
#### handle Debian Policy Manual, Section 11.5. urls
#### and by default allow them only from localhost
$HTTP["remoteip"] =~ "127.0.0.1" {
alias.url += (
"/doc/" => "/usr/share/doc/",
"/images/" => "/usr/share/images/"
$HTTP["url"] =~ "^/doc/|^/images/" {
dir-listing.activate = "enable"
#### variable usage:
## variable name without "." is auto prefixed by "var." and becomes "var.bar"
#bar = 1
#var.mystring = "foo"
## integer add
#bar += 1
## string concat, with integer cast as string, result: "www.foo1.com"
#server.name = "www." + mystring + var.bar + ".com"
## array merge
#index-file.names = (foo + ".php") + index-file.names
#index-file.names += (foo + ".php")
#### external configuration files
## mimetype mapping
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
## load enabled configuration files,
## read /etc/lighttpd/conf-available/README first
include_shell "/usr/share/lighttpd/include-conf-enabled.pl"
scgi.server = (
"/RPC2" => # RT_DIR
( "127.0.0.1" =>
"host" => "127.0.0.1", # Ip where rtorrent is listening
"port" => 5000, # Port specified in .rtorrent.rc
"check-local" => "disable"
fastcgi.server = ( ".php" => ((
"bin-path" => "/usr/bin/php-cgi",
"socket" => "/tmp/php.socket"
auth.backend = "htdigest"
auth.backend.htdigest.userfile = "/etc/lighttpd/htdigest"
auth.require = ( "/RPC2" =>
"method" => "basic",
"realm" => "XML-RPC",
"require" => "valid-user"
"/torrents" =>
"/db" =>
)[/scroll]
[scroll]#!/bin/bash
### BEGIN INIT INFO
# Provides: rtorrent
# Required-Start: $network
# Required-Stop: $network
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start rtorrent as a daemon
### END INIT INFO
#!/bin/sh
###<Notes>###
# This script depends on screen.
# For the stop function to work, you must set an
# explicit session directory using ABSOLUTE paths (no, ~ is not absolute) in your rtorrent.rc.
# If you typically just start rtorrent with just "rtorrent" on the
# command line, all you need to change is the "user" option.
# Attach to the screen session as your user with
# "screen -dr rtorrent". Change "rtorrent" with srnname option.
# Licensed under the GPLv2 by lostnihilist: lostnihilist _at_ gmail _dot_ com
###</Notes>###
##Start Configuration##
# You can specify your configuration in a different file
# (so that it is saved with upgrades, saved in your home directory,
# or whateve reason you want to)
# by commenting out/deleting the configuration lines and placing them
# in a text file (say /home/user/.rtorrent.init.conf) exactly as you would
# have written them here (you can leave the comments if you desire
# and then uncommenting the following line correcting the path/filename
# for the one you used. note the space after the ".".
# . /etc/rtorrent.init.conf
#Do not put a space on either side of the equal signs e.g.
# user = user
# will not work
# system user to run as
user="kierzniak"
# the system group to run as, not implemented, see d_start for beginning implementation
# group=`id -ng "$user"`
# the full path to the filename where you store your rtorrent configuration
config="/home/kierzniak/.rtorrent.rc"
# set of options to run with
options=""
# default directory for screen, needs to be an absolute path
#base="/home/${user}"
base="/home/kierzniak"
# name of screen session
srnname="rtorrent"
# file to log to (makes for easier debugging if something goes wrong)
logfile="/var/log/rtorrentInit.log"
###END CONFIGURATION###
PATH=/usr/bin:/usr/local/bin:/usr/local/sbin:/sbin:/bin:/usr/sbin
DESC="rtorrent"
NAME=rtorrent
DAEMON=$NAME
SCRIPTNAME=/etc/init.d/$NAME
checkcnfg() {
exists=0
for i in `echo "$PATH" | tr ':' '\n'` ; do
if [ -f $i/$NAME ] ; then
exists=1
break
fi
done
if [ $exists -eq 0 ] ; then
echo "cannot find rtorrent binary in PATH $PATH" | tee -a "$logfile" >&2
exit 3
fi
if ! [ -r "${config}" ] ; then
echo "cannot find readable config ${config}. check that it is there and permissions are appropriate" | tee -a "$logfile" >&2
exit 3
fi
session=`getsession "$config"`
if ! [ -d "${session}" ] ; then
echo "cannot find readable session directory ${session} from config ${config}. check permissions" | tee -a "$logfile" >&2
exit 3
fi
d_start() {
[ -d "${base}" ] && cd "${base}"
stty stop undef && stty start undef
su -c "screen -ls | grep -sq "\.${srnname}[[:space:]]" " ${user} || su -c "screen -dm -S ${srnname} 2>&1 1>/dev/null" ${user} | tee -a "$logfile" >&2
# this works for the screen command, but starting rtorrent below adopts screen session gid
# even if it is not the screen session we started (e.g. running under an undesirable gid
#su -c "screen -ls | grep -sq "\.${srnname}[[:space:]]" " ${user} || su -c "sg \"$group\" -c \"screen -fn -dm -S ${srnname} 2>&1 1>/dev/null\"" ${user} | tee -a "$logfile" >&2
su -c "screen -S "${srnname}" -X screen rtorrent ${options} 2>&1 1>/dev/null" ${user} | tee -a "$logfile" >&2
d_stop() {
if ! [ -s ${session}/rtorrent.lock ] ; then
return
fi
pid=`cat ${session}/rtorrent.lock | awk -F: '{print($2)}' | sed "s/[^0-9]//g"`
if ps -A | grep -sq ${pid}.*rtorrent ; then # make sure the pid doesn't belong to another process
kill -s INT ${pid}
fi
getsession() {
session=`awk '/^[[:space:]]*session[[:space:]]*=[[:space:]]*/{print($3)}' "$config"`
echo $session
checkcnfg
case "$1" in
start)
echo -n "Starting $DESC: $NAME"
d_start
echo "."
stop)
echo -n "Stopping $DESC: $NAME"
d_stop
echo "."
restart|force-reload)
echo -n "Restarting $DESC: $NAME"
d_stop
sleep 1
d_start
echo "."
echo "Usage: $SCRIPTNAME {start|stop|restart|force-reload}" >&2
exit 1
esac
exit 0
INSTALL
wTorrent Settings
Language:
[en___]
Database file: db/database.db______
rTorrent scgi host: localhost___________
rTorrent scgi port: 80__________________
rTorrent scgi folder: /RPC2_______________
Enable auth for the scgi folder:
[False]
rTorrent scgi user: ____________________
rTorrent scgi password: ____________________
Don't use multicall:
[True_]
User scriptaculous effects:
[True_]
Folder to save uploaded torrents: torrents/___________
Folder where wTorrent is: /var/www/___________
Default folder to save torrent data: /data_______________
Set wTorrent login
User: ____________________
Password: ____________________
Try configuration Save configuration
Error: cannot connect to rtorrent, please check host, folder and port values (and user/password if you have auth set up).
[ Dodano: 2008-10-24, 16:40 ]
Jezeli nikt nic nie wie to moze macie jakies inne propozycje GUI do rtorrenta? A moze jaki inny klient? Docelowo ma on byc na dysku sieciowym dns-313 wiec jakis lekki.
